GST installed wrong bumper protector - fix or ditch?
Discussion in 'Gen 3 Prius Main Forum' started by ggood, May 24, 2009.
  1. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    OK, apparently the people at GST are not quite up to date on the Prius accessories. Instead of the correct rear bumper applique, I got what you see below. Should I make them fix it or live with it? My wife says its not that bad.
    3 people like this.
  2. sluday
    sluday New Member
    251
    16
    Jersey Shore
    If it was free then leave it. I you paid for it then raise hell and get some free stuff in return.
  3. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Hmm. Do you like it? If you like it, then keep it.
    If YOU don't like it but you WIFE likes it, then I'll not make any additional comment.
    My assumption is that the clear applique (with the Prius logo in it) was part of your bargain. If so, then simply call in to make arrangements for the correct part to be placed on your car. It really isn't a matter of "demanding" it -- the dealer should recognize a wrong and be very happy to correct it.
    If not, just take it up the chain of command. They'll make the correction.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The "applique" should be transparent vinyl. What was the code on your Moroney sticker?
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    "Not that bad" isn't what you want when you paid good money for a new car. I'd have them remove it and install the correct applique.
  6. a priori
    3,083
    407
    23
    Chicagoland (West)
    Monroney Label. :) (See Dept. of Justice writeup on the law that requires the window sticker.)
  7. nineinchnail1024
    nineinchnail1024 New Member
    280
    40
    New Orleans
    I actually like it. You could definitely slide boxes from Sam's Club in and out of there.
  8. Zaxcom
    Zaxcom Member
    114
    NC
    What is the model number of the clear one.
    I know BP30 is the black one? i want to make sure i order the correct one.
  9. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    I like it too, I'd leave it.
  10. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    It seems like it would be much more durable than the film applique.
  11. agentred
    agentred New Member
    59
    I think it looks good with the gold colour, it matches the tinted windows. It would've looked bad if it was white or something, but the black works.
    Final decision rests with you, but I'd mention it to the dealer and use their apologetic goodwill towards your next service check up or accessory purchase.
  12. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    I've always thought that the black vinyl bumper protector both looked better and protected much better than the not-so-clear applique -- and it's cheaper to boot.
    But if it's not what you want ....
  13. SW03ES
    2,480
    176
    Gaithersburg, MD
    Absolutely, if its not what you want and it bothers you, you should take it back and have them correct it. You paid over $30,000 for the vehicle, and it should be as you specified.
    However, should I succeed in getting the wife to relinquish her '04 for a 2010...I'll be getting that bumper protector thanks to your pictures.
  14. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Given my skill at abusing bumpers, I would want the sturdiest bumper protector available. Short of some nice diamond plate, that looks like it will do the job.
  15. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    My wife made the same comment about it matching the tinted windows. It's growing on me, mostly because I don't want to be bothered fixing it. I have doubts they could really get it off cleanly anyway. Also, it's a legitimate point that the big embossed PRIUS on the applique might be regarded by some as being a bit cheesy and unnecessary.
    Oh and thanks everyone for commenting. I was just sort of on the fence and looking for feedback on how other people thought this looked.
  16. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I think this thick rubber protector is most durable than the 3M film appliqué and it cost more. You got a bargain if you only pay for the appliqué.
  17. HTMLSpinnr
    5,339
    917
    251
    The applique isn't embossed, more just "etched" and really has to be seen at an angle to make out the wording at all.
  18. hntr467
    hntr467 New Member
    22
    Rockford, IL
    I think it looks just fine. It really depends on what you want, and how you plan to use the car. Myself, I would always try to avoid resting anything on the rear bumper without a protector like yours. I see the transparent one as a precautionary measure to avoid damage when someone inadvertently rubs or rests something on top of the bumper. Regardless, just like others have already said, if you decide it isn't what you want, then they need to make it right with you. Don't compromise, get it the way you want it!
  19. Boo
    5,051
    483
    97
    Flushing, NY
    It's easily done if they know what they're doing (I know that's a big IF for the dealer). Body shop people do it all the time.
  20. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I'm afraid I don't like the black -- but if you are getting used to it, then it's probably easier to keep it.
