Got our stickers today, and our spare tire fits nicely...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jon H, Apr 28, 2013.
  1. Jon H
    Jon H New Member
    Northern California
    Stickers finally came after exactly a month, received two days after they cashed our check. I wasn't too thrilled about having to be towed somewhere in case of a flat tire, and the mess the flat tire system would make, so I bought a space saver spare (2010 Corolla) from the local Toyota parts recycler for $35, a cover off eBay for $10, and a set of steel rim lug nuts. This way if we get a flat, I change it, or if she's driving, call AAA to put the tire on and were off. I was glad to know there is a full jack and tool kit under the driver seat, you access it from behind.
    F8L likes this.
    51,155
    congrats! what stickers? i like the idea of the cover, can you give us a link? why the extra lugnuts? thanks, all the best!(y)
  3. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Guess he is talking about the HOV stickers.
    51,155
    ah! thank you.
  5. Jon H
    Jon H New Member
    Northern California
    Yes, HOV stickers, my bad. Here's a link to the cover, I bought the same cover when I bought a spare for my 2007 BMW 328i and converted it from run-flats to regular tires for a significantly smoother ride. This cover is a nylon fine mesh with a draw string that fits and looks great.
    The reason I bought the extra lug nuts is that aluminum mag wheel lug nuts are longer and center the wheel from the circumference of the lug nut and the tightening pressure is centered on the washer near where you put wrench. Steel wheel lug nuts are tapered and all the pressure is on the face of the nut that contacts the rim. The steel wheel nuts are designed for this. Using the stock aluminum mag lug nuts in this manner might work, but increases the odds of damaging the threads. And for what it's worth I'm a retired (2010) Master Technician that spent over 20 years with Toyota/ Lexus.
    Spare Tire Cover 24 5" 26" New Plain Safari Tracker Black | eBay
    Dorman Wheel Nut/Wheel Nut (611-062.1) | AutoZone.com
  6. Vijay C
    Vijay C Junior Member
    Southern California
    Just curious, how did you secure this spare tire in the open space in the back? Hope you didn't loose much room by having this hanging around all the time ? I guess, it is worth it, considering the peace of mind it brings along.
    Can you post the picture, of this secured spare tire, when you have an opportunity ? Cheers
  7. Jon H
    Jon H New Member
    Northern California
    Here is a better picture, it's not secure, and it's not going to be.
    Vijay C likes this.
  8. bisco
    51,155
    thanks jon! do you know if the hatchback comes with extra lugnuts if the car has mags, or does toyota just figure any port in a storm?
  9. Jon H
    Jon H New Member
    Northern California
    You know, I'm not sure about that, sometimes I call things as I see them...
  10. bisco
    51,155
    10-4. i may just pick some up at autozone, better safe than sorry, that's why i got the spare!:)
  11. Jon H
    Jon H New Member
    Northern California
    I put the lug nuts in a bag with a large trash bag included so we can put the damaged tire in a bag first, before putting it in the trunk, a rim and tire that comes off the road is very dirty, and will make a huge mess of the trunk area, and I'm talking grime, not just dirt. I got this idea from I believe it was Audi or Land Rover.
  12. bisco
    51,155
    good plan, thanks!
  13. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . Jon H: you can build a shelf directly over the spare. = 2X storage.
  14. Andyprius1
    2,327
    859
    Cool CA
    . Also try the jack out first, that is: put the doughnut/ spare on and test out the jack.
  15. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Jon,
    Thanks for the tip about the lug nuts. I just tried my donut spare on once when I got it, using the regular lug nuts and figured all was good. So now I will buy some tapered steel ones. Thanks for the link also.
    Now to the scary part: I don't like the idea of that heavy tire&wheel free to fly around the car in the event of a serious accident. I have it strapped down to the rings with the adjustable strap provided by Toyota for tying down a road wheel in case of a flat. (Doesn't make much sense that they would include the strap since the PiP doesn't have a spare.):rolleyes:
    F8L likes this.
  16. Andyprius1
    2,327
    859
    Cool CA
    I would not worry about it, the strap is secure, right? If you build a shelf with the Doughnut tire below, you hide the tire, it can't fly around if it gets loose, no Sun gets to the tire and now you have twice as much room.
  17. rogerv
    1,639
    317
    But what is the shelf fastened to so that it won't come loose? As for the room, I place grocery bags around and on top of the spare, and when I'm not carrying anything else back there, I pull the cover over the cargo area. But Jon was saying he wasn't securing the spare tire, and that is what I was questioning in my post. And yes, I do figure the strap is secure, or at least better than nothing.
  18. Andyprius1
    2,327
    859
    Cool CA
    . The shelf fits all of The space horizontally, so it cannot go anywhere. I made it so it is relatively flush to the walls and The rear seat back.
  19. Vijay C
    Southern California
    Thanks for sharing the picture. Not sure, like others quoted, how to stop this guy floating around causing secondary collisions with the occupants in the Pip.
    I guess, this is one step better than nothing...
  20. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Congrats. Enjoy the Diamond lane
