Green Cell Phone
Discussion in 'Environmental Discussion' started by efusco, Mar 31, 2009.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Blue Earth solar self-charging touch screen cell phone.
    It's made with recycled water bottles and can maintain it's own charge via a PV on the back.
    Samsung Mobile World Congress 2009
    Blue Earth - World's First Solar-Powered Touch Screen Cell Phone - AOL Mobile Blog
    [​IMG][​IMG]
    * Solar Panel on the back of the phone
    * Eco- friendly phone made from recycled plastic extracted from water bottles
    * Free from harmful substances such as Brominated Flame Retardant, Beryllium and Phthalate
    * Eco-UI: Eco-mode / Eco-calendar / Eco-walk
    * 5 star energy efficient charger which uses standby power lower than 0.03W
    * Small and light package made from recycled paper
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Interesting idea. Now you need a hat with a holder so that your phone can get sun, except that would put the cellphone next to your head all of the time.
    I applaud the concept, even if some of the details are dubious. From a functional standpoint, it would be nice to have solar charging for camping and boating, but I think it would be difficult to get sun on the PV panel, since phones get tucked away.
    Tom
  3. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Cool idea. Should work fine if you're like me and use the phone on the way to- and coming home from- work. Obviously it wouldn't keep the charge while in a call but if there's enough sunlight between calls, it should work.
  4. efusco
    19,891
    1,196
    Nixa, MO
    I think one would clearly need to get into the habit of laying the phone down face-down. And I, too, would like to see a feature list. I suspect it may not have BlueTooth since that takes so much energy.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well that would be cool, except i use BT nearly all the time, so unless im in my car, i always have it in my pocket (saves me from leaving it somewhere...something that i did have to contend with more than a few times!!)
  6. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Bluetooth likely will be included since that is a very popular feature these days. Sure, BT will suck the battery down faster, but then again, if you're a chronic phone user, the solar cells aren't going to help you much anyway.
  7. taggart
    taggart Member
    249
    Very cool. I'll be watching for this to come out. Samsung is also coming out with a greener hi-def tv this year. They claim it uses up to 40% less energy than a hi-def lcd or plasma. Lcds and plasmas are energy hogs.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Too bad it wasn't powered by methane. I do know that when I make my "special recipe" chili, I could easily power my entire house just on my gas production
    I'm pretty sure if my "special recipe" chili concoction fell into the hands of terrorists, our way of life would be over
  9. icarus
    icarus Senior Member
    4,884
    976
    earth
    My new 42" samsung flat lcd uses ~1/3 the power of the previous 30" crt it replaced,,, while on. The lcd uses less than 1 watt when off,,, compared to 35watts for the crt. So I don't believe that size for size that Lcd's are energy hogs per sey.
    Icarus
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    I suppose the current crop of LCD tv's are energy hogs, compared to proposed developments. I just like not having to lug around what is - in essence - a giant vacuum tube
  11. qbee42
    18,058
    3,081
    Northern Michigan
    It could be worse. I have my big DLP TV with the high wattage projection bulb, the digital cable box that works like a toaster even in standby, a PS3 with its cell processor, the seven channel A/V amp, and last but not least the 1000 W subwoofer amplifier. I like winter because I can justify all of the heat.
    Tom
  12. hill
    8,996
    Worse than blue tooth, is wifi / web browsing. My PDA's 400mhz processor can suck the life out of the mongo oversized battery in less than an hour . . . but in a way it's still green . . . because it recharges via solar. Only difference is, the solar is on my roof :D
    Then there's the sun's deadly work on plastic. No such thing as non-photochemically reactive plastics. The up side is, who keeps a cel phone for more than 2 or 3 years now days? And those poor graveyard working slobs, they're s.o.l. ... can you tell that I hated working graveyard? End of tangent.
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    and whatever happened to that anyway??
    there was a Japanese company developing microturbines that were to run on butane. they were to generate electricity and initial project design was for laptops and later cellphones. the advantage was that you would never be without power since you would recharge then as easily as refilling a butane lighter.
    oh well, sounded too good to be true i guess
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    I knew it was too good to be true. Just with a few beers and my secret, sinister "secret recipe" chili concoction, I had a "perpetual motion" energy source
  15. ScubaGypsy
    ScubaGypsy Live Free & Leave No Footprint
    95
    Aquidneck Island, RI
    How about eliminating the battery altogether through the use of piezoelectric energy harvesting? These materials generate electricity through vibrations (and to a much lesser extent through pyroelectricity). Here's a link discussing recent research results as presented last week.
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i used to have one of those "self winding" wrist watches when i was a kid....
    now maybe that would work... just need to install one of those vibration proof hard drives, or better yet!! just get flash memory instead... uses waaay less power..
    probably could do for under $10,000!!
