Greenland has a 'heat wave'?
Discussion in 'Environmental Discussion' started by bwilson4web, Jul 25, 2012.
  1. bwilson4web
    16,011
    Source: Satellites see Unprecedented Greenland Ice Sheet Melt - NASA Jet Propulsion Laboratory
    Just another curious, unrelated to climate, totally random, ordinary 'summer'. Yeap, no 'hockey sticks' here folks . . . move on:
    Just God's Zamboni machine smoothing another ice ring. <grins>
  2. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
  3. bwilson4web
    16,011
    I wonder if there is a peer reviewed analysis of ice cores that documents the 150 year average cycle?
    Regardless, here is an interesting article that begins to tie climate and weather changes:
    Source: Arctic Warming is Altering Weather Patterns, Study Shows | Climate Central
    I'm equally interested in the Antarctic weather and climate. We already know the lower latitude glaciers and ice fields have significantly decreased. The Arctic ice sheets are also thinning with more sea exposed in the summer to absorb solar energy. But Antarctic ice shelves have also had some impressive changes over the past couple of years. More Southern oceans exposed to sun light should also show a similar amplification. It is sometimes easy to forget the Southern hemisphere.
  4. bwilson4web
    16,011
  5. icarus
    icarus Senior Member
    4,884
    976
    earth
    Just as an aside, "watts up with that" is a site promulgated by a TV weather man,, with no climate expertise at all.
  6. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    Bob,
    God's Zamboni, indeed.
    The prior record melt years in the satellite data were 2010 (1) and 2011 (2). So this is just best viewed as continuation of short-term trend. I think what made news is that the interior surface flipped from frozen to melting in just a few days. That seems to be an entirely new phenomenon in the satellite era.
    Related:
    Ice-albedo feedback - Wikipedia, the free encyclopedia
    Greenland Ice Albedo Monitoring - Byrd Polar Research Center - Research Wiki
    Apparently the albedo reduction is now about twice what the average general circulation model anticipated. So add warm air temps to the sunshine falling on the darker surface, and you get more melt.
    The second article talks about the large 2012 albedo anomaly in the interior/higher elevations. There was this really unusual darkening of the interior portions of the ice sheet surface in 2012 (look at the first spaghetti graph in that article), now there's unexpectedly rapid surface-wide melt. Maybe concidence, maybe not. Maybe I have causality reversed here. But two off-the-chart events, seems plausible these would be related.
    Here's the albedo graph. This is higher elevations, black line is 2012. So the albedo change preceded the unusually widespread and rapid conversion of the frozen surface to melting surface.
    I've seen it written (without having seen any research to verify it) that the greater incidence of North American wildfires is depositing enough additional soot to make a difference. No idea whether that's true. (It's true that wildfires deposit soot there, it's unknown if that's enough additional soot to matter.) But if true, it's a feedback from persistently high wildfire years to persistently higher melting.
    As the snow melts, it differentially leaves the soot, so the surface gets progressively darker with more melt, independent of the effects that the melt lakes have.
    Ice-albedo feedback is one of the things Hansen points to when he suggests that the scientific consensus substantially underestimates likely sea-level rise for this century.
    bwilson4web likes this.
  7. Zythryn
    Zythryn Senior Member
    6,406
    4,403
    Mojo, there defiantly are natural cycles, just as there have always been natural forest fires.
    Just because something in the past has a natural influence doesn't mean mankind isn't currently having an influence.
    The most telling statistic to me is the ratio of record high temperatures to record low temperatures.
    As to this thawing, it is being studied to see if we can figure out what is happening. This is good news,isn't it?
  8. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    The quote about the arithmetic is from the Nasa Goddard press release and is on the Nasa website.
    Pretty funny those dumb nice person scientists cant do the math.
    NASA - Satellites See Unprecedented Greenland Ice Sheet Surface Melt
    ""Ice cores from Summit show that melting events of this type occur about once every 150 years on average. With the last one happening in 1889, this event is right on time," says Lora Koenig, a Goddard glaciologist and a member of the research team analyzing the satellite data."
