Goodyear Fuel Max and PSI to Max MPG
Discussion in 'Gen 2 Prius Main Forum' started by miyelani, Apr 2, 2009.
  1. miyelani
    miyelani Junior Member
    Hampstead, MD
    I'm getting the new FuelMax tires from Goodyear installed tomorrow AM to replace my integrities at 38K. I don't want to lose my overall 51 mpg I've got going...what psi would you recommend front/rear? Thanks :)
  2. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    I'm considering these tires as well, so please keep us updated on first impressions, etc.
    What psi are you running your Integrities?
    I believe the Fuel Max have a sidewall max of 51 psi. I would start by running them at 51/49. If that is too much of a jump for you, start lower and work your way up. I've been happy running my Integrities at 50/48.
    PA P
  3. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Yikes!
    50/48 - does your car still fit in the garage?
    I'm running my Goodyear Assurance's at 40/38 and I was worried.
  4. PA Prius
    754
    241
    SE Pennsylvania
    My wife did break the antenna off backing out of the garage, but she claims the garage door was not completely up.
    Even at that pressure they still wore out on the edges first.
    Miyelani, remember that rolling resistance improves 25% through the life of the tire, so your first mileage will likely not match your worn out Integreties.
    PA P
  5. miyelani
    Hampstead, MD
    So would you say to start 40/38? I have whatever the dealership puts in them every time I go in (every 5,000 miles). They definitely need a higher psi based on wear. Thanks for the input and I will definitely report back now that I know about this group!
  6. PA Prius
    754
    241
    SE Pennsylvania
    I'd suggest higher, but if that's what you feel comfortable with, sure. You can always adjust later. I use a bicycle floor pump-- readily available, no electric, and a bit of exercise. Can't beat that!
    PA P
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    Did you plus size or kept the same 185/65/15 OEM size?
    It depends on the tires. If it is softer, you need more PSI to feel like the Integrity.
  8. miyelani
    Hampstead, MD
    Well I don't want to do that! :D What is the general mpg difference w/levels of psi? Would I see a gigantic jump in mpg? Every bit counts. I'd love to see 53-55 be my average instead of 49-52, depending on the season, of course.
    If you were filling the tires, where would you start? I'm up for suggestion, I can always let air out.
    What a fabulous forum. My husband can only listen to me go on about mpg and the prius for so long and so many years!
  9. miyelani
    Hampstead, MD
    I ordered the 185/65/15 as I worried about losing mpg if getting a larger tire.
  10. spitinuri
    spitinuri Member
    317
    Many people here run pressures 10-20 psi over the recommended tire pressure. The folks who are truly hypermilers run pressure significantly higher (as far as I can tell). You can get better mileage by running higher pressures. How much? I run 52/50 psi front and rear and probably get 1-2 mpg better. I don't know if that is about average or not. I'm fairly new to the car (November purchase) but am able to get 55-60 mpg highway with no or light wind and temps > 60 F.
    As you know tires have a recommended pressure for a couple of reasons. The main reason is handling. The tire performs best at the recommended pressure. The second is that your ride will be harsher with higher pressures. Tires may also wear more unevenly with higher pressure (although I think you really have to put some high pressures for that). The only real upside to higher psi is mpg. That's why I do it.
    Personally I think it fun seeing just how much you can get out of this car.
    There is plenty of information on this site on what people do to get better gas mileage. Tires are just one part. The oil you use. How you drive. Using a scan-guage. All of these can help you achieve your goal.
    2 people like this.
  11. miyelani
    Hampstead, MD
    I drove from Baltimore area to Central NJ--about a 200 mile haul-- last night w/o any change to tire pressure (whatever Mr. Tire would put the tires to--standard Pruis setting). Going 65-75 mph, I got 54 mpg. Never have I gotten that high on this trip--usually it is right around 51 w/OEM integrities at suggested psi. I'm very interested to experiment with other things to increase mpg. These tires definitely made a huge mpg difference for me.
  12. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    As you may know, Goodyear reports that the Assurance Fuel Max should get around 4% more mpgs than the regular Assurance on the highway. All other things being equal (psi, degree of treadwear, etc.), in the long run, I wouldn't expect that you would get more than 4% better highway mileage than you did on the Integrities.
    If there's a "standard" psi among PriusChatters who inflate their tires more than what's recommended on the door, I think it would be 42 front/40 rear.
