Got a Hybrid2Go Lifetime warranty battery/ Dr. Prius Screenshots
Discussion in 'Gen 2 Prius Main Forum' started by mwbrown25, Oct 11, 2022.
  1. mwbrown25
    mwbrown25 Junior Member
    So. Cal
    Got a lifetime warranty Hybrid2Go battery installed this morning. Customer service and mobile tech were great, on time, friendly etc) Hooked up Dr, Prius APP as soon as the tech left and went thru the drill.. Cell #2 and #3 look way off from eachother. 1 pic was from this morning, and the other from this evening after driving all over town. Whats your thoughts? im not well versed in all this hybrid tech? No dash lights are on.
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Call them up and tell them the pack they installed has a corroded voltage sensor harness and it's giving faulty readings and it's likely going to fry the Hybrid battery ECU and leave you broken down on the side of the word unless they install a pack that's actually functioning correctly.
    They'll know what you're talking about. This is one of the most common problems with older rebuilt battery packs. The modules/batteries they rebuilt are probably fine. But they cut corners on taking time to clean corrosion out of the Hybrid Battery ECU and failed to replace the voltage sensor harness with brand new. In the meantime it's safe to drive as long as you have your Dr. Prius app with you to clear the error codes and you don't go too far from home.
    Prius Rising and mwbrown25 like this.
  3. mwbrown25
    So. Cal
    Thanks I shared the dr. Prius screenshot with hybrid2go and they advised me to keep driving it and maybe they'll balance out.
  4. Tombukt2
    Tombukt2 Senior Member
    12,221
    2,157
    Durham NC
    My question always is what is lifetime exactly nada.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,967
    1,915
    NJ-USA
    Wow. What "customer service" BS. There's an open circuit in the voltage sensing harness. Period. Between the block 2-3 connection and the ecu. It ain't going to "balance itself out".
    Tombukt2 likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    That's the funniest thing I've ever heard. You're apparently dealing with idiots or fraudsters. That indication you have is a component failure, whether it be the sensing wires or the ecu pins or the ecu itself. There is NO "balancing" in the universe that is going to solve that.
    This is one reason why I went to using brand new Toyota wire harnesses for all my builds. Much easier to just pull a new harness out of its bag than to deal with all the hassles of an old, usually corroded original.
  7. mwbrown25
    So. Cal
    I contacted Hybrid2Go this morning and they are going to install a different battery pack tomorrow. Thanks for your help and everyone's responses. Hope this company pans out and I can get some years out of this car and HV battery. Before I chose hybrid2go to do the battery I asked around this forum and they seemed to have a good reputation around here. I may post a review of the company and follow it up with updates as to how the pack is holding up and my mileage for any others that may be considering a $1400 pack replacement with a warranty.
  8. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Holy Jezzus....$1400???
  9. mwbrown25
    So. Cal
    I know right! 18 year old cars shouldn't be worth that much but my wife is driving the Tundra 4x4 to work every day costing us an extra $100 per week so it'll pay for itself quickly $1400 with tax installed. Pricey but not any better options here in Southern California. My first choice was a NEW OEM battery, price from Toyota was only $1800 otd but the closest dealer that had one in stock was a 14 hour Roundtrip drive and I would have swapped it in there parking lot to return the core.
    #9 mwbrown25, Oct 12, 2022
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Did you get that warranty in writing ?
    Have you actually read ALL of it ??
    Your first experience isn't really encouraging.
  11. mwbrown25
    So. Cal
    Straight from there website. I have a basic invoice for the repair.
    Warranty Request Terms
    For warranty assistance please call Hybrid2go warranty support at (805) 235-5083
    Warranty claims must be supported by diagnostic trouble codes. These codes must be
    obtained with a code scanner. If you choose to use an auto repair facility to scan your
    codes Hybrid2Go is not responsible and will not reimburse any expenses, fees or charges
    related to such a service. Most auto parts stores will provide code scanning services at no
    cost. Hybrid2Go recommends you have your codes scanned for free at your local auto
    parts retailer. Photos of codes must be provided for warranty requests.
    Once you have the trouble codes read by an auto parts store (etc):
    1. Take a picture of the scanned codes and submit photo(s) to Hybrid2Go.
    2. If you have the vehicle diagnosed the following information must be provided
      by the repair shop or dealership:
      ● Diagnostic trouble codes for the Hybrid Control ECU
      ● Diagnostic trouble codes for the Engine Control ECU
      ● Diagnostic trouble codes for the Hybrid Battery ECU
    The service of scanning vehicles for codes can be obtained for free as described above at
    most major auto parts retail stores. Hybrid2Go does not pay for any diagnostic costs or
    fees charged to you by any repair facility to scan your vehicle for codes.
