Grinding noise up front when stopping?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MP3gee, Nov 5, 2020.
  1. MP3gee
    MP3gee New Member
    There is a very loud metal like grinding on the front of my nieces 2009 prius, pulled both front tires off & rotors are not ate up and plenty of pad left.... Any ideas? I have yet to check the codes because when I went over there today the battery was dead from sitting too long. We put a charger on it & I should be back over there tomorrow to run the codes....
    49,469
    maybe soething caught between a pad and rotor?
  3. MP3gee
    MP3gee New Member
    I seriously doubt there is something caught between pad/rotor. I'm just wondering if the back brakes may have tricked my brain into believing it was the fronts?
    49,469
    definitely a possibility. sounds can be difficult to trace
  5. Moses Bruh
    Moses Bruh Member
    97
    29
    spend the time to pull the caliper off and really check the brake pads for any issues? Also lift the car up and get under and take the time to visually check the entire front area for anything that seems off.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Entirely possible.
    Also possible that the rotors/drums have some surface rust from sitting idle so long.
  7. oldtechaa
    oldtechaa Active Member
    336
    222
    NZ
    2013 Prius Alpha
    The bearings are another possibility to check.
