Going from Prius Four, not IV because it isn't a 2010 15" wheels to 17" please help
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PriusCatMouse, Apr 6, 2016.
  1. PriusCatMouse
    PriusCatMouse Junior Member
    31
    Recently purchased a 2013 Prius Four, not IV because only 2010 used uppercase roman numerals for model designation with 15" stock Toyota wheels (tires are like new)
    My friend has a 2013 Prius Five, not V because same as above with stock 17" wheels (needs new tires)
    He said he's willing to sell me his stock 17s in exchange for my 15s (with tires) for $200.
    I understand I may lose a bit of MPG but I really like the look of the 17s
    I'm going to need some tires for the 17s but would like some LRRs
    My 15s are: 195/65/15
    His 17s are: 215/45/17 (I read stock tires are actually 205/50/17)
    What size tires would I need to purchase for the 17s to fit my Four the best?
    What are some good LRR that you would suggest? (it will immediately need tires as they are very worn lol)
    I did check the large LRR thread but it doesn't have many recent posts
    Thank you
  2. Mendel Leisk
    40,586
    Just to clarify, that "2013 Prius V" is a level 5 Prius hatchback, not the larger "Prius v".
    ** Ok, let's get this straight. Only 2010 used uppercase roman numerals. So a Prius V existed in 2010. After that, it is a Prius Five. The Prius v wagon uses a lowercase v. So for the wagon it'd be a Prius v Five. **
    The latter has a different rim, larger tire size. In 2010 there was a "Prius V", and 2011 too? No, no Prius V in 2011. Good 'ol Toyota has created a mess with this, I know. Bottom line, does your friend's car look like yours, lol.
    Assuming yes, the stock 17" size is 215/45R17. It's OD is slightly smaller than 195/65R15, but really minor. That's what our 2010 Canadian Touring came with, BTW. A few people have sub'd 205/50R17, which is closer in OD to 195/65R15, ever so slightly larger, in fact. But this tire seems to always come in heavy duty load style, which means a bit rougher ride?
    215/45R17 would be safest bet, and big tire chains would likely only put that size on. Good for LRR, ok handling, road manners and reasonable price: Bridgestone Ecopia EP422 plus. I was looking at a 2016 demo in Port Moody recently, and that's what they had on. Had a nice rim protector (a flare out of the rubber to prevent rim contact with a light contact), looked good.
  3. PriusCatMouse
    31
    Correct it's the Prius V not the v. Acutally, it is a Prius Five, not a V or v but we got there now... :)
    It the 215/45/17 would be best I will do these, I just wanted to confirm didn't know if I needed to adjust size to fit best for my Four.
    Cool I was actually looking at the EP422s
  4. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    You give your buddy perfectly good 15s with new tires, plus $200, and all you get is 17's with worn out tires? My question is why would you do this?. No "factory" Prius wheel looks that good to me...add to this the 17" tires cost more, there are less choices and you get less mpg. o_O
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I will echo what was said above, you will definitely loose MPG. I have 17" wheels that came on the Prius new. Look at my fuelly, it has logged every gallon of fuel ever burned in this Prius. I have yet to break a overall average of 50 MPG. And yes, I know YMMV. But when you look at similar Pri out there with 15" Wheels and Rubber, there is no doubt about the loss when up-sizing. Buyer beware.
  6. JC91006
    16,674
    8,519
    I really like the improved handling and the looks of the 17" stock Five wheel, I have them on my Prius Two since it isn't a 2010 and Prius V. But I agree with Frodoz, it's not a very good deal giving up $200 plus new tires. It would be worth while as a straight trade
  7. PriusCatMouse
    31
    I like the look of the 17 over the 15 and many others do as well. It's a matter of perfence and the 17s look MUCH better to me.
    Yeah I'll take a small hit on MPG but I'm fine with that.
