Greetings Prius C owners~ Joined to find-EZ fix for loose black rubber seal (roof drivers side)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Marlene Munroe, Aug 7, 2023.
  1. Marlene Munroe
    Marlene Munroe New Member
    2016 Prius c
    Love my Prius C, 2016 three model. love the DIY ez fixes for changing filters, vacuuming the 3rd one and keeping my baby in tip top shape. Just stopping in to learn how to DIY my top rubber seal, drivers side rooftop loose issue! Not a huge problem overall.
  2. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    Congrats and welcome. I hadn't heard of this seal problem. Any chance you can share a photo that shows the problem?
  3. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    If it's the rubber strip that runs in the drainage channel over the two doors on top of the car, I had the same problem. I believe its just a friction fit and can be pressed back in with your fingers. If that doesn't work, there may be clips on each end that need replacing. The only time I had issues with mine was after going through an automatic car wash. The brushes loosened it up. Pushing it back was all that was needed.
    If that's not it, please explain further.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    If it IS that rubber strip and fills the channel meant for mounting a rooftop luggage rack........
    then you have two choices:
    Get a new one from a dealer. Actually get both and replace both sides as they shrink with heat and age.
    Or get some body emblem cement or silicone RTV and glue it back in place in a few spots down along
    each edge.
    It only snaps firmly into a clip at each end.
  5. ElSteverino
    ElSteverino New Member
    Kansas
    This was a problem on the drivers side of my daughter’s 2013, I put some butyl tape under the section that lifted up and she hasn’t had a problem since. I can’t post a link, but search Amazon for “zxmt butyl tape”. I used the stuff that looks like a black cord.
    good luck
