gotta get snow tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius123, Aug 16, 2010.
  1. prius123
    prius123 Junior Member
    35
    winnipeg
    Not going to get into all the issues about not having enough money. Lets just say been living off 30-40 bucks a week on food since starting these car payments a couple years ago. But gas was at 1.50/L looking like it was heading to 2+. Made sense to be doing payments on this car than how things were.
    Anyways.. gotta get snow tires though this winter and oct 'll be a triple cheque month. I'll have about 600 to 700 to do something about it. Right now have the stock bridgestone turanza el 400 p195/55r16 with 35k km. Went around with those the past couple winters. Almost got killed several times. Definitely going to be getting at least a couple studded tires on the front.
    Here's whats running thru my head right now... I gotta figure out what my options are here. Do i put those snow tires on the wheels i got now? Then ya got those tire pressure monitors. Sounds like i gotta get them to take those out cause it costs to put 'em in and stuff. Cause if its not at the dealer they have no clue how to deal with these things. Then ya got the light on the dash that comes on. I guess ya just gotta ignore it. The computer doesnt mind you driving around with things not right? Can get those black winter wheels and put the tires on that. That's gonna be too cost prohibitive, for 4 wheels and 4 studded tires. Can't do it. Its gonna be way over a grand. Then i seen somebody in this forum mention how they got the wider 205/55/r16 tires that are more common and cheaper. They're putting those on the stock wheels? So i should get those tires and put them on my wheels and take out the tire pressure monitors? And then there's the choice of places to do it at. Ya know if you bring it to the dealer they'll ring up the tab and it would be 2grand the way they do it. So i dont know.. i gotta figure out what i gotta do then maybe call around. Like where do i go to get this done that's cheaper. Around here there's canadian tire and sturgeon tire, maybe fountain tire, thats probably more expensive. Probably canadian tire but maybe it'll be cheaper at sturgeon. I'm thinking maybe i can get the 4 studded tires put on these wheels with no tire pressure monitors. I wonder what that would cost. Maybe can still afford to put the pressure monitors in? Probably cant afford it so would have to go with 2 studded tires on the front or something. I know how people love that but got no options right now. Somebody's gotta crunch some numbers here, total final costs including labour and gst cause it could be the difference between life and death. I need some help here cause risking dying on the road yet another winter. :(
  2. prius123
    35
    winnipeg
    here's what shows up if you search at canadian tire.. its like 200 bucks a tire. Then you get putting in studs, taking my tires off the rims, putting new tires on the rims, balancing, labour, taking out the tire pressure monitor, gst, pst, wind up costing 1500 bucks for snow tires, 2000 if you do it at a dealer i bet.
    Your search for "2008 TOYOTA PRIUS 4-1497 1.5L DOHC Touring; 3795 lbs.; 106.3 in. (195/55R16) Load Index: 86 Speed Rating: V". returned - 7 Results:
    5 Products - 2 Articles Compare Selected Items
    View:
    Grid
    List Sort by: Product Name (A-Z) Product Name (Z-A) Rating(high-low) Price(low - high) Price(high - low) Products per page: 16 32
    Search Results
    Continental ContiWinterContact TS 800
    Product #08-8875-4
    Reg. $182.46
    View See more Winter Tires - Special Order
    Michelin X-Ice Xi2
    Product #08-7610-0
    Read all reviews
    Reg. $183.30
    Continental ContiProContactâ„¢
    Product #08-7547-2
    Reg. $204.99
    View See more All Season Tires - Special Order
    Michelin Primacy Alpin PA3
    Product #08-7567-4
    Reg. $206.40
    Continental WinterContact TS 810
    Product #08-1297-2
    Reg. $234.75
  3. prius123
    35
    winnipeg
    and then somebody said stock toyota lug nuts come loose on other's winter tire rims?
  4. prius123
    35
    winnipeg
    ok i'm looking around. Seems like the only time i see p195/55 is with r15 not 16 like the ones i've got. Whats up with that? Guess i gotta go with the 205/55r16.
    So checking the canadian tire, sounds like there's just 3 kinds you can put studs in.
