got some young 2012 modules
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Apr 10, 2014.
  1. scotman27
    scotman27 Active Member
    735
    81
    PA
    2001 Prius
    Hi everyone:
    Its been awhile but I wanted to let you know that the battery repair on my 01 prius is still very good and all voltages are within .1 to.3v from highest to lowest.
    I on ebay stumbled across a 7800mile pack of 28 from a 2012 prius v that was hit upfront and totalled. and had another seller that could send me 10 2012 modules that had 9000 miles on them from a prius c that was hit and totalled.
    i got them both shipped for 1350 which i think is a good deal if they check out. i just got the 10 today and all date codes point to 2012 and voltages are 7.58.
    so my question is what should i do to check the modules for capacity and strength before I go tearing into my pack? or should I just put the pack in parallel and charge to 8.1 and stick it in the car.
    this testing will let me know if I got scammed, which if i did i could file a claim through ebay but i got to get this testing done within a month.
    I got a mrc super brain 977 r/c charger i could do 2 cycles of discharge/charge up to 5amps on each module to get capacity but i want to ask before i just do.
    So this question is out here in the forums to get some feedback and some help.
    let me know what i should do,
    thank you
    scott
  2. bwilson4web
    15,512
    GOOD! This means you aren't under a time-gun to get things ready. In GOOD, FAST, CHEAP, pick two, you can get GOOD and CHEAP.
    Sounds good. But understand your buying the modules, not the capacity. The actual module capacity is going to be a function of the prior usage and there are no guarantees. But the good news is:
    • later modules have lower internal resistance - lower heating during operation
    • much improved terminal seals - they are better able to handle heat and pressure, less likely to leak like the original NiMH modules
    Ok, if you choose fast, the process:
    • parallel charge to get them as close to the same SOC (State of Charge)
    • consider a timed, discharge, "n" identical load resistors (see Radio Shack or eBay)
      • 1/4W, 256 ohm or higher, one resistor per module, 0.031A initial rate (32 hr ~= 1Ahr)
      • 1/2W, 128 ohm or higher, " " ", 0.063A initial rate (15 hr ~= 1 Ahr)
      • 1W, 64 ohm or higher, " " ", 0.125A initial rate (8 hr ~= 1 Ahr) (*)
    The protocol is to use parallel charging to bring all of the modules to same voltage. Prepare the resistors, one per module, with hookup wire to connect to the modules and have them ready to go. Make sure the resistors are as close to the same values as possible. If any are low or high, put them aside and get a closely matched set. The following has to be done WITHOUT INTERRUPTION:
    1. Isolate the modules after parallel charge
    2. Put a load resistor on each module.
    3. Start monitoring the voltage as they discharge
    4. After an hour or no more than the 1 Ahr limit or when one module reaches ~7.5V, remove the load resistors from all modules
    Let them 'rest' and measure the partially discharged voltages. This gives a relative strength of each module so you can pair the strongest and weakest.
    The Super Brain can give you metrics, numbers, to use for a module but doing all 38 is going to take time. The procedure I outlined before allows a 'parallel' metric to support pairing of the strong and weak modules. Only you can determine if there is enough time to test all modules:
    • discharge to 6V
    • charge (record this Ahr)
    For the faster procedure, it makes sense to take one or more weakest modules and use the Super Brain to get quantitive numbers for worst-case, Ahr capacity. Two or three would give a good average. Doing the same for two or three of the strongest modules would also give a range. BUT this is not necessary for your purposes.
    Use the earlier procedure to balance charge all the modules and then assemble a pack with weak-strong modules paired together. I would probably pay for a fresh set of buss bars since the earlier ones probably have some trace KOH from the old modules. But I'm not hard on this if the old ones are throughly cleaned and the delicate sense wires checked. Also, I understand the cover may need some 'metal adjustments' to handle the slightly larger modules.
    The 30 day schedule pretty well negates the opportunity to individually measure each module with the Super Brain. It would take time to do all 38, probably measured in weeks. It would be the best way and give good Ahr capacity readings. But the procedure I've outlined is fairly safe, fast, and the matched load resistors a reasonable approach.
