Ground Clearance Different in '10?
Discussion in 'Gen 3 Prius Main Forum' started by global, Jan 22, 2010.
  1. global
    global Junior Member
    Maryland
    Have an '04 with 90+ looking at getting a '10. Read all the ground clearance threads but dont see where anyone says definitively if there is a difference in older vs newer.. Bottom line-'10 at dealer looked lower than my '04. Did not ask and now I am home and cant compare. Does anyone know? It matters to me as I have a cabin in West Virginia with gravel roads. '04s been ok but a little lower could be an issue.
  2. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    The specs for my 2010 car say 5.5 inches.
    Compare that with the specs in your owner's manual.
    I've got a gravel driveway that tends to get rutted, and the 2010 is OK.
    In other threads where folks have asked about unpaved roads, one suggestion that is regularly given is to rent the car for a day or a few and try the road. Hope that you get some rain so you can do it in bad conditions.
  3. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    I swear I am hooking that front bumper on things more often......
  4. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
    I have already scratched the underside of the front bumper on a parking lot cement "curb" or whatever you call those things. Have to be careful not to pull too far forward.
  5. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    I haven't hit any of the standard height curbs yet with ours. So I don't think it's any lower than any of the other imported cars I've owned.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Specification, minimum running ground clearance: Gen2 = 5.6 inches; Gen3 = 5.5 inches
  7. global
    Maryland
    Ha-I knew it was lower! (Just kidding-.1 inch. ) Thanks. :)
  8. Zanrok
    Zanrok Casual Prius Lover
    176
    27
    Reno, NV
    I was doing some digging around and I noticed the 2012 ground clearance is now 5.3.
    So it seems the Prius is shrinking... from
    5.6 in the Gen 2
    5.5 in the Gen3 2010,2011
    5.3 in the 2012.
    Wth? :(
    I am starting to get worried as every little bit helps with driving around in the snow. Anyone else notice this?
  9. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    I'm betting that is a unloaded car....put in 2 adults and a few grocery items....what would it be then.
  10. Mendel Leisk
    38,709
    If a dealership has any on the lot you can check it out yourself: just stand a tape measure on it's end and extend the tape till it's brushing the underside of yours. Likely somewhere in the middle of the engine bay would be the nadir, but look around.
    Then repeat at your dealership, with the new model. Maybe let them know what your up to, LOL.
    And then there's debatable underside: if it's steel support framing, jutting out, vs more flexible and uniform aero panel. The latter is likely a little less prone to hang up in deep snow.
