Gradual decline in fuel mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by PriusCatt, Aug 18, 2014.
  1. PriusCatt
    PriusCatt New Member
    Hello...
    I have a 2010 Prius that I purchased new, no accidents of any magnitude. Slight bump in the back which created some dents. When I purchased the car, the number of miles read 550 available and it got 52-53 mpg. Then it started declining and averaged 47 mpg. I went to the dealership a week ago and had an EFI fuel system decarb and clean throttle body done and after 4 days it gets 41.5 mpg, now even lower at 39 mpg.
    I watched the consumption gauge as I drove today going very slightly uphill between 38-45 mph and it was getting 25 mpg or slightly lower. Going slightly downhill did not improve the mpg much at all. The only time when it gave a high reading was when it sat idle at a stop light period. Another trip where I was going about 52-55 mph it showed about 48 mpg. I live outside LA, so it is hot, I use the AC all the time and always have.
    What do you think is the issue? I had a 2009 Prius and it got 60 mpg or better as the norm. Thanks. :)
  2. JC91006
    16,482
    8,399
    Try a different gas station
    49,470
    welcome to priuschat! how many miles on her? you might need a new 12 volt.
  4. PriusCatt
    Hi and thank you! About 48K miles. Not much. I have known people who have had Prius' for a very long time with high mileage and no one has ever had to replace the battery. Wondered is this was covered in the mass tort ... thanks.
  5. PriusCatt
    HI ... I normally only use Shell gas. Because of the unexpected lower mileage I have strayed at bit when the tank is getting low. But still 95% use Shell throughout the ownership of the car.... thx
  6. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    I agree...check the 12 volt battery. Do a search to see what we mean.
  7. fuzzy1
    10,167
  8. fuzzy1
    10,167
    Not your thread. Did you read the linked thread?
    We prefer to see actual voltage numbers. Just because it is just 30 months old doesn't guarantee that it is fine.
    Did you personally re-measure them recently, while morning cold? Don't trust the dealer, they may set it while the tires are warm or hot, leaving them actually underinflated.
    Many of us prefer higher pressure, but that is a comfort vs. mpg tradeoff that only you can choose.
    AC always on, and set to low temperature, will cause significant MPG loss in slow and congested traffic. Raising the temperature setting and reducing the fan speed as much as tolerable will help. But if reduced AC use is not tolerable, just recognize that it does cost fuel.
    'Too much pollution' is not relevant. The AC does not clean it up.
    Please check and report the brand and model name so others can check out whether or not it is an LRR (low rolling resistance) model.
    New tires will reduce MPG a bit until they are broken in. This is in addition to any loss due to a non-LRR tire model.
  9. PriusCatt
    Ok, thanks. But
    They are Sumatomo 195/65 R15. Thanks for your assistance.
  10. PriusCatt
    So what happened to Fuzzy? He did not respond to my new information. :(
  11. fuzzy1
    10,167
    Sorry, but the way you formatted the reply hid most of that new information.
    Sumitomo is the brand, what is the model name under that brand? They make several models.
    Regardless, I don't see any Sumitomos on the current LRR tire lists. So the tire choice is probably costing a few MPGs.
    I had a 2010 Prius for three years, so know that it can be manually switched between Recirculate and Fresh air source, whether AC is On or Off.
    With high outside temperatures, AC is certainly needed. But in my climate (not a desert), it never needs to be set to LO. 75-80 works just fine, especially when dressed lightly for hot weather. Without passengers, I also set the fan speed fairly low, and point all the dash vents at me, in order to minimize the needed climate control energy consumption. Let the back seat area get hotter, nobody is sitting there.
    Do take note that over any significant length of time, the inside air will be completely replaced by outside air, even when set to Recirculate. (It must be replaced, otherwise you will suffocate as the interior oxygen is consumed by your respiration.) The ventilation system can filter out much dust and pollen, but not any of the chemicals and other pollution and smells. You can avoid the short dense clouds of pollution, but not the longer term average pollution level. So when the outside temperatures are tolerable, you may as well use the Fresh setting to avoid AC use, except for those occasional brief dense dirty clouds. Without Fresh air, sunlight heats up the interior significantly and forces fuel-robbing AC use at lower ambient temperatures, needlessly reducing MPG.
    The car automatically selects Recirculate with AC, to save energy by cooling partially pre-cooled air. (This doesn't save anything when you initially get in the car with hotter inside air. It saves only after the interior is cooled below outside temperature.) But even then, it always pumps in some fraction of outside air -- whether fresh or polluted -- to prevent oxygen starvation and excessive moisture accumulation.
    Did you have any other new information that I missed?
    #11 fuzzy1, Aug 23, 2014
  12. bwilson4web
    15,518
    The Sumitomo T4 had been listed as 'low rolling resistance' but Sumitomo changed/discontinued that model. It had a 51 psi sidewall rating and is what I have on our 2003 and 2010 Prius. The 2003 is testing different tire sizes and the 2010 is running what Toyota sold us about three years ago . . . when the T4 was still in production.
    Sad to say, the T4s on our 2003 are wearing out so I've order a pair of Yokohama Avids that match my criteria:
    • 51 psi max pressure - this reduces the contact area and tire flex to minimize hysteresis losses. I have not found any other vendor making 51 psi sidewall, 14" tires.
    • maximum diameter / minimum revs per mile - this is in effect, 'overdrive', that reduces the transmission stirring losses as well as the angle of flex between the contact area and the non-contact area.
    These physical characteristics can be modeled and measured. In the meanwhile, I've given up on the term "low rolling resistance."
    I appreciate that tire design and construction can reduce rolling drag but there are no metrics for rolling resistance as part any tire specification. Between California and NHTSA and Dept. of Energy, all have promised but FAILED to deliver rolling drag metrics. I don't fault those who think this term has merit but challenge them to cite a coefficient of drag or actual rolling drag metric for current production tires (i.e., California and NHTSA both published some initial study results 10 years ago!)
  13. bisco
    49,470
    i think the mass tort solved all these problems, didn't you get the
    i think the mass tort solved all of these problems, didn't you get the memo?
  14. PriusCatt
    I understand. They are TOURING. They are supposed to be compatible with this vehicle, they came up as such via a search. So I have been using the trip function on my car and watching the consumption. I got 49 MPG on the HWY up to about 1 mile from work or less, in a light traffic industrial area. By the time I got to work it was 42 MPG. It was showing a minute by minute consumption. So I do not know what could have happened to drop it so much. My MPH were 0 to 40 max. Thanks.
  15. bisco
    49,470
    49 on the highway and less around town tells me your battery isn't doing much. you should be under warranty which will save you as much as $4,500.
  16. cbo111
    cbo111 Junior Member
    Calif
    My 2010 has over 132k miles and has consistently read over 50 mpg on the computer. I live in the mountains and work in the desert. Mostly highway miles at 70 mph. I've never changed the battery.
  17. bisco
    49,470
    same here!(y) except for the miles, mountains, desert and mph parts.:cool:
  18. PriusCatt
    Hi ... is it stop and go driving or pretty car free driving? My MPG is going down again, now at 39 MPG. I see it at 50 MPG on the Consumption screen and then it just drops.
  19. Mendel Leisk
    38,718
    Maybe calculate what you're getting for a few tanks. You seem, at least in part, to be at the mercy of up-and-down mpg display in the dash.
  20. bisco
    49,470
