Greetings from a confused newbee!!!
Discussion in 'Newbie Forum' started by gsesupport1, Apr 14, 2008.
  1. gsesupport1
    gsesupport1 FLLRUP
    :mmph: I have an 05 prius and I am getting what I consider crappy GPM 38 strictly city driving total commute 2 miles. We drive the car everywhere we go and the GPM just doesn't increase. I started out getting about 51 in the city and ever since then have steadily decreased the GPM. I did notice that when I replaced the tires with my o so favorite manufacture Firestone my GPM decreased from 49 to 38. I took the car to the dealer for it's 30K check and they said everything is working the way it is supposed to. Are there any suggestions for increasing the GPM? I did try to inflate the tires a little more but my wife complained that the car seemed to float. Please help me out here.
    gsesupport1
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's the tires and the short trips. There is not much you can do about short trips, other than combine them, but you can use LRR tires.
    Tom
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    1.) Short trips is the ultimate killer. Whenever I start a trip I lose MPG for the first 10 minutes, after that the number usually continually climbs until I reach my destination.
    2.) Low Tire Pressure could be the culprit, try inflating your tires up a tad higher, Try at least 38 PSI or higher.
    3.) Try to keep the Climate control turned off for the first 5 minutes, that will help as well.
  4. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    As others have said it's your short commute. I tend to get about 25mpg or so the first 5 minutes of driving. After that it will climb to the low 50's. When your car first starts it will run the engine to warm itself and the catalytic converter up to temperature. While doing this the engine will run very rich which causes the decreased fuel economy. In reality all computer controlled cars do this. MPG decrease is just noticed a bit more on the Prius since mpg is more in your face in the Prius.
  5. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    Or ride a bike and avoid those trivial distances altogether. That's the best option. 2 miles? You can do that on foot in 40 minutes, on roller blades in 20 minutes, or on a bike in 12 minutes (at speeds where you won't get sweaty in morning temps). Why use a car?
  6. gsesupport1
    gsesupport1 FLLRUP
    Okay, I spoke to the tire dealer today, they are willing to replace my bridgestone EL400T with what ever tire I want at no charge, currently the size on the car is 185/65R15. I have read alot about tires here on the forums, but what is the best tire that can go on the car to give back my MPG. I would ride a bike to work but I never said I made the short trips it is my wifes car, now we all know she is not going to ride a bike in a dress to work everyday.
    Where can I find information on the REVS and LRR for different tires?
    Thanks again
    gsesupport1
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Tire Rack - Your performance experts for tires and wheels has been recommended often.
