Graham's Mini Scanner - Tool Rental
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Nov 26, 2009.
  1. bwilson4web
    15,396
    INTRODUCTION
    This longish posting is about 'tool usage' of a Graham Davies mini scanner. It covers basic operation to check out the health and status of an NHW11 Prius.
    Background
    Graham Davies is one of the Prius pioneers who along with the 54,000 owners of NHW11 Prius made a stellar constribution of his Mini-Scanner. He made about 200 of these marvelous instruments until the NHW20, using a different CAN protocol, made them unusable for the next generation. But there are close to 50,000 NHW11s still out there who could use a Graham scanner to diagnose and help correct problems ... to keep these NHW11s running. I now have a second one and am doing 'tool rental' so folks who need to repair their NHW11s can gain more years of service.
    TECHNICAL
    The mini scanner has four buttons, a display capable of showing two lines of two data elements, and is powered from the CAN bus where it gets the signals. There are seven lines or rows so a total of 14 variables and be viewed, four at a time. But it is a little tricky to operate so I will make frequent references to this sketch:
    ON/Reset/OFF
    The left-most, standalone button is reset. When the ignition is on, the mini scanner remains inert until the reset button is pressed. The scanner remains on until the car is turned off. Hitting the reset is the same as the initial power on state and after initialization, puts the mini scanner in "Display 7" mode.
    Line 7 - showing MG1 C and MG2 C
    Line 1 - showing ICE C and ICE rpm
    MG1 and MG2 temperatures are a primary indication of their health and status. When the Prius is warmed up and operating at speeds under ~65 mph, the normal temperature relationships including engine should be:
    • 85C - ICE coolant temperature
    • MG1 C < ICE C - MG1 has to carry about 28% of the ICE power in or out so in addition to be closest to the engine block, it tend to run warmest of the two MGs but cooler than the ICE.
    • MG2 C < MG1 C - at ordinary speeds up to about 65-70 mph, a healthy MG2 will be cooler than MG1. But if MG2 is running warmer than MG1, we begin to worry about shorting or a cooling problem. This is a bad thing that is associated with transaxle failure.
    • MG1 C and MG2 C > 100C - heat is the enemy and running at speeds that heat MG1 and MG2 above boiling is going to shorten the transaxle life. In fact, I prefer to to treat 90C as the warning level and at 95C, I slow down NOW! Speeds in excess of 75 mph on hot days and in mountains can easily bring the MG temperatures above 90C range. In such conditions, I recommend keeping your climbing speeds to 55 mph since this is both engine and vehicle efficient and 55 mph up a mountain is much nicer than the alternative.
    There are three buttons on the right, a center "mode" button, and two option buttons. By pressing the "mode" button for about 1 second, the "Favorite Select" mode occurs and all data lines can be displayed. Use the "right" button to go up and the "left" button to go down. It does not "wrap."
    Line 2 - Traction Battery Min V and position
    Line 3 - Max Battery C and Max V
    The NHW11 traction battery has 38 modules grouped into 19 pairs numbered 1-19 from the control electronics. Each module has six cells at ~1.2 VDC or 7.2 VDC for the nominal module volage. Two modules together give a voltage of 14.4 VDC. But in practice, the per cell voltages can go a little higher, up to 1.4 VDC in part due to charging needing extra voltage to push current into the cells.
    We are looking for a low module-pair that is 1.2 VDC or lower than the maximum module-pair. This is the signature of a failed cell inside a module. A failed cell can not be repaired so the module has to be replaced and/or the traction battery pack refurbished. Regardless, that traction battery assembly has to come out.
    The other problem is a failed or failing module will start running hot. Heat is the enemy! Since the electrolyte is a saturated KOH solution, if the temperatures approach 100C, the internal cell pressures will become very high and this can lead to other 'bad things:'
    This is an NHW20/ZVW30 battery pack that was over charged.
    Line 4 O1 V and O2 V sensors
    The NHW11 uses a fuel trimming algorthm that requires two oxygen sensors. As the engine runs, it cycles between a slightly rich and lean mixture causing #1 oxygen sensor to swing ~100-800 mv. The exhaust gas then passes through the three-way catalytic converter where #2 sensor sees a smaller swing. The catalytic converter has combined the NO{x}, CO, and hydrocarbons into mostly nitrogen, CO{2} and water vapor. Both sensors need to work and #1 must have a larger swing than #2.
    The NHW11 also has a hydrocarbon capture system just before the catalytic converter that has mechanical linkages. These can corrode and should be inspected, tested for smooth operation and lubricated with a high-temperature grease if living in salty areas.
    Line 5 AccM V and AccS V
    The NHW11 uses a mechanical, dual potentiometer encoder on the accelerator pedal that are resistance offset but otherwise linear. Some of them develope 'noisy' wipers and this can confuse the hybrid vehicle ECU. Not knowing which is right, it goes into a "safe mode" also called the "big hand" syndrome. By slowly pressing the accelerator, and monitoring the voltages, look for swings or jerks, the symptom of noisy contacts.
