Got oil change, now A/C fan is making noise?!?!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ddiamondd, Jul 23, 2014.
  1. ddiamondd
    ddiamondd Junior Member
    34
    Colorado
    So, first things first, I hate going to dealerships. But the local one has a 3 oil change/tire rotation special for $150, so I couldn't say no. Anyway, I brought it there just a few hours ago, and before I paid, he said my air and cabin filters needed replacing. He showed them to me, and I agreed, but said I would do it myself (they wanted almost $80!). So I leave the dealer on the way to advance auto parts, and go to put the A/C on. I crank it up, as I usually do, and now there is a somewhat loud humming noise that is accompanying the usual air blowing sound. This only really is audible at the top of the fan speed range. Mid and low seem to be ok, but its still kind of there. Never heard this before, and I don't know what it is or why it happened. I replaced both the engine and cabin air filters, and its still there. Kind if sounds like its in the glove box area, but its hard to pinpoint. Has anyone else experienced this? Should I be worried? I need an alignment anyway, but am hesitant to complain to the dealer if its not their fault. Any info will be much appreciated!
  2. JC91006
    16,673
    8,518
    There is probably a leaf that fell into the blower fan while the Tech was checking your cabin air filter. Take your cabin filter out and see if you can find debris in the blower. This is the area right under the cabin air filter.
    spiderman and ddiamondd like this.
  3. ddiamondd
    34
    Colorado
    You, my friend, are a genius! I was looking around that area when replacing the filter, but didn't know what to look for, or if my hand could fit. It barely did, but there was a myriad of leaves and sticks. Seems to be fixed now! Thanks so much. I love this forum!
    51,155
    i would hesitate to let them change my oil or rotate my tyres.:eek:
    hybridbear likes this.
  5. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    BTDT, only my blower vibration was of the tear itself out of the dash magnitude after the oil change / inspection service.
    We turned around and headed right back to the dealership to see if they knew what was up. The shop forman said"yeah, thats pretty common." He called the tec that did the oil change / inspection. The young guy immediatly pulled the cabin filter part way out, where he said" ooh, you have a mouse problem".
    I had been feeding the farm cat in the garage, and a little mouse had stacked a couple teaspoons of dry cat food stars on top of the cabin filter for next winter. When the tec pulled the filter partly out during his inspection, some of the cat food dropped into the blower wheel. I am sure he would not be paid for the extra 1/2 hour or more it would take him to vacuum all that out of the blower wheel, so he just slid the filter back in there and said nothing, hoping nothing would vibrate and no one would notice.
    I realized this was my fault for having an open dish of cat food in the garage near the car,so I took the car home and cobbled up a small 90 degree elbow tubing adapter for my shop vac hose and spent the next half hour with shop vac, flashlight and mirror, sucking out the cat food.. I quit feeding the cat in the garage and have had no more junk on the filter problems(3 years) :)
    #5 Jon Hagen, Jul 23, 2014
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You couldn't... why? That is pricey if you ask me.
  7. qdllc
    qdllc Senior Member
    1,371
    399
    I'd be rather upset if I paid for one thing and the mechanic ventured into a part of my car he was not paid to touch.
    How would he know the state of your filters from doing an oil change and tire rotation?
  8. JC91006
    16,673
    8,518
    This usually happens in the form of free 40 point inspections. They find issues to fix for you.
  9. ddiamondd
    34
    Colorado
    I can't stand dealers, but the people here have been very helpful, aside from this. But the problem is fixed, lets hope I don't run into other issues...
    Really? I think $50 each for synthetic oil change, tire rotation, and mutli point inspection is a decent price. Especially when you factor in the convenience.
    It was part of the "multi point inspection". They check the air and cabin filters, lights, brakes, fluids, and so on. Glad they did too. Especially the cabin filter. Aside from the junk that fell into the fan, which was easy enough to remove.
  10. MattPersman
    MattPersman Member
    110
    33
    Indiana
    Yes that's a good price, my dealer charges 69.xx for just the oil change
