Got my Prius Hood
Discussion in 'Gen 2 Prius Main Forum' started by bhaynnes, Oct 13, 2006.
  1. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    Woot! I got my Prius hood and my prescription sunglasses came (to be stashed in the sun glasses storage area), now you can be faily certain the sun will never shine again in the San Fran Bay Area.
  2. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    One of my favorite add-ons is the power outlet connector- to make the front (formerly called cigarete lighter outlet) outlet always on- coastaletech.com - costs about $10. That way my cell phone can be charging even if the car is off.
  3. xbdude
    xbdude opticat
    168
    North Central Florida
    Is the power outlet connector an easy installation??
  4. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(xbdude @ Oct 13 2006, 02:42 PM) [snapback]332493[/snapback]</div>
    Here's the instructions. As you can see you can even use your own parts.
  5. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(bhaynnes @ Oct 13 2006, 10:53 AM) [snapback]332364[/snapback]</div>
    When I got my Prius hood certified I was notified that I qualified for..... Man hood!
    2nd part doesn't matter as it never rains in Southern California.
    Woot? That's a great exclamation!
  6. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <_< Caution... Quote: " One of my favorite add-ons is the power outlet connector- to make the front (formerly called cigarete lighter outlet) outlet always on- coastaletech.com - costs about $10. That way my cell phone can be charging even if the car is off. "
    With the Prius power OFF and that 12v auxiliary outlet enabled, your very small 12v battery has been reported run down by a device (like a cellphone) connected, forgotten and left on or charging. When the 12v auxiliary battery is run down, you can't start the Prius until you recharge it so it can close the main relay to connect the big traction battery.
