Grille Shutter Inoperative and Check Engine
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Kremtok, Jul 18, 2016.
  1. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Greetings,
    Relatively new 2016 Prius Four with all the boxes checked was working just fine this morning. At the end of the work day I got in the car to drive home and I got a warning - 'Grille Shutter Inoperative Visit Your Dealer' - accompanied by a check engine light.
    Since I'm a little over 200 miles from a dealership I'm in a bit of a spot. They have a local shop that they contract with but they can't get me in until Thursday.
    Has this happened to anyone here before?
  2. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    I'd peek down at the front and see if the shutters are open or closed. If they're stuck open, not that big of a deal.
    CR94 and fuzzy1 like this.
  3. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    They are open, but is the check engine light related to or independent of the grille shutters?
  4. fuzzy1
    10,170
    Can you read the CEL code to find out?
    I'll vote with MrMischief -- if the shutters are open, then no need to quit driving or rush to service at an inconvenient time. Closed shutters would be a greater concern.
  5. Tideland Prius
    16,155
    CEL usually is a "catch-all" light. It doesn't literally mean check the engine. It's there to indicate a malfunction. Fortunately for us, Toyota included a multi-info display that tells us the error (in this case, your active grille shutters).
    fotomoto likes this.
  6. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Thanks for the replies.
    After sleeping on it I was able to approach the problem with a clearer head. I had a buddy get in and start the car while I watched the shutters and the problem was immediately apparent. When they installed the block heater before delivery, they routed the cable through the grille shutters, which stopped them from closing. The only question that remains is why it took 311 miles for the problem to manifest.
    Anyhow I rerouted the cable and the problem is corrected. Now I just need to get the code read and cleared and everything will be peachy.
    bisco and Mendel Leisk like this.
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Since the dealer is so far away, try your local auto parts stores. They can usually read (some hybrid codes) and clear them. If it comes back, then a trip to dealer is called for.
  8. booke02
    booke02 Active Member
    391
    415
    Israel
    Glad to hear a happy end to the saga.
  9. Mendel Leisk
    38,727
    Good sleuthing! Maybe Toyota should put out a service bulletin on this.
    RCO likes this.
  10. fuzzy1
    10,170
    Many codes should self-clear after a certain number of Ignition-On cycles without the problem reappearing. This ought to be one of them.
    kithmo and fotomoto like this.
  11. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Only a dealership knuckle dragger would route a cord through the louver vanes. Seriously stupid.
    Anyway, I'd wager that nearly every possible failure mode on those louvers is to default open.
    m.wynn likes this.
  12. Mendel Leisk
    38,727
    To be fair, these active grill shutters are new and pretty rare. For sure let the dealership know, for next time.
    m.wynn, kithmo and fuzzy1 like this.
  13. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Thanks guys. I notified the dealership so they can change their installation practice. With 30 or so Priuses on the lot right now, they may even have to correct the installation on a few of the cars they have in stock.
    For the record, the check engine code was P05A0, which I understand is 'Active Grille Shutter Stuck On.' A buddy had a port reader so I just cleared it and it's all good now.
    MrMischief likes this.
  14. Arturas
    Arturas Junior Member
    Vilnius, Lithuania
    Hello, guys! I have the same problem here in Lithuania. I get the message "Grille shutter inoperative. Visit your dealer". But the problem is that grille shutters are available at USA market only and it's hard to get the piece (curtains and motor) here in Europe. Even though, it cost's about 500 EUR. I'm not sure if I need this "Grille shutter" as it is unnecessary for my eco-friendly driving.
    So maybe someone knows how to disable the error message, because it pop-ups every 4-5 seconds on my screen. How can I tell my Prius: "You don't need Grille shutter. You look better without it, babe"? :)
    Christov Tenn and RCO like this.
  15. bequa
    bequa Junior Member
    26
    Tbilisi, Georgia
    Hello Arturas,
    Have you found any workaround ?
    Has anyone idea of motor resistance? or ways of spoofing it?
  16. bisco
    49,492
    you folks have grille shutters on the 2004 and 5?
  17. sillymike
    sillymike Junior Member
    59
    GA
  18. bequa
    bequa Junior Member
    26
    Tbilisi, Georgia
    @bisco
    Lol no, its 2016 Pri, profile info is outdated.
  19. bisco
    49,492
