Great news today - 2012 Toyota Prius PHV to get selectable EV mode, full battery regeneration
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by freedom45, Jun 15, 2011.
  1. freedom45
    freedom45 New Member
    24
    Montreal, Quebec, Canada
    3 people like this.
  2. hill
    8,177
    Shwwweeeat !!
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    great news
    49,478
    perfect.
  5. k9frog
    k9frog New Member
    88
    sullivan co ny
    there moving in the right direction, now if toyota can make the car affordable thatll be a plus
  6. nwprius
    nwprius Member
    227
    35
    Lacey, Washington
    That just made the difference for me. I just signed up for the Pre-Registration. Even though I just bought a 2011 five with ATP.
    The previous iteration left me uninterested because it did not allow charging the lithium ion battery while driving. Now they have my attention.
  7. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
  8. WE0H
    WE0H Senior Member
    3,247
    527
    Wow that was good news to hear. I bet that car will get huge mileage figures with the complete battery capacity able to use regen charging. The wireless Gen III will become the gas guzzler Prius version now ;) I sure hope they offer it as a Prius Five PHV with all the bells & whistles of a Five. As long as it is under $40k, it is fine.
    Mike
  9. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Does this mean you don't have to brake like a Grandma in a PHV?
  10. cproaudio
    2,401
    759
    CA
    They really listened. When I was test driving the PHEV in green drive expo in SF, the Toyota rep asked me if there's any improvements Toyota could make to make the Prius PHEV better. I told them that regen into the PHEV pack would be great because without that ability, all the regen would goto waste once the main pack is full.
    How does a grandma brake in a PHEV?
  11. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Now throw in a 10-way adjustable power drivers seat, a longer travel in the telescoping steering wheel (with better placement of the spokes), and some ride enhancements (like those dampers from the Lexus CT 200h or the enhancements they did for the v wagon), and it'll be ready to go!
  12. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Great news.
    The weird thing, if I ever get to drive one, will be sitting behind the wheel of a Prius without pulsing and gliding.
  13. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    So what you're asking for is a Plug-in CT200h? ;)
  14. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Good question. Presumably, a Grandma would still brake like a Grandma (slowly and early) in a PHV.
    But I assume, since my question was mostly rhetorical, that you can now stop in about half less distance in a PHV and still recapture all the energy from motion, as compared to a regular Prius.
    It's a nice feature if you are sensitive to causing people in cars behind to get annoyed when you brake early for the purpose of not using friction brakes.
  15. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Hard braking will still bring in friction brakes, just not as soon or as much.
    Braking will still be a loser compared to gliding, even with 100% regen (no friction), since regen process is only 1/3 to 1/2 efficient.
    B mode will be detrimental except from the highest mountain passes that can fill the combined pack.
    On a typical highway trip, I can run EV from my home, switch to HV a mile before the freeway to allow initial warmup at lower power demand and while already moving, then switch to EV on the off ramp and use the rest of my wall juice in local driving at my destination. Sweet.
  16. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    ^^ I think SipNfuel was wondering if mac current rate into the batterie(s) will be higher than in the plugless Prius. We'll see, but I kind of expect one battery to fill up, and then the next battery opened to receive charge. If that is the case then the answer is nope.
  17. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Thanks for your reply. My assumption was there is a red light ahead, someone is behind you impatiently waiting to get into the right turn lane that opens up ahead. You maintain speed so the person behind you can make their turn, but on the other hand you have to brake forcefully because you coasted up to the stop at a faster speed, rather than braking early.
    The thought was in a PHV that you can still brake more forcefully and still not hit the current limit.
    Yes, this is what I meant. I assume(d) the current limit is/will be higher. But the way you put it, perhaps it is filled in series and not in parallel. 100 amps into the battery is the current limit in the regular Gen III Prius and Gen II Prius.
  18. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    I wonder how much the FE stats/rating will increase.
  19. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Depends on many things.
    But the basic FE rating in an EV depleted mode will be the same.
    If you only drive 10 miles a day you'll have infinite MPG since you won't use any gas. But the basic 'guts' of the Prius, other than the extra capacity battery, are essentially the same.
  20. JJay
    JJay New Member
    123
    Vancouver, WA (near Portland)
    Personally, I've been looking at replacing my Prius with the Lexus CT for 2 reasons: 1) no-nonsense plain sun/moonroof 2) great handling in Eco and Sport modes. (Seats are really nice too!)
    We test drove the Lexus 2 weeks ago.
    The Prius Plug-in with 1 battery pack for all modes is a game changer. I registered for the Plug-In yesterday.
