Grill Blocking - how much for Minneapolis....
Discussion in 'Prius c Accessories and Modifications' started by Hodgempls, Oct 9, 2012.
  1. Hodgempls
    Hodgempls New Member
    Minneapolis
    I purchased my Prius C last weekend (coming from and Aveo 5 HB) and I did get the block heater installed. I was wondering about blocking the grill as well and was curious if I should just do the bottom portion? Or do both the top and bottom? Temps are falling fast......
  2. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    I have my whole grill blocked right now
  3. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    I suspect Prius c strategy will closely resemble the regular model. In that case, block the lower-grille entirely once the you see temperatures like we are seeing now... highs around the mid-50's.
    I leave my upper-grille open all year long, even in the extremes we see come January. Others block it though.
    Let us know what you learn. Having an aftermarket gauge of some variety to observe operating temperatures is very informative.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Minneapolis... I would stuff fur coats in the engine compartment. ;)
    Welcome aboard by the way!
    Revan86 likes this.
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    Please be aware there are two radiators, engine coolant radiator and HV inverter coolant radiator.
    The normal temperature of the engine coolant is approx 190F (88C) and the inverter coolant temperature is cooler is better.
    Please refer to Gen3 Prius Grill Blocking strategy.
    The inverter coolant radiator on Prius c is located at the bottom same as Gen2 Prius.
    Therefore, my recommendation is leave the lowest part of grill open in the mild climate.
    Ken@Japan
    Hodgempls and [email protected] like this.
  6. john1701a
    12,754
    5,245
    57
    Thanks for the info! What I suspected wasn't right then. Using the "block all the upper and most of the lower" strategy for Gen2 would indeed be better than what we do for Gen3.
    Hodgempls likes this.
  7. Hodgempls
    Minneapolis
    I appreciate all the info. Blocking the grill is my project for tonight.....
  8. mjHession
    mjHession New Member
    43
    Let us know how it turned out when your done. what method are you using, and could you post any pictures?