  13. PA Prius
    754
    241
    SE Pennsylvania
    I wrote to Goodyear's Customer Service this week and got this response--
    There currently are no such standards and labels on tires. Legislation is
    being considered to create a type of rating system for rolling resistance
    or fuel efficiency of tires, with rating results provided at point-of-sale
    in retail outlets, but not on the tire itself. The legislation would also
    require an element of consumer education on proper tire care. But many
    questions remain unanswered. Studies show that many varying conditions – no
    matter the tire type – affect fuel efficiency. These include type of
    vehicle, road surface, vehicle load, temperatures, tire inflation pressure
    and more. Also, legislators are concerned that reductions in tread
    thickness, volume and mass are among the means available to reduce rolling
    resistance, yet those qualities would likely be undesirable if they lead to
    shorter tire lives and increased numbers of scrap tires.
    The Integrity tire in your original equipment size is the lowest rolling
    resistance tire we make for your vehicle​
    I wrote back asking if I am understanding this correct that the Integrity has a lower rolling resistance than the Fuel Max. I haven't heard back from them. I wonder at times about the reliability of Customer Service info. Michelin gave me the run around as well as I've recorded in another thread.
    The lack of concrete RR info is frustrating, but it would at least be helpful if manufactuers could supply a list of their products in order of RR.
    PA P
  14. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I run 40/38 and still see above EPA on non-integrity tires. W/ integrity tires, I ran 42/40 and averaged in the low 50's. At some point there was a handling trade off w/ my current tires (a corner I normally took at a certain speed caused the car to get rather squirrely until I dropped 2psi).
  15. drees
    drees Senior Member
    1,782
    247
    Sorry, main reason isn't handling. It's well known in the racing world (autocross or track events) that you will normally be running 4-6 psi or more above what the recommended pressures are.
    Like most things in a mass manufactured automobile, things are built to a compromise to satisfy as many people as possible. This means that recommended tire pressures are chosen the same way - basically the pressure that achieves a good balance of performance, fuel economy and ride quality.
  16. PA Prius
    754
    241
    SE Pennsylvania
    I got a response from Goodyear this morning, saying that it is correct that the Integrity has a lower rolling resistance than the Fuel Max. Grrrrrrr! Just when I had thought I had made up my mind. My hope was/is for an Integrity replacement that would improve my mileage without going to the short treadlife of the Bridgestone Ecopia or Michelin EnergySaver.
    PA P
  17. PA Prius
    754
    241
    SE Pennsylvania
    The tire search drama continues--
    I called my local Goodyear dealer and asked what they'd recommend for an Integrity replacement if I don't want to lose any mpg. He said the Integrity is the lowest rolling resistance tire Goodyear makes. I then asked about the Assurance Fuel Max. He came back a minute later and said the Fuel Max would be better....
    In spite of this conflicting info from Goodyear customer service and dealer I am again leaning towards the Fuel Max. With the 51 psi sidewall max I'm thinking I can bump my current 50/48 up a few psi which should help a bit. I like the 65,000 mile warranty on the Fuel Max over the Integrity. I like the HydroEdge, but don't want the mpg hit or the road noise. Anything I'm missing?
    PA P
  18. miyelani
    Hampstead, MD
    I still haven't had a chance to up my psi, thank you for all the input on that, plan on doing that this weekend. I have not been able to keep up the 54 mpg, not sure how I did that on such a long trip, especially in the rain...maybe a tailwind! I've been averaging just shy of 52 since I got the tire, overall, so slightly better than my integrity tires at 39k miles. Less than 1 mpg gained, but something is better than nothing. Still early, as I haven't even hit 600 miles w/these tires. At least it isn't worse, which is what steered me away from many other tires.
  19. Torien
    Torien New Member
    What do you guys think of filling the tires with Nitrogen instead of standard air? Has anyone had experience with Nitrogen in their tires?
  20. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    Air is 78% nitrogen, 21% oxygen, ~1% argon, and small amounts of CO2 and other trace gases. Oxygen and argon are lighter/smaller than the N3 molecule. If all the non-nitrogen parts leaked out, you'd lose some pressure. However, when you top up, 78% of what you add is also nitrogen, making the new mix 95.16% nitrogen. A second round makes it 98.9% nitrogen. With the tyre acting as a filter, the amount of gases other than nitrogen is ever decreasing. That's if the hypothesis that the structure of the tyre is permeable to oxygen molecules, but not nitrogen molecules, is correct.
    Even if the proportion of leakage were not 100/0, you'd still get an increasing amount of nitrogen in total every time you inflated the tyres.
    According to this WikiAnswers answer, oxygen molecules are about 3% smaller than nitrogen. Given that tyres are designed to be inflated with air, I would expect that the low-permeability liner is designed to hold back both nitrogen and oxygen.
    I can't say that I notice great drops in pressure that could be explained by losing the oxygen and not the nitrogen.