    Hankook I*Pike RC01 Winter Tire
    205/55r16 91t
    Product #06-2008-0
    See more Winter Tires or compare Reg. $109.99
    Goodyear Nordic
    205/55r16 89s
    Product #06-2072-4
    See more Winter Tires or compare Reg. $136.99
    General Altimax Arctic Winter Tire
    205/55r16 91q
    Product #06-2025-8
    See more Winter Tires or compare Reg. $159.99
    Looking at steel rims they're like 60 bucks a piece. Wondering about the different types they have. There's:
    pattern: 16x7. 6-5-1/2,
    pattern: 16x6-1/2. 5-115
    pattern: 16x6-1/2. 5-4-1/2
    pattern: 16x6-1/2. 5-100
    Not sure what all that means. Think it has to do with lug nut pattern. I'll have to check which kind the prius would be. Either way, cant afford it right now so gonna have to pass on that.
    Right now i'm looking at 110x4. 440. Seen someone say its 10 bucks a tire to stud them. 480.. taking my tires off, taking my tire monitors out.. putting them on my rims.. balancing, labour, gst, pst.. should just barely be able to pull it off. Maybe i can get the monitors put back in.. I wonder what the price difference is with the monitors in or out.
    I dont like the whole way this isnt the same tire size as i have now. Although looking around they seem oddball sizes that weren't in the drop-down menu and when i did see them they were like 200+ bucks a piece. I dont know.. i dont like putting wrong sized tires on different rims. Whatever though sounds like this is what i gotta do. I'll ask them what the price difference is horsing with these damn pressure monitors.
    Anybody got any better ideas with all this? :confused:
  5. bisco
    49,492
    sounds like moving to FL would be more cost effective and simpler.:D
  6. raholco
    raholco Ailurophile
    51
    Going to the 205/55R16 is no big deal-I did it with my Nokian WR-G2s.
  7. prius123
    35
    winnipeg
    looking around about this tpms stuff and its just a gizmo on the inside. If i'm using my same rims then it'll probably be less of a hassle than people who have a 2nd set of winter tires and would have to transfer them or something. Ya gotta wonder if these non-toyota tire places 'll be able to handle it or they'll wreck them putting the tires off and on. oh well i'll just leave them in there.
  8. prius123
    35
    winnipeg
    ok so what are the pros and cons of putting winter tires on the rims you have as opposed to getting their own steel rims? Does it wreck them by putting them on and off? I think people just like to put the set on themselves. Well maybe by next year i'll get a set.. although i dont like the way they look either. Whats the big need to get rims of their own instead of just putting them on the stock rims. Whats that cost anyways? i'm thinking maybe 20-30 bucks or something? Like should i really get a set? Do the tires get wrecked? Cause if ya gotta mess around with this tpms stuff and they wouldnt have them on the steel rims.. plus those black ones look worse.. might make more sense just to switch the tires onto the stock rims every winter. The only drawback i can think of is it'll wreck the edge of the tires, plus they could change it over themselves.. but then ya got no tpms. hmmm. yes i'm worrying about winter tires today. lol
    [later edit] oh yeah thats what it is, they gotta balance it and stuff.. probably gonna wind up costing me 50 bucks each winter plus wrecking the tires. hmmm.. but still theres that tpms thing. ya gotta wonder whats the better thing to do.
    [later edit] yeah you're better off getting a set of steel rims even though theres no tpms. be doing that by not this winter but the next. Just in time for the car to start breaking down. should have did that 2 years ago.
    ok for the steel rims, which ones would i have to get?
    dang.. might as well scrub up a bit more coin and get those right away during the next couple months instead.. so sounds like i gotta save up a grand, eh? Guess i'll have to cut into that food budget. Plus i gotta get some sort of different kind of lug nuts or else those non-stock steel rims 'll fall off?
    [later edit] hmm its just a bit too much at the moment that extra 300 and some. I can pull it off with this triple cheque by putting them on my stock rims for now,.. that going the extra and getting the steel rims is gonna cut into 2 months worth of household bills and backed-up utilities. The winter after this one i'll work on getting rims. What a mess.
  9. Tideland Prius
    16,155
    prius123, PM msantos and jayman. They're both in the Winnipeg area and can definitely help you out regarding studded tyres and prices for southern manitoba.
    As for me, i have two suggestions
    1. Order from Tire Rack.
    2. Buy from the US.
    tires are a lot cheaper down south.
  10. Patrick Wong
    18,200
    6,474
    If you are going to buy separate rims for the winter tires, then I suggest you should buy 15" steel wheels, use the 185/65R15 size, and don't worry about the TPMS sensors. Usually a narrower tread is desirable for winter tires, and the selection and pricing should be more favorable.
