Going to the Drive-in movie theatre
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by JamesnStacey, Jun 15, 2013.
  1. JamesnStacey
    JamesnStacey Junior Member
    We just bought our Prius C last Monday and we want to celebrate by taking it to the Drive-In movies tonight. Does anyone know how often we will have to restart the car mid movie to keep the battery charged?
    tx,
    stacey
    49,490
    just leave it on and keep it in park, it will take care of itself.
  3. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Just leave the car in"Ready", in PARK and let the car do it's thing. When the battery gets low, the engine will start automatically , recharge the battery, then shut off by itself.
  4. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    I am confused about why you would need to do anything to keep the battery charged. What electricity are you using from the car? How would it be different if you went in a regular ICE car? Where are you finding a drive-in movie at all??? (Bisco has the right answer for any electrical usage.)
    [The last time I went to a drive-in movie, I saw a science fiction movie set in the year 2015, so what do I know...]
  5. bisco
    49,490
    i think you play the sound thru your radio now. there's a drive in on cape cod.:p i think my last trip was for 'it's a mad mad mad mad world'.
  6. JamesnStacey
    yes, you need to keep your radio on...thank you for the help....what about the driving lights? They need to be off???
  7. markabele
    5,084
    1,782
    Nebraska
    If it's hot out you can even run the air. Won't use too much gas at night.
  8. Fauxknight
    Fauxknight Active Member
    210
    116
    Leave it in ready mode, the normal driving mode, not one of the other modes. Bring a piece of cardboard to cover the instrument panel. Enjoy movie with radio, AC, and whatever else you want, it'll charge itself as needed, and won't use up too much gas in doing so.
  9. markabele
    5,084
    1,782
    Nebraska
    Can't you dim the instrument cluster in the c?
  10. Fauxknight
    210
    116
    The head unit can be turned off, but the dimmer for the main instrument panel only works when the headlights are on. Just bring a towel or piece of cardboard to cover it up, I assume you headlights will be off an it'll be obnoxiously bright.
    markabele likes this.
  11. bisco
    49,490
    you can't turn off the drl's? who's designing these things? don't they go to the drive in to watch godzilla?
    steveoknievo likes this.
  12. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    You can turn off the DRLs... what he said was that the instrument panel can only be dimmed when the lights are on... and if the lights are on you are blinding the people around you...
  13. bisco
    49,490
    the o/p asked in post #6.
  14. Fauxknight
    210
    116
    Then the answer is to turn them off. DRLs won't help at all, and even with the DRLs on you don't even get the night time dimming of the main panel, you have to go to normal nigh time headlight mode for that.
    So:
    1. Car in ready mode (normal driving mode).
    2. DRLs/headlights off.
    3. Head unit off.
    4. Towel or cardboard covering main console.
    The ICE will start occasionally to either warm up the coolant, if the coolant temp drops too low, or to charge the battery, if the battery gets down to the low end of 2 bars. In either situation it won't be firing up very often or for very long, and it resolves both issues at the same time whenever it does rev up.
    minkus likes this.
  15. bisco
    49,490
    you should read the post, nothing to do with the display.
  16. Fauxknight
    210
    116
    I just answered that, I'm the only one that posted between your two posts, so clearly this is directed at me. I just went out of my way to cover that question. After that, I went on to reiterate the other points made so far. Perhaps you could be more clear in how the answer is not being given, you need to be more verbose.
  17. bisco
    49,490
    just trying to help the o/p, she asked if the drl's need to be off, not sure why.
  18. Fauxknight
    210
    116
    Yep, and the first thing I said in post #14 is to turn them off.
    ztanos likes this.
  19. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    re-read my post... I answered that he could turn the DRLs off... but I added other information.
  20. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
