GPS Not Working. Home location not accurate
Discussion in 'Prius v Audio and Electronics' started by prevee5, Sep 16, 2022.
  1. prevee5
    prevee5 Member
    121
    Monrovia, California
    2012 Prius v Model 5, Non-ATP, 130K miles
    Gps suddenly doesn’t know its location. Home is now 12 miles away. Anyone know of a fix?
    Radio and Satellite / SiriusXM working normally so probably not antenna?
    Don’t use GPS much since we have cellphone GPs but nice to have as a backup.
    Please advise.
    Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,457
    6,560
    Texas Hill Country
    Gps has a separate antenna
  3. prevee5
    prevee5 Member
    121
    Has the GPS antenna failed?
    Anyone had this issue?
    Where is the GPS antenna?
  4. rjparker
    10,457
    6,560
    Texas Hill Country
    It is under the dash, passenger side if I remember correctly. @gromittoo is the resident expert on the mfd.
  5. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    If displayed GPS location changes as you drive, but is wrong, it is the system logic or the satellite ephemeris reads/captures that are erroneous.
    #5 Air_Boss, Sep 24, 2022
  6. prevee5
    prevee5 Member
    121
    Yes, gps updates while driving and instructs you to turn on streets that don’t exist in the area I’m driving.
    Any fix for this or is the GPS circuit in the head unit “dead”?
    Would a system reset do anything?
  7. rjparker
    10,457
    6,560
    Texas Hill Country
    If the gps antenna is weak it may not be capturing multiple satellites which degrades its accuracy.
    @gromittoo ?
  8. Air_Boss
    4,220
    1,188
    New Yawk
    If there are streets the nav system doesn’t know about, it means they are newer than the nav database. Nothing the GPS can do to map streets it doesn’t know exist.
  9. prevee5
    prevee5 Member
    121
    Just to clarify, GPS thinks Home is about 20 miles away from where my actual Home is. No matter where I am, gps mostly routes me to n entered destination starting at my “Home”. Tells me to turn here and there on actual streets but they are nowhere near where I currently am. Seems to call out commands at random. Pretty weird
  10. Air_Boss
    4,220
    1,188
    New Yawk
    Then it is a system logic or satellite ephemeris issue.
  11. prevee5
    prevee5 Member
    121
    Any suggestions on a fix?
  12. Air_Boss
    4,220
    1,188
    New Yawk
    Knowing nothing of the specifics, can you unpower and reset the system, force it to rebuild the ephemeris file?
  13. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Is there a calibration setting/button like in the ATP NAV? (Vaguely remember there's one hardly ever drive our v).
    REVVL V+ 5G ?
  14. Air_Boss
    4,220
    1,188
    New Yawk
    I have no idea. No issues with our 2012 v Five GPS nav, though it will not lock onto Sirius XM satellites.
  15. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    GPS antenna is usually near/in front of the radio underneath the dashboard. See this manual pg 26 (Moderators this is a link to a Toyota Owners website manual if you need to please approve) also pg 46:
    https://assets.sia.toyota.com/publications/en/omnav-s/OM33A02U-00/pdf/OM33A02U-00.pdf
    "Location & GPS Information" button, see that it acquires at least 3 satellites, (for triangulation).
    On pg 64 there is a "Settings" tab on the top but the manual doesn't appear to explain it. Please check there for possible calibration...
  16. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Air_Boss likes this.
  17. Air_Boss
    4,220
    1,188
    New Yawk
    Not on the non-ATP, but this looks very interesting.
  18. prevee5
    prevee5 Member
    121
    So I pulled 2 fuses associated with the nav system according to the owners manual. Unfortunately, no effect. Any other suggestions?
  19. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    So did you check if the unit is getting satellite signal/lock???
    REVVL V+ 5G ?
  20. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
