GreenTec's Upgraded 45Ah Prius Plug-in Battery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Proximity4082, Nov 2, 2025 at 12:52 AM.
  1. Proximity4082
    Proximity4082 New Member
    Virginia
    Hey, just wanted to ask if anyone had any thoughts on GreenTec's Upgraded 45Ah Prius Plug-in Battery (the standard battery is about 22Ah), which seems to provide double the range of the standard battery. It's advertised for about $4,500. Would you say it is more worth buying this w/ a Plug-In Prius or just going straight to the Prime?
    Any other details and thoughts would be helpful either way.
  2. PriusCamper
    PriusCamper Senior Member
    12,579
    5,090
    Pacific Northwest, USA
    #2 PriusCamper, Nov 2, 2025 at 1:59 PM
    51,757
    i'd go to a prime before your head gasket blows. and prime should be 2018 or newer
    Brian1954 and BiomedO1 like this.
  4. BiomedO1
    BiomedO1 Senior Member
    3,389
    1,762
    SacTown, Ca
    ^ Yep, gen3's had too many issues. IMHO - better to upgrade with ALL OEM equipment, rather than a patch-work. Great when the system is working, but a nightmare when it isn't, and everyone is pointing fingers at each other.
  5. jacktheripper
    jacktheripper Senior Member
    264
    534
    Wow… it looks like GreenTech copied NexPower’s webpage and possibility the product too — even the section on “how to take full advantage of the extra capacity.”
    The difference is, NexPower’s cells are 55Ah and still about $1,000 cheaper. I’d definitely recommend going with the original instead of a copycat — you’ll get better value and likely save a lot on shipping too.
    PriusCamper likes this.
