Grinding while Driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bcrisp, Mar 27, 2023.
  1. Bcrisp
    Bcrisp Junior Member
    Washington
    Hey everyone! Im in need of a little help. My gf has a 2010 Prius with a 170,000 miles on it, its a great little car, but it makes a 'grinding' noise while driving. I was thinking it might be the cv axle, but turning it doesnt seem to make the noise any worse or better. I put it up on stands today and put it in drive and it made the same noise. It gets louder as the vehicle increases speed, but doesnt seem tied to the engine (when its in neutral and you give it gas it doesnt grind). She said that it has been going on a long while, with no clear indication as to when it started. She said it was quieter at first and her ex told her he didnt hear anything, he must have been deaf cause it is very loud and you can feel it in the peddle.
    Anyways, I plan on getting back underneath of it on Friday to change the tranny fluid and hopefully have a better idea of just what is actually wrong with it.
    Here are two links to it:
    Driver side
    Passenger side
    regards
    Brent
    #1 Bcrisp, Mar 27, 2023
    52,390
    wheel bearing?
    Bcrisp likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Trade the girlfriend in, no more cAr issue
    Bcrisp likes this.
  4. Mendel Leisk
    41,900
    Unrelated, but have to ask: have you cleaned the EGR and intake manifold?
    Bcrisp and Grit like this.
  5. ChapmanF
    18,541
    Another distinctive sound I haven't heard before. I might also guess an oddly and especially progressed wheel bearing, but that's just a guess.
    I'd probably proceed by making the same videos but with the tires off ... and then the same videos but with the rotors off (put something the right thickness and hard between the caliper pads, so the brake system's self-test doesn't disassemble the calipers) ... and if the sound is still there, then think about the bearings.
    Bcrisp, douglasjre and Grit like this.
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    BAM!!!
    Bcrisp likes this.
  7. Bcrisp
    Washington
    Thank you everyone for responding! I was under it yesterday, and more than likely is the bearing. I changed the transmission fluid and did the brakes (both needed to be done). While I was under, I had her give it a little gas and the noise seemed to emanating from the passenger side wheel bearing. So next week, I’ll pull it and see a shop can pack a new bearing for me.
    And I haven’t done anything with EGR, or intake manifold.
    bisco and Mendel Leisk like this.
  8. Bcrisp
    Washington
    Again, thank you for everything! It was the bearing. I was very surprised that it was a whole unit and not the wheel and hub type. So relieved that I didn’t need to find a press!
    I suppose next I need to do the EGR valve. Any guides that are better than others?
  9. bisco
    52,390
    check mendels signature above ^
    Bcrisp likes this.
