Gurgling exhaust noise
Discussion in 'Gen 4 Prius Technical Discussion' started by mpg1, Jan 15, 2026 at 12:16 AM.
  1. mpg1
    mpg1 Junior Member
    Northern Michigan
    I was wondering if I'm hearing what could be the infamous faulty heat exchanger leak on my recently purchased 2016 Prius. Although the antifreeze levels appear to be full, this evening I noticed a "gurgling" sound coming from the exhaust. The car has 69k miles. There's also a bit of a sulfur/rotten egg smell coming from the exhaust and I thought I could smell exhaust fumes when I started it this morning (which prompted the other observations). I've literally had the car for a day. If it IS the heat exchanger it looks like the car is out of the tsb time repair allowance. I'm attaching a video of the gurgling noise https://youtube.com/shorts/RWTvBZYkJB4?si=-FnvnSC5jkFV8pQm
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,248
    6,398
    Texas Hill Country
    Just watch the coolant reservoir very carefully every day for a couple of weeks.
    Smelling exhaust on a cold start is normal especially if you are standing behind the car.
