H.I.D easy as 1 2 3
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Gwest, Feb 9, 2010.
  1. Gwest
    Gwest Member
    97
    Redwood City
    This is 1/2 of the HID kit[​IMG]
    There is 2 plastic clips under the fender and 4 10 Mm bolts. Un do them and bend back the inner fender like this
    I took out the fog lamp because I couldn't get the HID bulb installed right. The lamp is held in with one philips screw. come out in just a second.
    This is the Back side of the HID ballast. I put some 3m trim tape on the back side of the ballast and stuck it to the bumper support.
    Here is a pick of the stock on the left and the HID on the right
    Here is what the HID bulb looks like it fits right into the stock lamp
    FOGS OFF
    FOGS ON
  2. Gwest
    Gwest Member
    97
    Redwood City
  3. Gwest
    Gwest Member
    97
    Redwood City
  4. boppo
    boppo Active Member
    799
    138
    Owego, NY
    sweet!
  5. SDM44
    SDM44 SeƱor Member
    199
    38
    Los Angeles
    what color range HIDs did you use? How well did they match the LED headlights? From what I've seen when looking at the LED headlights on another V, the 4300K is a little too yellow looking and 6000K is too blue looking, and 5000K-5300K seemed to match pretty well.
  6. nieveser
    nieveser Junior Member
    32
    Portland MI
    Very nice job! I would like to know also which color temperature did you used. Is it 6000 K?
  7. Gwest
    Gwest Member
    97
    Redwood City
    SD44: I agree the 4K seem a bit Yellow. I have 8K and you can see they are Blue. So if you were like 5 or 6 k you might be closer to stock color. I didn't care that my Fog's were not the same color as the stock LED lights. Driving around town I didn't notice to much of a diff. It's when you get away from city light's or in dark areas or places or you have a over hang it makes a diff.
  8. ajc
    ajc Member
    340
    38
    pa
    I want to get a HID kit and replace my low beams. Carhidkits has a HID kit from AGT. They said that I will need a harnes because the factory bulb is 55w and the HID is 35w. The harnes needs to be conected to the battery. Do I need to run the + & - to the battery in the rear or is there somewhere in the engine bay that I can hook into?
    By the way the Toyota dealer told me not a good idea to put a HID kit on?? :mad:
  9. Gwest
    Gwest Member
    97
    Redwood City
    Hummmm The stock H11 bulb draws 55 watts and there is no problem.
    The Aftermarket HID kit draws 35 watts, (25 watts less). I see no problem with hooking the power from your stock fog lights to the new hid kit. Un less your pulling 35 watts at some elevated amperage
  10. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    4300-4500K will match the OEM LED headlights and have the most light output.
  11. Fussion101
    Fussion101 Junior Member
    81
    NYC
    its the power required at startup that you should be worried about.
