Got answer to why Remote A/C sometimes does not work.
Discussion in 'Prime Audio, Electronics, and Infotainment' started by chenderson2, Jun 1, 2018.
  1. chenderson2
    chenderson2 Member
    94
    57
    Houston
    You won't like it, but it seems to explain what is happening.
    The battery has to have at least 3/4 charge before it will work.
    Of course, as I told the Toyota tech that informed me of this fact, that makes it almost useless, as if a person drives over 5 miles from the last charge the battery will probably have less than 3/4 charge.
    49,490
    kinda surprising, considering pip has it with less than half the battery. you'd think the charge threshold would be lower.
  3. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    I would have bet anything that I've used it will less than 3/4 charge before...
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Ask 'em to show you in writing. A limitation like this should also be in the owners manual.
    I had remote A/C in my Gen 3, which has a tiny battery in comparison to any plug-in, and didn't have this limitation.
  5. Insighter
    Insighter Active Member
    409
    285
    SoCal
    I know I've used it with less than 3/4 charge. I remember reading something a few months ago about it not working if the doors or unlocked and maybe under some other conditions.
  6. breakfast
    breakfast Active Member
    266
    199
    Page 510 of the manual says...
  7. bisco
    49,490
    wow, they have a sensor on the hood now? is there an engine bay light?
  8. breakfast
    266
    199
    I'm guessing they don't want a Prime to run the heat pump unattended with the hood open - nothing to do with an engine bay light (I don't think there is one)
    Why stop there? There's a sensor on the fuel filler door and the charging port cover too, even on the base (Plus) model where the charging port cover doesn't lock (and there is an LED "flashlight" in the charging port area, by the way)...
  9. bisco
    49,490
    yes, pip has those too, but no hood open detector. i guess they don't want you driving with the port open, but the hood up is okay.:cool:
  10. chenderson2
    chenderson2 Member
    94
    57
    Houston
    Since writing this post, I have been able to run the A/C with much less than 3/4 charge, so Toyota was wrong.
  11. bisco
    49,490
    or at least the a$$clown working at the dealership.:cool:
  12. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    I got it to turn on from the remote with less than 1/4 charge as well.
