Grill blocking on the C
Discussion in 'Prius c Accessories and Modifications' started by Revan86, Sep 18, 2012.
  1. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    Hey guys
    Does anyone know much about grill blocking on the Prius C?
    I have found a fair amount of info grill blocking on other cars but not the C. I don't know that all the info translates to the C but for all I know it's all the same. As his is the first winter the car has been in the US I don't know if anyone has really done it yet. Any and all input would be helpful.
    Thank guys and gals
  2. dellrio
    dellrio Im pretty much awesome
    281
    88
    37
    Des Moines, IA
    I would be interested in this as well, based on my hobbies (snowboarding) I do significantly more winter driving than most people, some grill blocking to help the engine get warm and stay warm would be nice.
    Revan - if the info you found regarding Grill blocking was for the GenII prius it would probably apply here given they use the same powertrain. That being said I doubt the grill openings are the same size so it may take some measurements of both openings to determine a good adjustment rate.
  3. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    Get a scangauge (or similar) so you know what normal engine coolant temps are, so you can judge how much is too much. (100% may not be too much)
    On the Gen 2, you could not see the inverter coolant temp, so folks were MUCH more cautious blocking the inverter radiator. If this is also true of the C, be sure you know where the inverter radiator is, and don't block it 100%.
  4. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    Here is what I have done, I live in Northern VA. I made grill blocks for the upper and lower grills. Only have the upper installed until it gets cooler. Made the grill blocks out of plastic and covered in left over vinyl from blacking out my front bumper. Attached to the grill using toggle bolts. All materials bought at Home Depot for approx $12.
    Plastic Sheets were "4' Solid Gutter Covers
    Toggle Bolts were 2.5" x 3/8" (2 to attach the top Grill and 3 for the bottom Grill
    Found this on the web looks like the inverter is on top
    For Uppper Grill
    1 Created a template using clear plastic sheets taped to front of car
    2 Traced to the gutter cover and cut to shape
    3 Test fit to grill and trimmed for better fit
    4 Drilled holes for toggle bolts and final fit to grill
    5 Removed from grill and covered in 3m flat black vinyl.
    6 Attached to grill and covered screws with vinyl
    For Lower Grill
    1 Measured grill size (30” x 4.5”)
    2 Traced rectangle to gutter cover and cut
    3 Drilled 3 holes for toggle bolts
    4 Attach and test fit
    5 Covered in Vinyl
    6 Will attach to grill when temps drop below 45F
  5. Revan86
    286
    84
    First off I'm in no way shape or form telling you grill block you Prius C. You should just drive your car the way Toyota built it.
    With that said this is what I've done
    Sorry for that bad pics lady's and germs. I have used pipe insulation. Cost was about 97¢ for 6 feet.
    A full uncut bit and a per cut bit.
    I have a scangageII and monitor my coolant temp. Per blocking the grill I saw temps around 188-195 on my normal drive. Now that I've blocked it has gotten up to 202 at the highest so I am guessing its ok. It has really really helped my morning mpg as it has been pretty cool and has hurt my mpgs. It had been really hard for me to get it to a " measly " 65 mpg. Now that I've blocked it I'm back up to low 70s. I know as it gets colder it will go down again but even if I can post pone it a few days I'm happy with it. I'm hoping some one will be able to give me a max temp I can let the car get up too. image.jpg image.jpg image.jpg image.jpg
  6. Revan86
    286
    84
    Sorry from the. Repeat pics :-/
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Frost King comes through again. I run blocked to one degree or another almost all the time. Coolant temp isn't the concern and seems to be fairly predictable. The concern is inverter temp which varies by use. I don't know if any of the xgauges work for the c. Expect the inverter temp to be OAT +20F.
  8. mjHession
    mjHession New Member
    43
    Regarding the xgauge, I believe the Gen III PIDs work for the C.
    On the topic of Grill blocking, does anyone else have some other methods to share. I'm not sure I want to drive around with pipe insulation shown on the front of my car. Could someone explain the gutter method above in more detail?
  9. Revan86
    286
    84
    Yes I would like to know a little more as well. It's was more of a cheep proof of concet sort of thing. Although with the color or my car and the color of the grill and the color of the pipe insulation it's not really noticiabl unless you point it out to some one.
    Still my guys at work make fun of it a bit ya know.
  10. filipinoof07
    filipinoof07 Junior Member
    66
    Thanks for the post. I made my mod today. We'll see how the milage improves.
