Grooving Heads for increased efficiency??
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Justdidit, Feb 12, 2013.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Being from KS, I found this interesting. Anyone care to chime In their $.02?
    FARM SHOW - Grooving Heads To Save Fuel Catching On Fast
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Obviously its not NEW news... just new to me. Wonder how the 1NZ would fair with a grooved head...
  3. bobeast
    bobeast Junior Member
    39
    23
    But wait, there's more! Order now and we'll double your order. 40% fuel savings + 50% more power. I think somebody ought to get Toyota on the phone :)
    roflwaffle likes this.
  4. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    haven't tried it but i think port matching (not grooving) is better since the airflow will be smoother and unobstructed. that is if it really needs matching.
  5. bisco
    49,513
    is there a reason auto mfg's wouldn't do this in the factory?
  6. Agent J
    294
    111
    Sydney, Australia
    i'm not sure.. but there are instances where the intake ports don't exactly match with the ports in the head. It wouldn't be the case for high-performance cars, i guess, since the engineers would've taken that into account. But for normal mass-produced cars, the there might be slight unevenness when the parts left the casting process. And for economies of scale, the intake runners might even come from a different supplier which could share the same part with a different type heads as long as they generally are within the volume tolerances set by the engine designers. lots of sample images from the web.
  7. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
  8. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    I'm certainly, going to pay attention. I tip my hat those brave souls that try it.
  9. wjtracy
    wjtracy Senior Member
    11,326
    3,593
    Northern VA (NoVA)
    ...directionally sounds like some of the advantages that a hybrid (Prius) naturally gets via use of the Atkinson cycle ICE engine design.
  10. a_gray_prius
    2,927
    782
    IL
    So there's this epic thread showing a Spanish "tuner" making a dangerous modifications on a Mitsubishi Eclipse with a 4G63T. It's discussed here: Car Lust: When tuning goes horribly, horribly wrong and here: Spanish "tuner". Enjoy - Page 14 - Mitsubishi Lancer Register Forum
    He puts "sin" grooves in the head. Based on discussion about this, I've gathered that the grooves are meant to improve the distribution of fuel/air in the chamber. However, this is unlikely to be effective in modern engines which have much better characteristics (and no longer run on carburetors - that's how old this idea is).
    tl;dr version: Don't do it. Send pictures of your blown engine if you do.
  11. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Like my favorite book that was never written,
    "Genius Mods for Prius Dummies"
    by Hugo First!
    LOL
  12. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Yes.
    Notice that they don't do this? There's your answer.
  13. wjtracy
    11,326
    3,593
    Northern VA (NoVA)
    ...grooves not the path to zero emissions either, I am sure
    dbcassidy likes this.
  14. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Operators are standing by for this special offer! But, only if you order in the next ten minutes.
    Seriously, in order to groove the heads, the most pronounced improvement would be decarbonizing (IE: cleaning the heads) of the built up crude in the combustion chamber. That would help improve easier starts, slight increase in mpgs and more pep. The grooving is something that I never heard of in all the engines I have rebuilt over the years. Porting and polishing the heads can help with more power as well as milling to raise the compression ratio.
    If this grooving is so wonderful, it would have been incorporated in many vehicles on the road today. It probably would have first started on the racing circuits, then expanding into production vehicles. I have not seen any of this grooving.
    DBCassidy
  15. dbcassidy
    1,581
    290
    I think combustion / air flow would be hampered by these grooves. Combustion chamber design today is about getting the most power, using a little fuel as possible, and meeting emissions.
    DBCassidy
  16. dbcassidy
    1,581
    290
    Another thought, grooves introduce sharp edges (thermal issues) and cavities the can capture and hold carbon buildup.
    DBCassidy
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
  18. PriusGuy32
    1,417
    511
    Harrison Township, Michigan
  19. 2007blueprius
    2007blueprius Member
    461
    30
    you are kidding right, I cant imagine who would have been the first to think of that and why.
    granted combustion chambers are shaped for a purpose, I cant see in on this "groove"
  20. maestro8
    471
    109
    nor cal
    It gets better... the guy took a pipe tap to the intake ports!
    Grooved Metro number 2
    I think this is a testament to the Geo 3cyl engine. If it can take that kind of abuse and still run as well as is claimed, that's some solid design!
