Grounding Amp?
Discussion in 'Gen 2 Prius Audio and Electronics' started by genoman, Mar 4, 2007.
  1. genoman
    genoman New Member
    Newbie here,
    Where have others who installed an amp in the truck space compartment grounded thier amp? I bolted it to the metal that goes across the opening of the trunk compartment, just behind the back battery. Is this a good place or not?
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Should be fine. Any metal chassis part is ground.
  3. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    I added a grounding lug (available from any good custom auto audio shop) and attached it to one of the
    bolt down-flanges on the HV battery. See picture below.
    Cheers
