Ground Wire Between Radiator & Grill?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by R_W, Apr 27, 2019.
  1. R_W
    R_W Member
    82
    25
    Based upon the replies and conclusions to my previous query, I was looking under my 2010 to prepare for flushing the coolant, when I found a wire dangling underneath with a clip on the end. My instinct is that it's a ground wire, so I clipped the end to the grounded metal as it was obviously supposed to connect and followed the shielded wire up, to where it connected to something I couldn't quite see without taking things loose at the top, beside the hppd latch.
    I'm sure somebody know what this ground wire grounds. Instead of putting effort into finding out on my own, I thought I'd take the easy way out and make a searchable post to ask.
    Thanks
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Pics?
    R_W and Grit like this.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Or it didn't happen...
    R_W and Raytheeagle like this.
  4. padroo
    padroo Senior Member
    2,763
    2,252
    Your question is like asking where an unknown road goes in southern Florida.:)
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    But I love these type of post, we throw a lot of wandering answers & suggestions. If not, how would I get quotes for my signatures?!
    Could be a left over ground clamp from a removed fog light install.
  6. R_W
    R_W Member
    82
    25
    Tried to take a pic, but I can't really get a good one in the dark.
    My car only has one wire that goes down, pretty close to the center of the radiator on the front side. (Sort of like Alligator Alley in South Florida crossing the Everglades, LOL) Looks like it comes from something eight inches or so to the driver's side of the latch. It's in a ribbed casing that goes over to the center, then straight down to where it connects to a clip that's clearly supposed to slide over something, I assume metal as a ground, but maybe it clipped into something different before.
    (If I were to describe it, the clip is like one you'd use to connect two wire sets together, like the ones on an old fuel pump or inside the door for an electric window, except this clip is made of metal)
    When I found it, the clip was pretty much dangling, so I slipped it where it looked like it should go.
    Maybe I'll try again for a pic in the morning. Glad I could provide some amusement.
    #6 R_W, Apr 27, 2019
  7. Elektroingenieur
    2,515
    3,287
    Three Touring
    The ▽ Location of Ground Points illustration in the Electrical Wiring Diagram (more info) shows that the six chassis ground points in the engine compartment (A1, A2, A3, and A4 on the Engine Room Main Wire, and D1 and D2 on the Engine Wire) are all bolted connections, and none is near the location you describe.
  8. orenji
    orenji Senior Member
    5,887
    3,488
    Loose horn wire?
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    What I was thinking as one possibility...
  10. padroo
    2,763
    2,252
    That far forward I would say usually lights, horn and maybe an airbag sensor but I am not sure where they are located.
  11. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    That's the external temperature sensor. Where it looked like it should slide over and clip in place is exactly where it's supposed to go.
    ETA: It's easy for that to fall off, mine has done it before. Just clip it back on and go.
  12. padroo
    2,763
    2,252
    Ambient Temp Sensor Location. I didn't know this.
    Vman455 and R_W like this.
  13. R_W
    R_W Member
    82
    25
    Thanks! Confirmed via @padroo's video. That's it!
    Vman455 likes this.
