Got quote on charger installation
Discussion in 'Nissan/Infiniti Hybrids and EVs' started by rcbookie, Aug 13, 2010.
  1. rcbookie
    rcbookie Junior Member
    anaheim
    I got my quote for installing the charger and I think it's high $1969.
    Has anyone else gotten their bids?:(
    I have a 220 circuit in but they said that it needs to be 8 gage they should be able to just pull new wire through the existing box and change the breaker form 30 to 40 amp
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    If you do most of the preliminary work yourself, mount the box, run conduit, pull the wire, and just leave them job of connecting the wire, you should cut that amount down by $1500!!
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the wire and plugs are not exactly cheap. the electrician is getting paid 45 to 65 and hour. people tend to bump the price when they are playing with wire inside the main box.
    how far is the wire run from your box to your outlet?
    if the run is only 10 ft or so, i would assume you would get charged between 1500 and just about what they quoted you. i'm sure i'm overlooking a few things without seeing the job.
  4. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    That is actually better than what they are quoting to others. No doubt you can do much better by buying the EVSE and getting it installed yourself. Checkout mynissanleaf.com for threads on this ...
  5. hill
    8,187
    You would think. We had a long run of number 8 that I shortened to end right where the charger will go ... only 4 feet from the main panel, inside our garage. I installed a 40 amp breaker ... had a 2 1/2 foot square of 3/4" plywood to mount the docking station on already installed ... got the AV estimate and guess what ... STILL TWO grand. The AV charger isn't even designed to be outdoors!
    :pound:
