Going on a trip: Leave Prius gas tank below half OK?
Discussion in 'Gen 2 Prius Main Forum' started by daveleeprius, Nov 7, 2006.
  1. daveleeprius
    daveleeprius Heh heh heh you think so?
    429
    Seattle
    So my wife and I are going on a trip for two weeks. We'll park our 2007 Prius in our carport for two weeks. Right now, the fuel level is under half a tank and I don't want to fuel it up yet. Any idea if it is OK for the car to leave it as is for two weeks? It will keep dry where it will be parked.
    Thanks,
    Dave
  2. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Yep. That's okay.
    I'm not sure if your base model comes with smart key (SKS), but if you do have it disable it by pressing the button below your steering wheel. Have fun.
  3. daniel
    14,487
    1,518
    Spokane, WA
    It will be fine. The bladder in the gas tank prevents air from coming in contact with the gas, so there is no condensation inside the Prius "tank."
    And even the SKS (if you have it) won't mind being left on for 2 weeks. A couple of months would probably require shutting SKS off, and a month's idle sitting it would probably be safer to turn it off. But 2 weeks is no problem, though it never hurts to turn it off.
    Do be very careful, however, to make sure nothing is left on (lights, door ajar, etc.) and that the car is OFF.
  4. silentak1
    893
    28
    LA
    When you come back, recheck your air tire pressures. :)
  5. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    I just got back from a three-week trip, had tank about a third full. No problems.
  6. daveleeprius
    429
    Seattle
    Excellent, thanks all for your replies! I have been meaning to check the tire pressure anyway, I am not sure the dealer gave it to us with it at the correct pressure. It feels fine when driving it though.
    Cheers,
    Dave
  7. brandon
    brandon Member
    771
    Manhattan, KS
    Your suspicion about tire pressures may be well-founded. I have never, ever gotten my Prius back from the Toyota dealer with the correct pressures. I don't think they're aware that there's a sticker on the car that tells them exactly what the tire pressure spec is for both front and rear tires.
  8. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    The manual states that the car should not remain dormant for two weeks due to the potential draining of the hybrid battery. Someone posted that they've left their car unattended for three weeks. Is this possible? At the very least, I'd make sure my battery is at full capacity before heading off for that long.
  9. silentak1
    893
    28
    LA
    I left my car unattended for a little over a month. All I did was turn off the SKS. I didn't bother to "charge up" the hybrid battery... this was not necessary.
  10. Rest
    Rest Active Member
    1,210
    53
    CA
    Condensation causing gas tank rust is not an issue in vehicles with plastic gas tanks.
  11. ramarren
    ramarren New Member
    96
    San Francisco Bay Area, California
    <div class='quotetop'>QUOTE(SSimon @ Nov 7 2006, 11:37 AM) [snapback]345113[/snapback]</div>
    I left on September 25 for my annual trip to the UK. There was about half a tank of gas in the Prius, all I did was turn off the SKS and lock the car. When I returned on October 18, it powered up without a hitch and the main drive battery still showed 6 bars on the MFD. Tires were down about 1 psi.
    Godfrey
  12. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    <div class='quotetop'>QUOTE(SSimon @ Nov 7 2006, 01:37 PM) [snapback]345113[/snapback]</div>
    I was the one who left my Prius for three weeks. It wasn't totally undriven, though - my brother took it out a couple of times during that period. He loved it, but since his family includes a baby, they're sticking with their minivan for now...
  13. daniel
    14,487
    1,518
    Spokane, WA
    <div class='quotetop'>QUOTE(silentak1 @ Nov 7 2006, 08:04 PM) [snapback]345270[/snapback]</div>
    I did the same. Just over a month parked in the garage while I was away. The traction battery indicated the same level of charge when I returned as when I left. I think it's actually the small 12-v battery that can drain, but I had no problem with mine. Like Silent, I turned off the SKS.
