Featured H2Go Power Stores Hydrogen as a Solid?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by kenmce, Jan 4, 2020.
  1. kenmce
    kenmce High Voltage Member
    1,527
    502
    NY
    Interesting tidbit from the BBC. Story is long on happy happy optimism and short on technical information. Story focuses on drones,not cars, but other uses are obvious. Presented here in case they really do have anything:
    H2Go Power seeks to power drones with a 'happy gas' - BBC News
    "In a lab deep in the basement of Imperial College in London, a young team has built what it believes is the future of air travel. H2Go Power is seeking a patent to store the explosive gas cheaply and safely.
    Until now, storing hydrogen required ultra-strong and large tanks which could withstand pressures of up to 10,000 pound-force per square inch (psi). That is hundreds of times greater than what you would find in a car tyre. But, while studying for her PhD in Cambridge, Dr Enass Abo-Hamed came up with a revolutionary structure which could store hydrogen as a stable solid without compression."
    "Hydrogen generates three times as much power per kilogram compared to fossil fuels - approximately 39.0 Kilowatt hours per kilogram compared with roughly 13 KWh per kg for kerosene or petrol or just 0.2 KhW for conventional lithium ion batteries."
  2. PriusCamper
    PriusCamper Senior Member
    11,055
    4,498
    Pacific Northwest, USA
    Looks like a person in a lab just did way better than Toyota did at advancing hydrogen fuels...
    austingreen likes this.
  3. Trollbait
    11,504
  4. hill
    8,153
    iirc - doesn't hydrogen have to be (heat pumped out) cooled down below ~ -420°f just to go from gas to liquid? .... and even then, it has to be pressurized to ~190psi ? Now you need more energy to go solid? And that doesn't count the cost of maintenance on the massive chillers/compressors? In the article, she suggests reforming hydrogen through electrolysis (TONS of electricity) because clean power is getting cheaper ... meaning instead of 3 or 4x the cost of conventional power - maybe some day, it will only be 2x as expensive. Or ... to put in her own words;
    If the hydrogen auto lobby has been promising, "in 10 years" - tons of affordable hydrogen cars running across the US - and it's been since the 1970's that the promises began, & continually reset ... i shudder to think how long 20 or 30 years will really be for THIS science project. i hope our tax dollars aren't funding this cash sink, on top of the run-of-the-mill hydrogen sink.
    .... another nit to pick - the researcher gal makes a disingenuous statement when she says;
    she fails to mention the power of varying fuels has a limiting factor - the size & shape of the fuel storage medium. Hydrogen often require over 15x as much space to store. When adjusted for THAT little bit of truth (same size containers), hydrogen suffers a bit of lost benefit;
    of course - in the make believe world of solid hydrogen ... maybe it's as good as dino juice, some day. Of course, in 30 years (discounting the NEXT solid hydrogen clock getting reset again)? Just think how powerful battery storage will be per pound & per cubic foot by then.
    #4 hill, Jan 4, 2020
  5. kenmce
    1,527
    502
    NY
    That's what we have research colleges for - to find stuff. I am still deeply suspicious of it because there are almost zero technical details. I figure it's at least 50/50 that this will be a lab curiosity, and nothing more.
  6. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    I've seen this "store hydrogen as a solid" idea come up several times in the past two decades and, while I don't have access to it anymore, believe its well situated in the scientific literature as a legitimate thing. However, before anyone touts this as a breakthrough, realize that there are enormous challenges of getting something that works in the lab to work outside of it. In fact, there is a term called the innovation "valley of death" to describe exactly this problem:
    This is why you often don't see these "breakthroughs" turn into final products very often.
    If Dr Enass Abo-Hamed can find a way through this barrier, then more power to her. Hydrogen fuels cells are dumb for cars, but do have a legitimate place for making aircraft sustainable.