  9. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
  10. bwilson4web
    16,011
    LOL!
    Actually it was a math test for deniers:
    • "once every 150 years" - this was the bait since deniers desperately seek some cycle to explain unusual weather and climate observations
    • "the last one happening in 1889" - this was the hook knowing 2012-1889 = 123 years, 27 years early, . . . humm, global warming
    Face it, you got 'punked' by NASA. At least CBS did the math on their evening news broadcast. <grins>
    Just as we've reverse engineered how Consumer Reports rates cars based upon the prius c review, the same approach works with global deniers. After all, anyone who can deduce patterns from data has a wealth of data from global warming deniers. Compared to a climate model, deniers are trivial.
  11. austingreen
    austingreen Senior Member
    13,635
    4,177
    Austin, TX, USA
    Unprecedented means in this interglacial this is the most warming we have seen in greenland. There was more of a melt in the last interglacial, but that was long ago.
    mean means average, as in a statistical average. The variance of these cycles accounts for the 18% off this time. That 150 year cycle is from nasa, and it is a word problem. The reporting should be more clear that the period is statistical and not fixed.
  12. austingreen
    13,635
    4,177
    Austin, TX, USA
    These things do cluster. That is not a statistical anomaly.
    We would not expect an event that happened in 1889 to appear in the satelite record. That would truely be unprecidented.;)
  13. tochatihu
    tochatihu Senior Member
    9,548
    3,683
    Kunming Yunnan China
    2001 Prius
    Hoping we might sort this out w/o rancor, but I'm still confused. Revkin helpfully shows a figure from Science 1994
    Some of those other “unprecedented” melt events at...
    In the GISP2 core, a low annual accumulation is 0.23 m (firn or snow?) per year, and a high year is 0.265. If this is the basis of the 150-year cycle, that is 150 +/- LARGE.
    I don't know how to relate that annual accumulation to the current situation in Greenland. I know there is fast surface melting now, but what about the previous season's input?
    Also I had hoped to post a link to annual forest burn area in US, but the NPS website is inaccessible to me just now. Perhaps because it ends with .gov From time to time, US gov websites are blocked for me here :rolleyes: It comes and goes.
    What I recall is that about 1910 there was a big fire and some fire fighters got toasted. This (in part) led to the policy of extensive fire fighting. This has led to more dry surface fuels and 'ladder fuels', such that when you have a dry year and some ignition source, the chance has increased that the fire will get very large. As we have seen (but not every year) over the recent decades.
    In the longer term, annual burn area seems to relate to ENSO phase. In some regions, ENSO + is dry while for others, ENSO - is dry. Fires happened then. Fire-scar studies in the southerstern US also show big burns in the mideval climate anomaly. Recently re-renamed the mideval warm period based on Lappland trees. Both topics discussed here earlier.
    The last few decades have put a lot of soot in the air, but I cannot say that it is unusual in context of prehistoric fire.
    austingreen likes this.
  14. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    I dont know exactly what NASA means by "unprecedented" .But I do know its an exaggeration meant to fool the media and the public.
    There is certainly evidence that there has been greater warming during most of the past 10,000 years.Thus a melt every 150 years would virtually guarantee a greater melting precedent .It would be greater melting occurring very many times over the past 10,000 years.
  15. tochatihu
    9,548
    3,683
    2001 Prius
    if anyone here is more interested in fires than 'today in Greenland'...
    http://www.fs.fed.us/psw/publications/skinner/psw_2012_skinner001.pdf
    New, but regional. You have to connect the other dots (open circles) figure 2, to see the annual burn are, only since 1987. Also, note the logarithmic axis.
    Figure 4 is also increasting, with >50 year fire rotation intervals in pre-settlement times. Interesting stuff - those old-growth forests had frequent, low intensity fires. The rest of Figure 4 is kinda scary, presuming that I understand it. Older and older forests having massive burns until 1985. Then? ? We finished buring off the (few, heavily protected) old growth and now burning younger trees? In any case the 1985 transition looks remarkable.