    Warranty will be made null and void if the battery is removed, a repair is attempted, or
    reinstalled by any outside repair facility, licensed contractor, or individual who is not a
    Hybrid2Go employee.
    If the battery is found to be defective in workmanship, installation, or material by
    Hybrid2Go we will replace the hybrid battery free of charge. Once the vehicle has been
    diagnosed with a hybrid battery failure and we review the diagnostic information to
    confirm the failure.
    Warranty becomes null and void if the vehicle is totaled in an accident or otherwise
    written-off. Fire, flooding or other damaging incidents in which the battery’s
    environment is compromised. Vehicle conditions may cause early failure.
    Warranty is NOT transferable to any other vehicle except where required by law. This
    means the warranty only applies to the purchased battery in the original vehicle. This
    warranty becomes null and void if you install the battery in a different vehicle other than
    Warranty will be excluded if any of the following items are found:
    -Batteries installed in vehicles that are stored for a period of thirty (30) days or more.
    -Any removal, tampering, or damage to the hybrid battery.
    -Any installations conducted by individuals or businesses that are not Hybrid2Go
    installers.
    -Your dead battery is required by us to complete the service.
    -Any modification or bypass of vehicle systems not in congruence with manufacturer
    specifications
    -There will be no refunds for installed batteries.
    -We do not service any vehicles outside of California, Washington, Oregon, and Arizona.
    -Improper vehicle maintenance – including engine failure to start or poor engine power
    conditions which discharge the hybrid battery due to the engine failing to start or
    properly run.
    -If you’re an auto shop the warranty needs to be put in the customers name and not the
    Auto shop – failure to do so will void the warranty.
    -If you’re a dealership the warranty needs to be put into the name of the buyer upon sale
    otherwise the warranty will become void.
  12. PriusCamper
    12,064
    4,896
    That's a fairly standard rate for rebuilt packs with a lifetime warranty...
  13. bisco
    51,157
    This is the first bad thing I have heard about hybrid two go, but at least they made good on it
  14. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    This, you'll find in the warranty of any company building batteries that they know may be a POS. They're worried about modules with self discharge problems that become "coded" modules due to staying inactive for a bit. Stored means 'not used'. Let it sit in the driveway for 30 days because you broke your leg? Finally heal up, go to start the car and it codes? Warranty void if they can prove it sat for 30 days.
    The last "used" battery I built with Gen 2 modules sat on a shelf in my shop for 15 months, waiting to be used in case of crisis. Every module was still 7.5 plus or minus 0.1 volts. No joke. 15 months sitting on a shelf.
  15. sam spade 2
    7,035
    2,799
    2017 Prius c
    As I suspected, a lot of if's and but's. Some reasonable and some not.
    I don't see any mention of the length of the warranty.
    AND without a printed and signed copy of a warranty document.........if they take down that web site, your "warranty" might die right along with it.
  16. mwbrown25
    So. Cal
    Hybrid2go followed thru and replaced the faulty battery this morning. Once again they were on-time and friendly. The mobile service is super convenient. haven't had the time to take the car anywhere or go thru all the tests on Dr. Prius but i'll report back. Hope there able to make an ok profit at $1299 and stick around for years to come/support there lifetime warranty. Time will tell.
  17. rjparker
    rjparker Tu Humilde Sirviente
    9,600
    5,898
    Texas Hill Country
    Given their first used battery lasted two days I doubt you will be happy long term. Few are when they buy used. Often the warranty becomes harder and harder to enforce.
  18. mwbrown25
    So. Cal
    Sorry to say it but hope your wrong lol. in my situation this was the best option at the time. I actually sent the tech a screenshot of the bad battery blade voltages about 3 min after he pulled out of my driveway. He never responded but had no other Gen2 batts anyhow. I'll keep this post updated or maybe start a new thread on the battery's reliability or any issues that arise with hybrid 2 go for anyone else considering a "lifetime warranty" battery replacement.
  19. PriusCamper
    12,064
    4,896
    Yep... Lifetime warranty from this operation, as well as Green Bean and others is a pretty reasonable solution / business model... I bet most people move on to brand new pack around the 5th battery swap...
  20. richard203
    richard203 Member
    205
    45
    SF
    i got green bean battery and it still going strong after 2 years almost 3 years and it still on the first battery they installed.
