Got the ole ''Check engine'' light on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lester williams, Aug 23, 2015.
  1. lester williams
    227
    68
    mississippi
    2014 H/B 4, 28K miles, so still under warranty. Gas cap was NOT loose, I filled it up before light and did not ''overfill'', left station and light came on. [ cap on correct now also ] First bobble with this car, will run it to dealer first thing in the morning and see about this tom-foolery. If it starts messing up--- that will give me a good excuse to get a Gen. 4,,LOL.I will post results after the service shop. It starts, runs, drive fine and oil and coolant levels fine,, we'll see.
    51,154
    sometimes you have to power it up a few times and it goes away, other times you need a code reader to delete it.
  3. lester williams
    227
    68
    mississippi
    Yeah, I had this happen before in pick-up and it cleared right up. This started Friday at noon, cranked it Sat. morning and evening, light still on. Might go try one more time today, save getting to dealer by 7:15 to be first in service line. Old, retired men hate to get out that early,, unless fishing, deer hunting, etc. Hate waiting in line worse, though.
    E.T.A----just tried it again, light still on, 4 restarts since light coming on. Off to dealer in morning.
    #3 lester williams, Aug 23, 2015
  4. ChapmanF
    17,345
    As one thing that hasn't been mentioned yet is to read the codes, use them to actually find what the problem is, and fix it, I thought I'd just throw that out there as one more option. :)
    -Chap
  5. bisco
    51,154
    yep, going to the dealer is even harder than getting up in the morning.:p
  6. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Guess you know Autozone will do a free "basic" scan to give you a heads up...before you go to the Dealership.
  7. lester williams
    227
    68
    mississippi
    Dealer closer than A/Z, I will go there and get their attention about FIXING the cause.......
    frodoz737 likes this.
  8. JC91006
    16,673
    8,518
    I don't know why people come on here looking for solutions for a car that's under warranty. I much rather have someone else fix the problem for free than to do it myself.
  9. frodoz737
    4,535
    2,438
    33
    Possibly just to share and communicate with the Prius group?
  10. JC91006
    16,673
    8,518
    Yes I can see that as a reason, but if I didn't know how to fix it, it would go to the dealer, one of the very few times it'll be free
    If this were my car, I would just delete the code and see if it returns. If not, problem fixed.
  11. lester williams
    227
    68
    mississippi
    Well,, I thought perhaps some might find this interesting, as I will post a follow-up on results from dealer.........of course, it will go to dealer as the warranty is still valid.
  12. ChapmanF
    17,345
    Trouble is, their "basic" scan will probably be with a "basic" scanner, and may tell you something like "no codes found" just because there weren't any in the, oh, one or two computers it actually talks to out of the ten or so in the car.
    You mean "if not, problem ignored." Without reading the codes first, you don't even know what you've chosen to ignore.
    Because there are hundreds of problems the computers check for, and only a few lights on the dash, talking about the lights on the dash isn't remotely like identifying the problem. The dash lights are your car saying "we. need. to. talk." and you have that talk with a code reader.
    All the suggestions so often seen here about disconnecting the battery for a few, or cycling the ignition, or using the 'clear' function on a scantool ... they are all ways of saying "sure, honey, right after the World Series" as a response to "we. need. to. talk."
    Oops.
    And then from time to time you see the posts on PriusChat where someone is now facing an expensive repair and somewhere in the back story is "but, for the last six months it never came back right away when I cleared it!"
    If I could give one piece of advice to all new PriusChatters: get a code reader, one that reads Prius-specific info. Have it in the car. If a warning light comes on while driving, take the next convenient turnoff and ask your car what's up. Then you can look it up and decide whether it's a "schedule repair some time this year" issue, or "drive home but make appointment for this week", or "drive home gently", or "call for a tow."
    Sometimes it truly will be an issue that you can safely leave until it's convenient. If you checked the code at the time and confirmed that, you'll have the peace of mind that goes with that.
    But one last thing, if the dash lights come on again while you're waiting to deal with it, don't get in the habit of just assuming it's for the same problem you already know about. Without reading the codes each time, that's a really easy way to miss a different developing issue that could be more urgent.
    -Chap
  13. frodoz737
    4,535
    2,438
    33
    You are correct and that's the reason I typed "basic". The way some perceive Dealership Service Departments in general is that they are less than forthright when problems occur. While the fault may be covered by warranty, foreknowledge in general can sometimes alleviate anxiety during the wait for Monday morning. I never suggest anything other than for a heads up...and would never delete a code while still covered under warranty.
    #13 frodoz737, Aug 23, 2015
  14. JC91006
    16,673
    8,518
    I'm not a fan of deleting codes without knowing what they are. But since this is a check engine light, which is usually emissions related, it would probably be what the dealer would do while the car is at 28k miles. If the problem comes back, then they would address it.....but they would at least log the code before clearing it.
    This happened right after getting gas, I can't see what else the dealer would do for them but clear the code
  15. lester williams
    227
    68
    mississippi
  16. lester williams
    227
    68
    mississippi
    Whelp, took the little fella to dealer, the service ticket said, '' Evap gas cap problem'' and code was cleared--light off. As usual-- when I tried to explain to him that every auto has to ''click'' when gas cap re-installed or problems will incur and I had off'ed-and-on'ed several times and restarting, he said, ''You have to complain twice before we replace the cap with a new one''..............I'm telling ya---- I did not leave that cap loose and it will need a new one. Oh well, I will not get too upset about just a probably bad gas cap-- if it was something more expensive I definitely would.
    I love the Lincoln MKZ system, it is the easiest thing going to refuel. The gas door is a ''push in to release'' like the overhead console sunglass case,, and not a cap period. Just push the gas nozzle in a spring loaded flap, no levers to pull, no cap to take off. Gas up, close the door, drive away happy. As happy as 28.6 mpg will allow--- but great road car.
  17. JC91006
    16,673
    8,518
    So they need the check engine light to come on again with the same gas cap problem before they'll give you a new cap?
  18. lester williams
    227
    68
    mississippi
    As stupid as it sounds, yep....... E.T.A.---Told wife this and she said, ''This is my 4th Prius in 10 years and a first for me''. But- I do not drive the Prius much anymore and honestly do not know if the light was on before gassing that time as we had just switched vehicles and I filled it for her-- then noticed the ''check engine'' light.
    #18 lester williams, Aug 24, 2015
  19. JC91006
    16,673
    8,518
    I believe it. I had a problem with a bad 12v on my new plug in, they charged it back up and said it has to leave me stranded 1 more time before I get a new one. go figure
  20. VicVinegar
    VicVinegar Member
    273
    51
    Northern Virginia
    Doesn't hurt to be more knowledgeable. We all know dealer service departments are hit or miss when it comes to a level of service or actual expertise. It is even more important when some dealers try to charge you if you didn't correctly identify a warranty issue.
