Grinding noise and grooves in front brake discs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nate_F, Dec 30, 2016.
  1. Nate_F
    Nate_F Junior Member
    25
    Idaho
    I've been noticing grinding coming from the brakes recently in my 60k-mile 2012 Prius 3. I read that there is a known rear brake problem but my vin didn't match any known issues in the Toyota Recal and Service Campaign page.
    To me, it sounds like the general grinding noise is coming from the front. The pics below seem to correlate.
    Any thoughts? Why are both front discs grooved while both rear discs are smooth? I haven't had it serviced yet and wanted to gather some information first.
    Front (both passenger and driver sides are grooved. Haven't seen the inward facing side yet):
    Rear (both passenger and driver sides are smooth. Haven't seen the inward facing side yet):
    From farther away (front):
    From farther away (rear):
  2. Mendel Leisk
    38,729
    When did you last have a brake maintenance? The US interval for thorough brake inspection is 3 year or 30K miles.
    49,500
    the front brakes do more work i believe. not sure why so much grooving, how much left on the pads?
  4. Tande
    Tande Active Member
    502
    302
    Mich.
    IMHO.....something not "Normal" going on.......especially at 60k......got a 100k on mine & they look like they're good for another 100k......FWIW
  5. bisco
    49,500
    some have shown early wear due to corrosion and lack of attention to inspection and lubrication, as mendel mentions above.
  6. Mendel Leisk
    38,729
    Yeah I'm speculating caliper pin lube has dried up, not allowing the caliper to float; that the brakes have never been opened up.
    If it's messed up enough a preemptive set of fresh pads, clean-and-lube of all contact points and the pins, and removal-and-burnish of the rotor might solve. If wear is uneven, they'le likely be noisy for the next week, till they settle down.
  7. Tande
    Tande Active Member
    502
    302
    Mich.
    My bad......I was ASSUMING proper maintenance.......I do know better.....:ROFLMAO:
  8. Nate_F
    25
    Idaho
    There's no maintenance required at 60k for the brakes (just inspection).
    A tech just told me he used brake cleaner on the discs and stomped the brakes a bit an the grinding noise is apparently gone now. Pads are at 50% in the front and 60% in the back. He said the grooves weren't out of normal and were probably caused by rust buildup.
    Doesn't make much sense to me to see grooves like this.
  9. Nate_F
    25
    Idaho
    I don't fully understand it, but the rotors are much smoother to the touch now. Pad-colored rust bands maybe?
  10. Mendel Leisk
    38,729
    Maintenance, inspection, don't get muddled with the language.
    Every 5000 miles or 6 months they're to be "visually inspected", and every 3 years or 30K miles is the in-depth inspection (aka "maintenance"). Whatever it's called, the calipers are supposed to be pulled, calilper pins lubed, pads/shims cleaned and inspected, contact points cleaned and lubed, disc thickness/runout checked to be within specs.
    Check your Warranty and Maintenance Manual.
  11. Nate_F
    25
    Idaho
    Interesting. Those points are not mentioned in the 2012 Toyota Prius Warranty and Maintenance Guide.
  12. Mendel Leisk
    38,729
    First instance page 41.
    It's your car. If the dealership has convinced you it has miracle brakes, what can I say.
  13. bisco
    49,500
    the whole car is almost a miracle.
    Montgomery likes this.
  14. Nate_F
    25
    Idaho
    Nope.
    I never said that. I mentioned trends which another user on this forum agreed with. Also, the results in this case were that the brakes and discs were fine (it was just gunk build-up).
    lol
  15. Mendel Leisk
    38,729
    Have you ever had the calipers off? All the chest beating aside, I'm thinking it's the caliper pins drying up. With 60K on the odometer you should have had the in-depth service (aka inspection, aka maintenance) twice now: every 3 years or 30K miles.
    One thing, Toyota documentation is poor, shows the soup-to-nuts breakdown of the brakes, doesn't differentiate well: visual inspection, vs complete maintenance, vs complete caliper overhaul. Honda is better in this regard: their Shop Manual have specific section, say brake service, and walk you step-by-step through what's required.
    Still, this stuff is pretty much biblical, never changes.
    #15 Mendel Leisk, Jan 5, 2017
  16. Nate_F
    25
    Idaho
    That makes sense.
    I'll try and take a look at the pins when it's not 0 degrees here. The place I took it too wasn't very specific on what they did with their "Brake Check" other than they measured the pad thickness so I don't know if they even took the caliper off.
  17. Mendel Leisk
    38,729
    Zero Fahrenheit? Ouch! It's been stubbornly below freezing here in lower mainland BC, not like that though.
    I'm gonna do our front brakes come spring, when taking the snows off.
    If you DIY it's safest to disconnect 12 volt negative cable and isolate it, before opening anything up. Before reconnecting when everything is reassembled , push brake pedal multiple times. This avoids possility of car detecting excessive pedal travel, throwing a code.
    Raytheeagle likes this.