    I recently bought the Prius Four for $13,300 it's fully loaded with Softex leather, solar sun roof, HUD, and super clean. I'm very happy with it and will be even more happy with the 17s :D
    #7 PriusCatMouse, Apr 6, 2016
  8. PriusCatMouse
    31
    If I could get the 17s anywhere else for less than $200 I would but this is my option and in fine with it.
    I just wanted to confirm the tire size when I put the 17s on my Prius that came stick with the 15s
  9. JC91006
    16,674
    8,519
    If you want to pay for wheels, you can get these 17" TSS wheels from the Gulf States Toyota.....Dorunron has them. They cost around $600 and you don't have to give up your stock wheels.
    alanclarkeau and Bay Stater like this.
  10. PriusCatMouse
    31
    Those look nice
  11. frodoz737
    4,535
    2,438
    33
    Still think your buddy's getting the better end of this by a mile. An even swap should be better...not good...but better. At least then you are only paying about >$400 instead of >$600 for the "upgrade" used wheels.
  12. dorunron
    3,318
    1,105
    Houston, TX
    PriusCatMouse and frodoz737 like this.
  13. frodoz737
    4,535
    2,438
    33
    Much better in the big picture...if that's what you "want".
  14. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    And I'll throw in a "monkey wrench". You do know that the cars that came with 17" wheels have a more powerful electric power steering motor with a different ratio? Don't know if the 17s will cause faster wear on the steering system. Most don't seem to care.
    Your mileage WILL vary! ;)
  15. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    One other concern to consider is the additional loading and stress those 17 " wheels could put on your solar sunroof pkg. I've read somewhere in this form that Toyota intentionally did not offer the solar sunroof pkg on G3 Priuses with 17 " wheels due to the additional stresses. Perhaps someone can validate this. Thanks.
  16. frodoz737
    4,535
    2,438
    33
    I have not seen or heard any reports of steering system or structural failures that resulted from putting 17s on a 15" factory equipped Prius, even though the 2010-2011 US models did in fact have beefed up steering on the V's (5s). Personally I wouldn't do it, nor would I install body kits or lower the suspension for looks, but we have a member or 2 here in very high standing have that have done just that. I don't know to many people that would put in the kind of sound system I did either. PriusCatMouse, just make a good deal, have whatever new wheel/tire assemblies you install balanced, have your alignment checked after about a week or two, remember your mpg will drop and new tires will cost more. Enjoy your car and maintain it better than the factory "minimums" and you two should have a long and happy relationship. Best wishes. ;)
    frodoz737 | PriusChat View Media.
    #16 frodoz737, Apr 6, 2016
    dorunron likes this.
  17. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    All the I-Tech Gen 3s in Australia had the solar roof, sunroof AND 17" wheels (and no spare tyre :mad: ).
  18. Bay Stater
    534
    771
    Central Mass
    Thanks, that's good to know!;)
  19. PriusCatMouse
    31
    Oh thanks I didn't know this
    Good to hear about the solar not being an issue. I'll have to advise if the steering seems to give trouble but I doubt it will.
    If it does I'll have to swap tire back with my friend and he'll have a new set up Ectopia EP22s at my expense lol
  20. dorunron
    3,318
    1,105
    Houston, TX
    I don't think you will have a problem with the steering. When our Prius was new before I bought it the local supplier (Gulf States Toyota) put the wheels and tires on our Prius. I believe it came from Japan with the standard 15" Rims. You can see that the tire placard has a sticker on it reflecting the 17" tires and pressures accordingly. If you look closely at the pics I posted above Going from Prius Four, not IV because it isn't a 2010 15" wheels to 17" please help | PriusChat Item #3 Additional Items you will plainly see the tire label.
    I hope you enjoy your Prius Four as much as I enjoy our Three. I did look at a Four when I bought the Three. I went with the Three because it was more along the price range I was looking for. This is our "second Prius". First one was a Gen II Package #2 that we bought used.
    Best of luck to you and yours! (y)
    Bay Stater likes this.
