Guys what should I do?! Prius or Honda Fit??
Discussion in 'Newbie Forum' started by Nate Byrne, Jun 15, 2014.
  1. Nate Byrne
    Nate Byrne New Member
    27
    Longmeadow, MA
    Hey Please hear me out on this.
    I want to buy my first car soon, and I'm in LOVE with the Prius. I have found an 06 with 69k miles ($10k), and an 07 with 89k miles ($9k). BUT I have become paranoid that the transaxle will break and cost me thousands down the road...
    I have found a 09 Honda Fit forsale ($10k) with only 61k miles.
    So my question is.... Do transaxle failures happen fairly frequently at this mileage? Should I really be concerned? Will a Toyota mechanic be able to spot a failing transaxle before I make a purchase? What do you guys think??!!
    Thank you so so much :)
  2. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    Nate Byrne - Greetings. Here is my 2ยข Worth.
    Do transaxle failures happen fairly frequently at this mileage? No.
    Should I really be concerned? No more than about the running gear in the '09 Honda Fit.
    Will a Toyota mechanic be able to spot a failing transaxle before I make a purchase? If the mechanic is competent.
    Assuming everything being more or less equal with these three car purchase candidates. I would purchase the '07 @ $9K & 89K-Miles. The '07 Prius improved/fixed a couple of flaws in the '06 Prius, and the Honda Fit is much smaller than is the iconic 2G Prius Hatchback Sedan. Bottom-line, even with studied caution in buying a used car, it is a crap shot. Good Luck.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Transaxle failure is extremely rare in the G2. I have an 07 and nothing has gone wrong with it in 7 years except a front wheel bearing.
    Prius is extremely reliable. if your stuck on transaxle failures (not even sure why) just be hyper vigilant about fluid maintenance. Alot of us are and we change out the trans fluid every 30,000 miles at a cost of 4 quarts of fluid=$40.
    Btw, Prius is commonly used as a Taxi. Please go to this blog and read about it from the Prius Taxi servicer:
    lusciousgarage.com
  4. Nate Byrne
    27
    Longmeadow, MA
    Ok guys thanks! Some additional info I saw on the carfax that I think is worth noting.... The 06 Prius with 69k had a PCV valve replaced at 68k miles, and a battery replaced at 39k miles ( I assume this is 12V?). The 07 Prius has no records of these being replaced - and I'm assuming the cost of this maintenance is ~$500. What do you think?
  5. JC91006
    16,673
    8,518
    Pcv valve is not an issue. carfax only reports services done at the dealer, it could have been done elsewhere and not on carfax.
    Remember carfax is not complete, tons of things are done away from the dealer that's not recorded. Best to ask for physical records, don't just rely on carfax
    SM-N900P ?
    Merkey likes this.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Check if a tow hitch was installed in those Priuses. If not, check if ATF was ever changed. It is not necessary but it is good if you see previous owner changed it on record.
  7. bisco
    51,155
    i wouldn't worry anymore about the prius tranny than the honda. on the plus side, a good mechanic can replace the tranny with a junk yard dog for cheap money.
  8. ibmoses
    ibmoses Junior Member
    109
    22
    Are these cars for sale by dealer or individual?
    Any idea how many previous owners?
  9. Nate Byrne
    27
    Longmeadow, MA
    06 has 3 owners. First sold it at 12miles, second drove it less than 6k miles/yr for 7 yrs, next owner drove it 20k miles in 8 months. 07 has 1 owner.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    PCV costs less that $10 and is a simple install in a tight space.
    If money is so short OP, Wth are you running to the dealer for repairs/maintenance you can do yourself ?
    #10 SageBrush, Jun 15, 2014
  11. Nate Byrne
    27
    Longmeadow, MA
    Money is not so short - and I am not "running to the dealer for repairs". I'm looking at the carfax and seeing what as been done, figuring out which car is less work for me and has been taken care of. RELAX.
  12. ibmoses
    109
    22
    I would go for the one owner if it looks and drives like it has been well maintained.
  13. Nate Byrne
    27
    Longmeadow, MA
    The 07 Prius felt more 'rough' to me, the 06 felt brand new to me.
  14. JC91006
    16,673
    8,518
    Brand new feeling is a good feeling. Have you driven new to compare?
    SM-N900P ?
  15. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    You can't go wrong with a Prius!!(y)
    You will be very HAPPY with a Prius!!:)
  16. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    MA (Mass) is a CARB state so you get extended CARB warranty to 150000 miles and 10-yrs.
    But you need to make sure it qualifies Toyota will disqualify depending on registration history in other states, and depending on when MA joined CARB. I think MA has been part of CARB long time so as long as it was always registered MA. Toyota does reserves the right to disqualify the extended warranty based on out-of-CARB ownership or purchase, so best way to verify would be check VIN with dealer.
  17. Nate Byrne
    27
    Longmeadow, MA
    The Toyota dealership selling a the 06 Prius was originally registered in NY, then CT. They said it would still qualify under the warranty. The one-owner was always in MA.
  18. Nate Byrne
    27
    Longmeadow, MA
    Also, is the transaxle covered under the CARB extended warranty?
  19. JC91006
    16,673
    8,518
    I think you shouldn't worry so much about the transaxle, it's a very reliable cvt transaxle. I don't believe there are many reported failures.....especially before 150k miles.
  20. Nate Byrne
    27
    Longmeadow, MA
    Okay thank you so much!! :)