  16. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    I dont particularly mind off topic posts,but since you scolded me in the past for supposedly being off topic,I will point out that fires were already off topic in a different thread.
    At least you could keep the off topic posts to the same originating thread.
  17. icarus
    4,884
    976
    earth
    I wonder what it will take for Mojo to realize that human action is causing dramatic climate change? Will it take two more years,, or ten, or twenty? How far down the road will we be by then?
    Icarus
    richard schumacher likes this.
  18. bwilson4web
    16,011
    Thanks!
    I was hoping someone might find the source of that rather strange "150 year" cycle. There may be a source but that was not evident in the original report. I don't think we've found it either. But then I thought about from another point of view . . . humor.
    Hypothesize that climate deniers have behaviors that can be modeled. For example, seeking any discussion forum about the environment and reactively citing climate denier "Readers Digests" rather than source papers with direct observations. Alternatively, the random "I drive a gas guzzler, no emissions" as if that is something new. Then there is someone whose math dealing with satellite data had some errors (my earlier posting sprung the math error trap.) Of course my favorite is the FOX commentator that a snow storm 'proves Al Gore is wrong.' These behaviors are as predictable as the behavior of many emotionally, not empirical, critics (and the Prius has had more than its share.)
    So let's go back to the original article, the full quote:
    Here we have one location where the ice cores should show the history of the "150 year" cycle. Happily, there is a credible source for this one location. But when you step back from the primary source, the wide-spread melt over all of Greenland, something not easily observed until satellites, well you begin to see this one data point was injected to imply it may occur over all of Greenland. It added nothing to the primary observation ONLY the "150 years on average" is also 'bait' for those who quote out of context and don't do grade school math.
    Science and our discussions are full of such traps that allow (beg?) those with an 'ax to grind' to latch on to something out of context. This is so common in Prius critics as to be a tell . . . if our Prius discussions were a poker game, we would within a short period of time know 'who is the goat.'
    I welcome review of the Summit core, to see what this '150 year' cycle looks like. But add to that the other cores and lets see if there are evidence of Greenland wide, surface melt (unlikely since only one location was cited.) In fact, the technical details of this melt begs the question of how melt events are seen in the ice core (yes, I like technical stuff using neat tools.) But I also laugh at "Three Stooges" and "Laurel and Hardy" gags.
    So when a climate skeptic quotes out of context, it is an opportunity for humor . . . to pull their chain. Lazy posting behavior laid it out with a sign that invited the fun. It isn't rancor as much as my love of the classic gags and applying them to current situations. <grins>
  19. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    OMG you are in deep doodoo dude,like over your head in doodoo.
    The article you originally posted, gave reference to the 150 year occurance.
    The woman scientist quoted gives a reference to a peer reviewed study by Alley as her source.
    Ill give links if you are to lame to find them.
    Jeesh.
  20. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    "2:10 p.m. | Updated | Lora Koenig of NASA just sent this note providing the reference underlying her comment about past summer melting episodes at the summit (the spot on the giant ice sheet least vulnerable to melting):
    The study I am citing is Alley and Anandakrishnan, 1995, “Variations in melt-layer frequency in the GISP2 ice core: implications for Holocene summer temperatures in central Greenland” published in the Annals of Glaciology for establishing the long-term frequency of melt events at Summit , Greenland. And Clausen et al., 1988 Glaciological Investigations in the Crete area, Central Greenland: A search for a new deep-drilling site also published in Annals of Glaciology for an early reference to the 1889 melt event though as mentioned in the press release Kaitlin Keegan and her advisor Mary Albert at Dartmouth University have more recent research on this event and please contact them for additional specific information.​
    My comment shows that melt events have occurred at Summit in the past and I have quoted the longest-term average frequency of ~150 years (exactly 153 from the paper) over the past 10,000. Since this is an ice core record that frequency is for the location of Summit only. The frequency ranges from ~80 to 250 years over different sections of the GISP2 ice core, please see the paper for specifics."​
    Jason dinAlt and bwilson4web like this.