  11. indycatcarol
    indycatcarol Junior Member
    Here is my grill blocked.The other day before the grill was blocked when it was 68 I was getting46.5 mpg. The last couple days with the grill blocked with the outside temp being mid 30's I'm still getting 46.5 mpg where it had been 43 mpg in such cold weather. I'm only making 10 mi. round trip excursions since I've done this so if I were traveling a longer distance would I get better mileage? I haven't driven it since the temp. is now upper 20's. If I covered the grill below the Toyota logo would that help? I used the 3/4" tubing. (My daughter said it looks like hair rollers. LOL!)
  12. 1945steve
    1945steve Junior Member
    68
    southern indiana
    I used black Tiger Tape and completely closed the bottom grills. We were down to the high 44's by then and now we're back up to the high 48's. On a couple of warmer days recently (low 60's) the trip mileage indicated 58+ on a 38 mile one way trip. Normally I would have gotten around 53 on that same trip.
  13. Hybrid Effects
    Hybrid Effects Junior Member
    97
    Orlando, Fl.
    Hybrid Effects does have a prototype grill block all ready made for the Prius C but I have not released any photos yet because we have no released the product yet. It is a very nice product and it looks like something the factory would have made and it is flush with the lower grill opening and will help with aero dynamics im sure, but it is a complicated part to make due to the reverse angles incorporated from the factory into the bumper. So the molds have to be two piece molds , Like every thing else with quality and good workmanship to make a nice product there is more time and money to achieve a good product. The only reason we have not released the product for the prius C is that the car we were using to prototype the parts the sponsor whos car we were using the guy vanished.
    note: We assume no responsibility for the grill blocking products we sell but we have sold lots of grille blocks for the second generation prius with and with out vents and i have yet to hear one problem from the second generation owners, one guy told me he uses his grille block year round in Texas.
    koipond likes this.
  14. Hodr
    Hodr Junior Member
    23
    Noticed your website appears to be down / broken. Did you ever come out with this product?
  15. Fauxknight
    Fauxknight Active Member
    210
    116
    Getting back into winter so this is relevant again. Been meaning to post this for a bit since I did most of my grill a couple of weeks ago.
    Cost: <$3
    Tools Needed: Scissors
    Time: 5-10 minutes
    Used 1" pipe insulation, two 6' lengths was more than enough, I still have spare to finish when the temps drop more severely. On the bottom each length is clamped across two slats, if you do them singly use a smaller diameter insulation and get an extra 6' length of it. On the top I double wrapped each slat so that it would cover better and hold more solidly.
    It seemed to hold temp much better right off the bat. Had a couple of 30 and 40 degree days and even some October snow (that's two months earlier than normal for us), MPGs seemed to hold steady enough. I didn't have my C last winter, so I admit that I'm not familiar with what kind of drop off I'm looking for.
  16. teevzees
    teevzees New Member
    Flint, MI
    I tried the 1/2 inch insulation. It left unintentional gaps in the upper grill. I intentionally left a gap on the passenger side upper grill directly in front of the ICE intake.
    I've only driven for an hour since adding the insulation. The results are very promising. It is 54° here today and the MPGs are equivalent to a day in the 70's.
    I will post photos shortly.
    I couldn't upload the photos from my android phone but here they are. 6368-1.jpg 6369-1.jpg 6370-1.jpg 6372-1.jpg
    #16 teevzees, Dec 4, 2013
    Snowball likes this.
  17. Flying White Dutchman
    4,374
    313
    hey guys
    where in the prius c is the ice and inverter radiator? upper or lower grill
  18. olieman
    olieman Junior Member
    Netherlands
    upload_2014-11-28_11-27-11.png The attached drawing clearly shows the layout of the Prius c inverter cooling water system, it shows that the inverter radiator is situated at the bottom.
    Text in Illustration
    *1 Inverter Water Pump Assembly *2Inverter Reserve Tank Assembly
    *3 Inverter with Converter Assembly *4 Radiator Assembly (HV)
  19. GregP507
    GregP507 Senior Member
    3,002
    480
    It's easier to use cardboard to control the airflow at the radiator, than trying to block the grill. Also, cardboard is easier to adjust, so you don't overheat the system.
  20. john1701a
    john1701a Prius Guru
    12,769
    5,252
    57
    Cardboard? No! The mess it becomes after getting wet doesn't even remotely compare to the foam pipe insulation... which is water & salt proof and only has to be touched once the entire winter.
