Grill block without scanguage?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dipstick, Mar 9, 2009.
  1. Dipstick
    Dipstick New Member
    17
    Alberta Canada
    Hey all, I'm a new prius owner in Alberta Canada. I've been reading about the methods of grill blocking, but most of the instructions talk about monitoring the temperature via the scanguage.
    Our weather here is at -15 to -25 deg C right now, and I thought I could increase my mileage. However, in this area, the temperature swings between cold/warm spells. By the end of the week it could get to 10 deg C or even more...would it be safe to grill block at these temps seeing as I don't (yet) have a scanguage, and can't monitor engine temp?
    Cheers,
    Bruce
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    For town driving, temps up to +10 C should be ok with a winter front. Once -15 C and colder, highway full winter front is fine
    If it worries you, just block off the upper grille slits. Leave the lower grille open, this is the part of the rad for inverter cooling
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I've kept the upper grill blocked year round. The lower is blocked 80% until the summer. Never heard the fan start.
  4. Dipstick
    Dipstick New Member
    17
    Alberta Canada
    Ok, thanks.
  5. 3xJ
    3xJ Junior Member
    canada
    I have been using a complete grill block this winter and got SGII recently. Now after seeing the numbers I would not block completely for highway if not colder than -15C. Today at -10C my coolant was at 95C constantly with a complete block. When I opened one of the five openings on the lower grill the temp varied between 80-90C which I believe is the normal range without the fan. However I never noticed the fan starting with the complete block. How do you know if the fan is on?
  6. jayman
    13,439
    640
    Winnipeg Manitoba
    I can hear the fan from inside. Eg in summer with the A/C, I can also barely hear the distinctive whine of the variable speed electric A/C compressor. I have *good* hearing
