Groaning sound after I stopped the Prime
Discussion in 'Prime Main Forum (2017-2022)' started by Roy2001, Apr 3, 2018.
  1. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    I searched but could not find anyone complaining about it.
    Whenever I stop the car, either in garages, parking lots or before red light, it would give some weird groaning sound. 1-10 seconds after I stop the car. Has anyone noticed it?
    It is pretty loud, not like from mechanical parts, but not like from speaker either, but I can clearly tell it is from the front part of the car, inside. It is pretty annoying.
    52,393
    it might be normal, can you record it?
  3. bwilson4web
    16,369
    It is me pissed that I didn't have further to drive. Oh, your car? I don't know.
    pilotgrrl and priuscatprimeguy like this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    My guess would be the fuel system releasing the pressure once off. Pearl S does this.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    My dog in the backseat does this every time I pull into the garage.
    When my mechanical brakes are cold, they groan and moan a bit till warmed up. There's also the brake pressurizing sounds that are fairly loud and gen 2's have the thermos bottle sounds but the OP says all the time. Are you sure it's really all the time, every time? If so, that's not normal and you should have a dealer look/listen to it.
  6. David Beale
    5,963
    1,989
    Edmonton Alberta
    Well my car does it every time. Most describe it as a "fart". And I'm pretty sure it's the fuel system venting into the canister.
  7. bisco
    52,393
    also, you should change your vehicle info.(y)
  8. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    At least since Gen 2, Prius' have made odd sounds after shut-off.
  9. Diemaster
    Diemaster Active Member
    295
    262
    so. cal
    does it do it when pressing on the the brake? it could be the vacuum pump to produce the vacuum needed for the brake booster.