    Doug Shaffer pioneered how to disassemble, clean and reassemble the encoder or you can get a new one from Toyota for about $500. I also clean them on an exhange basis:
    Line 6 MG1 Nm and MG1 rpm
    MG1 along with the Power Split Device are the "variable" part of the CVT transaxle. Due to gearing, MG1 Nm torque is 28% of the engine torque. If you divide the MG1 Nm by 0.28 and multiply it times the ICE rpm, you have the engine shaft power to the transaxle. It is a built-in engine dynanometer.
    MG1 also has two modes: generator and "energy recirculate" (also called heretical.) In generate mode, MG1 provides counter torque to the engine and everything combines in MG2 to drive the car. But in "energy recirculate" mode, MG2 generates power and MG1 works like a motor to slow the ICE rpm ... a kind of 'over drive' and very efficient at high speeds.
    Line 7 MG1 C and MG2 C
    Our old friends, the temperatures of MG1 and MG2 that should be kept under 100C by conservative (and fuel saving!) driving.
    LINE 1 select
    LINE 2 select
    By pressing the middle button for a second, the cursor moves to a new line and blinks. Using the left and right buttons, one can select a new data item to display. This is part of how the Graham scanner is programmed:
    Options 2
    Pressing the middle, mode button allows changing the number of lines reports out the RS-232 serial interface and the poling rate. I have it programmed for six lines and the fastest poling rate, just over 1 second for all six lines.
    Trouble code
    Pressing the middle, mode button allows use of the right and left buttons to display the recorded engine, hybrid and battery error codes. Then holding the right button for ~3-5 seconds, it lets you reset these codes.
    These major codes often have subcodes but they are not displayed. However, knowing the major code often gives enough information to isolate the problem to an assembly. Volume 1 of the maintenance manual has the codes and explains their relationship to the vehicle systems. This is the diagnostics volume. Volume 2 covers how to replace parts.
    CONCLUSION
    There are many other aspects of the Graham scanner that support sophisticated engineering studies but I'm renting one primarily as a diagnostic tool ("renting" a loan with a refundable deposit.) A running NHW11 is a lot better to have than having one broken and unrepaired. There are plenty of parts in the salvage yards so there is no reason these cars should not continue service for a very long time.
    I will write a separate instruction on efficient driving of the NHW11. Although it will use Graham scanner examples, these less expensive and more common instruments are all that are needed:
    • ICE rpm
    • ICE temperature
    Using the Graham scanner to calibrate these add on instruments would be a clever thing to do and I need it back to keep NHW11s running.
    My thanks to Graham Davies for inventing this wonderful tool, Doug Shaffer for pioneering work, and 54,000 NHW11 owners who risked time, money and reputation to make the Prius a USA success. Last but not least are Toyota and their excellent engineers who made this possible ... domo arigato gozaimashita ...
    どうも有難う御座いました
    ps. I have two Graham scanners and rent one. But the number of NHW11s needing temporary use of these instruments will only increase over time. I am interested in buying and making more of them available as rental units. Contact me by PM.
  2. SynkorSwym
    SynkorSwym Junior Member
    Little Rock, AR
    2001 Prius
    I
    Hi Bob, First of all let me say that I admire you, Mr Wong, and others that have put so much time into helping others on this site. I have been reading this site for several months now trying to get up to speed on my prius, since I'm a do it your selfer and know nothing about the prius other than what I have picked up here.Again, Thank you. Now, my adventure, I purchased a 2001 prius about a year ago in what appeared to be very good condition. That still seems to be true. I have put a rebuilt battery in it and that went well, did that through Greentec, (almost did it myself but decided against it). Recently I was driving the car, lost power, the triangle light came on, and it would only do about 15mph. I was close to the Toyota dealer so i took it there. The next day I was first told that it was the throttle position sensor, then a few minutes later told that it appeared to be the accelerator pedal position sensor. Also, now the CPU was reporting that it was a 2003. So he ask me if I had the CPU changed out. several hrs later I got a call telling me that it would cost around $1025 to fix the accelerator position sensor by changing out the whole assembly. However, none of the work or the analysis. which had climbed to 2.5 hours now could be warrantied because of CPU being changed out. At this point I went and got the car, paid the 2 hours and left.
    I know that at at one time you were swapping out parts and offering the use or rental of the mini scanners. Is that still an option? And what is your advise about my situation given that I may have a 2003 CPU online with my accelarator pedal position sensor throttle position sensor and whatever else is on that curcuit. Thank you
  3. SynkorSwym
    Little Rock, AR
    2001 Prius
    I
    Sorry, I should have typed ECU instead of CPU. Old habits die hard.
  4. ronlewis
    ronlewis Active Member
    824
    170
    texas
    2001 Prius
    wow, you da man.
