Got to remember how low I am
Discussion in 'Gen 2 Prius Main Forum' started by TidelandAZ, Oct 27, 2005.
  1. TidelandAZ
    TidelandAZ New Member
    62
    Arizona
    Ok, I'm 20 days into ownership of my 05 Tideland Pearl, and I'm loving it!
    This morning, I pulled into a parking space, and heard the sound of the plastic rim (I think that's what I've seen it be called here) against the little parking barricade. This was the small kind - just about 3-4" off the ground. Coming from my Highlander to the Prius, I've got to remember how low to the ground I am!
    Did anyone else have this adjustment "issue" when first driving their Prius?
    (I know it's not a fault of the car, but of the owner.)
  2. NuShrike
    NuShrike Active Member
    1,378
    The Prius is taller than my '96 Civic which is taller than the previous '95 Civic.
    So no. :)
  3. bkmcae
    bkmcae New Member
    Try backing into parking spaces. The back has more clearance than the front.
  4. TonyPSchaefer
    14,816
    2,496
    66
    Far-North Chicagoland
    In your Prius, you're not low, you're on top of the world!!
  5. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    I quickly learned to NOT try to touch the concrete parking blocks in a parking lot. But the lower edge of the front apron is already scuffed and gouged where it made contact.
    With my 2000 GMC Sierra I was used to driving up until the front wheels touched, then parking it.
    The rear isn't much better. I have already gouged the rear apron plastic. So I just tend to avoid those concrete parking blocks in stalls by parking a good foot or so away.
  6. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    I have the same problem. I've done that no less than 5 times since receiving my Prius 6 months ago.
  7. ThrillAddict
    ThrillAddict New Member
    31
    I've also been spoiled by my SUV when parking. Everytime I park I just run up until I hit the little curb (softly mind you) to make sure the back of my car is out of the road as much as possible (and in an H2, you can barely feel hitting the curb!). I'm worried that on Monday when I get my Prius I will have this same problem when I'm in a hurry and being forgetful. Is the lip low enough to cause visible damage (without looking under the car) on a normal curb?
  8. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    It takes a while to learn how close you can get and still not stick out the back of the parking slot. I remember the first time I did it. I still do it but only every few months usually when I am in a hurry.
  9. coloradospringsprius
    171
    It's visible, but not obvious.
  10. sailatinu
    sailatinu New Member
    38
    Naperville, IL
    Well, I do not have my Prius yet, though uhm.
    I've done that enough times to be causing damage to my car (in my past civics).
    I blame it on my being a suckass driver.
    Makes me want to install frontal-cameras which watch down there..
    grin
  11. TidelandAZ
    62
    Arizona
    Have to admit that after reading all of the rear view camera postings, I was thinking the same thing! I don't seem to have the problem backing up! ;)
  12. TidelandAZ
    62
    Arizona
    Thanks for making me feel better about this. I cursed myself when I did it (self-name calling, of course). I felt like I had spanked a newborn infant!
