Got my wheels and snows :)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by alexilic, Jan 14, 2010.
  1. alexilic
    alexilic Member
    120
    Wauconda, IL
    I got my snow tires!! I ended up going with 15" rims, and general altimax snow tires.. all for under $600 delivered to my door :) Here are a couple of pics...
    Couple of observations. First, not enough snow on the roads, but the little I did find, the tires had great traction. Second, the "feel" is looser. Maybe it's the higher profile of the 15"s over the my tourings stock 16"s?? Could be the narrower width? It's not enough to make a difference on my daily drive, but when the winds pick up or I hit the on/off ramps hot, I notice they wander more?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    What is your location? I can see a front plate, so it's not Michigan.
    Tom
  3. alexilic
    alexilic Member
    120
    Wauconda, IL
    Northern Illinois :welcome:
    Alex
  4. a_gray_prius
    2,927
    783
    IL
    They might also feel "looser" because the rubber compound in snow tires is typically softer than that of summer and all/no season tires.
  5. alexilic
    alexilic Member
    120
    Wauconda, IL
    I'm sure it has something to do with it. It doesn't bother me and nothing a few hundred miles of driving to get used to the new feel. I'm hoping for some good snow so I can try them out!!
  6. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    Hey there neighbor, I'm just down the road from you in Mundelein.
    Car looks great! Very nice!
  7. alexilic
    alexilic Member
    120
    Wauconda, IL
    Thanks 007!! Wish I would of know you before, we had a block heater install at my house this past fall. Wayne and about 20+ people showed up.. it was good times even tho it was cold(relatively!)
    See you around,
    Alex
  8. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    Nice. Winter tires make a big difference in handling on snow & ice. You're actually able to leave your house LOL.
    Yeah, winter tires have a softer compound, that is normal for the car to feel a little sloppy on dry pavement.
