GPS reads slower than speedometer. Better or worse FE?
Discussion in 'Gen 2 Prius Main Forum' started by fthorn, Apr 17, 2009.
  1. fthorn
    fthorn From gas hog to greenie to gas hog
    197
    I noticed on a recent trip that my GPS unit shows a slower speed than does my speedometer. For instance, when speedo set to cruise at 75, GPS shows 73 mph.
    Am I getting better or worse fuel economy than what the MFD shows?
  2. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    If the GPS is correct then the car thinks it has gone further than it really has so its computed miles per gallon is too high (I think :) )
  3. fthorn
    197
    That would be the obvious answer to me, too. But I'm waiting to see if anything else might negate this.
  4. hschuck
    hschuck Member
    385
    17
    bay city, ca
    Speed is not a factor in determining mpg. Distance traveled and fuel used are the only factors involved.
  5. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    But speed is calculated by distance over time so if the speed is incorrect the distance is probably incorrect also (assuming time measurements are more or less accurate)
  6. timberwolf
    timberwolf New Member
    220
    31
    UK
    You would have to measure your odometer against a known distances travelled to determine that as the speedometer and odometer are separate devices. In the UK (and the EU) a car's speedometer is allowed by law to read 10%+ a constant above the actual speed but never allowed to read under, I've seen posts where Prius owners have tested that the odometer is much better than the speedometer in accuracy wise.
  7. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    While your indicated speed and your odometer likely pull data from the same source, how that data is then manipulated and displayed to you in each gauge is not the same.
    Basically - your speedo can be off, but that doesn't necessarily mean your odometer is off, as well.
    I'm pretty sure MOST car (and motorcycle) manufacturers intentionally have their speedos showing slightly higher than actual speed. This is a bit of a buffer - imagine if your speedo indicated 10% too slow! You'd get speeding tickets rather easily... which would lead to litigation for the manufacturer.
    IMTO (in my technical opinion), it's a safety/liability measure engineered into the instrument.
    That said, I doubt your odometer is off by very much. Maybe 1% or so. Again, if your odometer was off by a significant amount, it could lead to litigation. There's no real way to tweak the odo to make you safer, either.
  8. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    The UK Prius adds exactly 10% to real speed over ground. This can be seen by comparing the speedometer to the speed seen in the Vehicle Signal Check screen of the MFD diagnostics. The odometer records the correct distance travelled.
    The car measures real distance travelled by multiplying real MG2 rotation speed - which is very accurate as the motor control circuitry has to know exactly where the rotor is in its rotation to apply the correct waveforms to keep it moving in the right direction - by the assumed circumference of the tyre. Tyres only have nominal rolling circumference, and that circumference changes with load and pressure, and with tyre wear. Tyre wear itself can account for about 2% difference in distance travelled.
    There's a good article on this at TireRack.com.
    I'm not sure whether GPS accounts for actual terrain or only measures speed and distance over the reference geoid, which is an approximation to the Earth's surface.
  9. bwilson4web
    15,606
    I'll answer the question and then address the why:
    • GPS reads higher than trip meter - actual MPG mileage is better, a greater value.
    • GPS read lower than trip meter - actual MPG mileage is worse, a lower value.
    HOW TO ADJUST MPG
    • actual_MPG = indicated_MPG * (GPS_miles / tripmeter_miles)
    LOGIC
    The tripmeter, the car's distance measurement, it tied to the number of tire rotations. However, tires with identical specifications, 175P65R14, can have different revolutions per mile. Usually these differences are just a couple of % and even as the tire wears down, the actual diameter changes due to the lost tire tread. For normal speed management, it doesn't matter. But for MPG when you are in the 50 MPG range, 2% is the difference between 49 MPG vs. 51 MPG.
    So if you put tiny, smallest possible tires on all four wheels, they would spin much more rapidly and indicate a greater distance than actually traveled. The actual speed would be less than indicated. So if you wanted to 'sandbag' a mileage contest, put four donuts on the car and run the course IF they are using an MPG indicator in the car.
    The irony is that tire physics indicate a larger diameter tire will give lower rolling resistance and better mileage but it also leads to lower than actual speed indication. So the indicated MPG looks as if mileage has gone down ... exactly what is reported for brand new tires with fresh and thick tread.
    Since I use gas receipts versus trip meter, I use a calibration constant from the GPS-to-trip meter to adjust the actual miles. This gives accurate MPG. On the road, I set my cruise control to a target speed and then use the GPS speed to 'trim' to true speed.
    GOOD LUCK!
  10. bac
    bac Active Member
    863
    52
    Pennsylvania
    Ding ding. We have a winner! :D
    ... Brad
  11. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    I have did the road mile marker tests also and be careful. The crews must have been drunk on some of these roads. LOL
    But a cross reference to use with your GPS and odometer to measure distance traveled. On a long trip your GPS might be a good check of your odometer.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,075
    Northern Michigan
    Keep in mind that your map database can be off too. All of the highway exits in Utah are off by two miles in my map database. Their physical location is correct, but the exit numbers are shifted by two. Presumably the State of Utah changed their numbering datum at some point after the database was created.
    Tom