    * - Resistors are also identified also by precision. Cheaper ones have more variability and more expensive ones, higher precision. If buying cheaper ones, get some extras so you can manually match them. More expensive ones, fewer extras are needed to match. As for the hook-up wire, I am partial to a stripped, tinned lead on both ends that are 'hard to bend' and sized to really make a tight connection. You don't want the terminal-to-wire junction to be an unplanned resistor. A quick touch test after all are on can identify the 'loose' connections.
  3. Patrick Wong
    18,200
    6,472
    I don't know the Prius c, and hope that the traction battery modules are the same as Prius v. Good luck.
    Please take photos and post if you should find any differences.
  4. scotman27
    735
    81
    PA
    2001 Prius
    will do patrick. i believe they are the same. but im not sure.
    they better not be different, ill be upset for sure
  5. scotman27
    735
    81
    PA
    2001 Prius
    Do you by chance have a part number for those resistors?
  6. scotman27
    735
    81
    PA
    2001 Prius
    i found a 1w .64 ohm resistor
  7. scotman27
    735
    81
    PA
    2001 Prius
    also a 1w 62k ohm resistor
  8. scotman27
    735
    81
    PA
    2001 Prius
    and 1w-68ohm 2% resistors in a 10 pack
  9. scotman27
    735
    81
    PA
    2001 Prius
    the only 1w resistors in stock at my location are the 10 ohm 1w 5% metal oxide resistors and 100 ohm 1 w 5% metal oxide resistors and 1k ohm 1w 5% metal oxide resistors.
  10. Patrick Wong
    18,200
    6,472
  11. scotman27
    735
    81
    PA
    2001 Prius
    hey i just thought of something, what about the taillight bulb test I did when i rebuilt my pack? would that work, i believe i did 10 modules at a time.
  12. scotman27
    735
    81
    PA
    2001 Prius
    im thinking about the 100 ohm 1w 5% resistors. if not, i can do the taillight bulbs. i know i can snag a couple more bulbs out of my truck, theres at least 4 more in there, if i can get 19 bulbs i can do the pack in halfs.
  13. Patrick Wong
    18,200
    6,472
    The problem with the use of light bulbs is that the resistance of the light is highly variable depending upon how hot the filament gets. So you will not have very precise control over the discharge rate.
    The 100 ohm 1W resistors are OK, but it will take longer to discharge a module compared to the 64 ohm 1W resistors suggested by Bob.
  14. scotman27
    735
    81
    PA
    2001 Prius
    How much longer do you think it would take?
  15. scotman27
    735
    81
    PA
    2001 Prius
    i can also get 1k ohm 1w resistors readily available at my location as well.
  16. scotman27
    735
    81
    PA
    2001 Prius
    i want to try to avoid ordering online if i can help it.
  17. scotman27
    735
    81
    PA
    2001 Prius
    the reason being is I want to get the testing done as soon as I can so if there is anything wrong with the modules i can get it taken care of through ebay.
  18. Patrick Wong
    18,200
    6,472
    1K ohm resistors will take much longer.
    Use the 100 ohm, 1W resistors, then. You should probably buy 70 of them or more and use a digital multimeter's ohmmeter function to select the 38 that are closest to each other.
    The 100 ohm resistor will result in 0.08A discharge rate, therefore 12.5 hours required to discharge ~1 Ah.
  19. bwilson4web
    15,512
    Patrick is correct. Use the 100 ohm resistors but measure them first so we can adjust for any differences. Your initial current will be about 80 ma. So 1 Ahr will be a little over 12.5 hours.
    As the modules discharge the ~8V will decay to upper 7.x values. The current will decrease proportional to the voltage drop BUT this is only important to anal engineers. <grins>
    We're really interested in ranking the modules so the strongest and weakest can be paired.
  20. scotman27
    735
    81
    PA
    2001 Prius
    I only bought 38 modules. They according to both Sellers have less t than 10000 mines on them. I would love to get the testing done before next Friday so the battery can rest for the three day weekend next weekend due to the fact that I will be away for my sisters wedding Friday through Sunday.
