Green bars don't appear when I brake anymore.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lucasanderson298999, Jan 16, 2017.
  1. lucasanderson298999
    lucasanderson298999 Junior Member
    27
    los angeles
    Backstory: Prius 2008. I did not drive it for a week prior to this issue.
    Usually when I drive the Prius and I hit the brake pedal, the green bars always appear but, recently they are not showing up whenever I push the brake.
    Is this normal? What does this mean?
    I apologize in advance if this has been discussed already. I searched this on forums but couldn't find any info.
    If there is, please link me to it?
    Thank you!
  2. lucasanderson298999
    27
    los angeles
    Usually when I drive the Prius and I hit the brake pedal, the green bars always appear but, recently they are not showing up whenever I push the brake. The green bars appear randomly when I push brake but not all the time as it used to.
    Thank you!
  3. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    The green state of charge (SOC) bars (the upper two on my car) should not normally appear in city driving. The only time mine come on is on a mountain descent.
    You should be concerned if the SOC starts varying wildly (five bars or more) during normal driving, and if you start hearing the battery cooling fan (vent on right side of back seat) come on during normal driving.
    49,488
    how long have you owned, how many miles? i only get green occasionally, and usually on the highway. same with purple.
  5. lucasanderson298999
    27
    los angeles
    Owned since I bought it in 2008 and it has 110,045 miles. I use to always get the green bars no matter if I was in city or highway whenever I pushed the brake pedal. Now I notice they very rarely show up, so I expect it was a problem?
  6. lucasanderson298999
    27
    los angeles
    The green bars are never to the max nor are the blue ones. The problem is I never see the green bars anymore when driving in city or highway when I brake. They are always blue and one or two bars from the max.
  7. bisco
    49,488
    honestly, i don't recall anyone getting green bars when they step on the brake, unless the battery icon is almost full.
    maybe we're not understanding you. there are two purple bars at the bottom, 4 blue bars in the middle and two green at the top. most of the time, the battery should hover around 5-6 bars.
  8. lucasanderson298999
    27
    los angeles
    Sorry about the confusion.
    When I am driving and I am coasting or when I press the accelerator, the bars are always blue.
    When I press the brake the bars turn green.
  9. dolj
    dolj Senior Member
    7,653
    3,867
    Wellington, New Zealand
    I only get green bars (usually only 7th) when doing a lot of loooong coasting to slow/stop for lights on the highway. It can happen around town with the right topography, but I would never describe it as "as soon as I hit the brakes" in either case.
    It could be a sign of the battery ageing, but unless you get that graph rapidly cycling between purple and green over the course of a couple miles, I'd say you have plenty more miles before you are in trouble.
    If you wanted to pre-emptively look after the battery, you could invest in the Prolong charger/discharger set up (available here in the PriusChat Shoppe.
    Unless you get battery trouble codes (with corresponding dash lights), Toyota will say there is nothing wrong and to just keep driving as normal until you do.
    WilDavis likes this.
  10. lucasanderson298999
    27
    los angeles
    got it! that's so strange! It seems I'm the only one that gets the green bars as I'm braking. I thought everyone's 2008/gen 2 prius was like that...
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
  12. Moving Right Along
    Moving Right Along Senior Member
    690
    540
    My Prius battery meter is pretty much always at either 6 bars (blue) or 7 bars (green). The bars tell you the battery's state of charge. When you use regenerative braking, you recover some energy and increase the battery charge. Sometimes that's enough to go from 6 bars to 7 bars and sometimes not. Just like sometimes if the battery is at 7 bars, accelerating can take it down to 6 bars. But that doesn't always happen either.
    Bottom line: as long as the battery charge isn't getting down to 2 bars or bouncing between 2 and 6 bars every few minutes, everything is working fine. If you're not seeing green 7 bars as often as you used to see them, then you can coast longer before stopping to use the regenerative brakes and gain more battery charge if you want.
  13. lucasanderson298999
    27
    los angeles
    the main concern I had was how come the green bars weren't appearing as often as they use to and not really about how many bars were appearing per color. thanks for your input, it's helping ease this minor anxiety haha
  14. dolj
    dolj Senior Member
    7,653
    3,867
    I think you can fairly safely put this down to the HV battery is not what it was when it was new. No need for any anxiety, it is a natural progression.
    andrewclaus likes this.
  15. Moving Right Along
    690
    540
    My best guess is that your hybrid battery lost a little charge since you didn't use it for a week - just enough to make it so you don't hit green bars every time you brake now. While you don't want to leave the car parked in one spot for months at a time, this was a very small and minor battery discharge that's common to NiMH batteries. No worries. (y)
  16. lucasanderson298999
    27
    los angeles
    you're right! I just have to accept that time is taking its toll.
  17. lucasanderson298999
    27
    los angeles
    That makes sense. I'm going to try and not leave in the driveway for that long. Thank you!
    Moving Right Along likes this.
  18. bisco
    49,488
    i think you're car was broken, and fixed itself. happy motoring!(y)
  19. dolj
    dolj Senior Member
    7,653
    3,867
    Just to be clear my "coasts" to slow/stop involve using the brakes (very gently) to maximise regen, so I would agree with the "as I'm braking" because that is how it appears to me, some time as I'm braking I go from blue to green. The characterisation that you were seeing it turn green "as soon as I start braking" is what I don't see and was the point of my statement. The former is normal, the latter, not so much.