  11. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I put on a cheap set of steel rims for winter with not so cheap tires on them. A little happy face sticker in the right place deals with the tpms light. I'm thinking this may be the cheaper long term solution, but you have a shorter term cash flow issue, so maybe stock rims this year.
  12. prius123
    35
    winnipeg
    Ordering from the states after shipping cost, duty for crossing the border, customs brokerage fees, probably winds up costing more. With something bulky like tires probably wouldnt be worth it. Anybody try ordering tires from there and get them shipped to canada, find the savings was worth it?
  13. prius123
    35
    winnipeg
    ok i'll keep that in mind. Looking up the
    185/65R15
    Product #05-1811-4
    See more Winter Tires or compare Reg. $82.99
    thats 110 bucks difference for the 4 compared to 16. The wheels are the same price. 83x4+40studs+240rims.. You're looking at 612.. plus balancing, labour, taxes etc. Sounds like i'll be able to pull it off. Anybody have any problems with 15's when the stock rims are 16?
    The 185/65R15 size seems familiar because at the canadiantire site when checking for tires in the drop down menu i had chosen the base prius model and it said that was my tire size. I was thinking how come my tires are different the later notice the drop down menu had 'touring' which would say 195/55R16 i've got now. Looked on my new car paperwork and nowhere it said my model was touring. So yeah i guess i could go with that tire size because it seems compatible. Thanks for the tip. I'll be going with those now. lol
  14. prius123
    35
    winnipeg
    ok what kind of steel wheel is the prius? And what do these differences mean. I looked it up so know what the tire numbers are.. But not sure about these.
    15-in. Multi-fit Steel Rims
    Product #09-5919-8
    pattern: 15x6. 5-4-1/4
    pattern: 15x7. 6-5-1/2
    pattern: 15x6. 4-100
    pattern: 15x6. 4-4-1/4
    pattern: 15x6. 5-110
    pattern: 15x6. 4-4-1/2
    pattern: 15x6. 5-100
  15. Patrick Wong
    18,200
    6,474
    I don't know about these multi-fit rims. I'd find a vendor where you can say that you have a Prius, want 15" steel wheels, and let them figure out what you need...
    Why not buy from Tire Rack or some place like that? They'll figure these details out for you, like whether you need wheel nuts or not.
  16. prius123
    35
    winnipeg
    Ordering from the states after shipping cost, duty for crossing the border, customs brokerage fees, probably winds up costing more. With something bulky like tires probably wouldnt be worth it. What would the total be from tire rack?
  17. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    I just purchased 4 new wheels and a set of Blizzaks from Tire Rack. The Blizzaks cost $70.00 each and the wheels were $99.00 each. $280 + $396 + $85 shipping = $761 for the package. The wheels are Elbrus 104.
  18. prius123
    35
    winnipeg
    Went down to the couple main tire places here in town for a quote and it'll cost about 850 for the 15's on steel rims with studs. So thats what i'm going to be doing.
    When I was down there was asking about summer tires. Sounds like these oddball 16 inch wheels, the tires wind up costing twice as much. I'm wondering if i should get a second set of 15 inch rims for summer tires and putting those 16's away. Anybody do that because of the price difference? I'm looking at 800 bucks here for all seasons on my stock 16in rims. Wondering if i could get a second set of 15 rims with cheaper tires for that price. Then the years after would be a big savings on tires. What are you guys doing who cant afford these $220 tires all the time?
    [later edit] oh also the guy looked up the steel rim bolt pattern and it says
    15x6, 5-100
    is that correct?
  19. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Um .... since I sold my '04 Prius, I still have my 4 studded snow tires, on multifit steel rims: 185 65 15 Goodyear Nordic
    You need a proper "acorn" lugut as the OEM lugnuts will loosen up
    Go to NAPA and order 20 of their part number #641-2042. This is a M12-1.5x21mm lugnut
    Ironically, the same lugnut fits the 2007 FJ Cruiser, so I kept them to use on the steel wheels that I run in winter for my FJ
    PM me if you want these wheels/tires: the first $450 obo takes them. I used them a couple of winters, they look new
  20. jayman
    13,439
    640
    Winnipeg Manitoba
    I should add this: if you walk into Canadian Tire and tell them you want a winter wheel package for a Prius, they will look at you as if you stepped out of a flying saucer. Tell them you want a winter wheel package for a Matrix or Corolla
