Grill blocking in mild winter temps
Discussion in 'Gen 3 Prius Fuel Economy' started by kalome, Oct 28, 2012.
  1. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I finally got around to this and the RXD is 4008 not 4808.
    I wanted to mention in case someone else reads this post and tries to program it in.
  2. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Ooops! Sorry about that. Thanks for the correction.
  3. Codyroo
    Codyroo Senior Member
    1,826
    510
    Pleasanton, Ca
    So, what kind of inverter vs outside temps are you seeing?
  4. Codyroo
    1,826
    510
    Pleasanton, Ca
  5. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Let me get back to you on that. When I tried to program it, it wouldn't work. So later I looked it up on the X-Gauge spreadsheet and saw that the RXD is supposed to be 4008. I got sidetracked and never reprogrammed it.
    I'm at work and will reprogram it at lunch, then on the way home i will let you know.
  6. markabele
    5,084
    1,777
    Nebraska
    In very basic around town (slow and go) type driving I'm seeing around +10 inverter temps compared to outside temps.
  7. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Went out for lunch. On the way back ICF was 89 and went as high as 93. Stayed mostly at 91.
    Temp outside right now is about 75F
    Edit - I haven't grill blocked yet. So I will compare when I do.
  8. markabele
    5,084
    1,777
    Nebraska
    Based on my own anecdotal evidence...blocking the lower grill should have virtually no impact on inverter temp.
  9. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    Kalome, be careful with the extent of grille blocking you do. I blocked my lower grille 100% and during normal around town and highway driving my FTW only went from 193F to 195F. Then I noticed that on the long uphill section of my highway commute (65+mph) my FWT went up to 202F then would cycle to 198F then back to 202F. That was in 66F outside temps. That is too hot for my liking and if the fan is turning on then you are using energy.
    When I got back to work I removed two slats of foam and the air inside the bumper smelled like hot plastic. Not a burned smell but like heated plastic. I've been driving around with the lower grille 50% blocked now and the temps don't go higher than 195F.
    FWIW at 40F ambient temps the water temp stayed around 195F. It was in 66F ambient temps that I noticed a problem. :(
    My upper grille is not blocked at all and probably never will be.
    kalome likes this.
  10. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Thanks for the input. It has been very warm this past week so I haven't even grill blocked yet. Still debating if I should or not. I bought the pipe insulation for it but not sure if I'm going to use it.
    In the Phoenix Valley it doesn't get that cold here. The only real noticeable benefit may come only in December and January. It may not be worth the trouble and the worry. Maybe I'll just see how I do without grill blocking.
  11. markabele
    5,084
    1,777
    Nebraska
    I just finally put my last piece of foam in and now I'm 100% blocked on the bottom. Justin is right, 100% blocked is really for temps where it never gets above 40 or 50 and you don't have any sections of road where you have to push the engine very hard for very long.
    IMO 100% does a lot more than 75%. At 75% there is still a decent size area for air to get in/out. Wait another few weeks and try 50% on the very bottom. Super easy to do and super easy to take in and out once you have it cut. I would just suggest to take them out if you know you will be pushing the engine for very hard/long.
    F8L and kalome like this.
  12. Codyroo
    1,826
    510
    Pleasanton, Ca
    I added my third piece of insulation, which effectively covers the lower grill, except I have gaps on either side to let air in as well as the upper grill (unblocked).
    I've smelled the "warm plastic" smell once or twice after doing this. Not sure what is causing it. The engine temps were 195F and the inverter was within 20F of ambient. For what it is worth, I have seen the engine temp get up to 197F going uphill with the extra blocking. I may remove it for now, but when the morning temps drop (consistently) into the 30's, it is going back on. I like being able to turn on the heat sooner (and with my scan gauge, I can run it at 82F...toasty) while I run up the freeway and up the Dublin grade. Once coming down the other side, it has to go off, because of the long descent and then the slow and go awaiting me at the bottom.
    I won't be blocking my upper grill either.
    F8L likes this.
  13. mtbiker53
    mtbiker53 Junior Member
    87
    22
    cape cod
    Thanks for all that,guys....only thing is,got ICF on gauge screen,but no numbers.
    Steve
  14. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    You must of entered one of codes wrong since it is not displaying the numbers. Try it again.
    TXD: 07E22175
    RXF: 046105750000
    RXD: 4008
    MTH: 00090005FFD8
  15. mtbiker53
    87
    22
    cape cod
    Yup,one to many zeros....
    Thanks again.....steve
    This forum is one reason I bought a prius.
  16. Rbimd
    Rbimd Junior Member
    Indiana
    I drive 45 miles to work each day, 85% interstate. I had been averaging 50-51 mpg with max speeds of 75mph and 55mph average, tires 42/40. November temps dropped into the low 30's and my mpg dropped 4-6 points. I topped up my tires which were down 4psi due to temp and picked up about 2 mpg. Then i tried grill blocking 85% lower, 50% upper and my mpg instantly improved to 54-56mpg, which is better than my summer mileage! I only monitor coolant temp with DashCommand, so i've been thinking of removing the upper blocking entirely because i can't monitor inverter coolant temp, but radiator temp never exceeds 196F. the Ambient/intake temp difference, which is usually 4-7degrees increases steadily to 20-25deg especially after exiting interstate and resuming city driving, which worries me though if the invertor coolant temps behave similarly
  17. Tim Bender
    Tim Bender Member
    134
    44
    FWIW I was monitoring temps with 100% block back I'm October on a 70f day. Coolant temp went above 200f only once after a steep highway climb. I think you are safe to block at the levels recommended by [email protected] without monitoring, and you might be safe to exceed those limits if you monitor temps closely. Ice only, I. Do not block inverter because I don't monitor the temp
    ThunderBolt ? 2
Loading...
