Hacking the solar?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by HTMLSpinnr, Jan 22, 2009.
  1. HTMLSpinnr
    HTMLSpinnr Moderator
    5,338
    908
    251
    Surprise, AZ (Phoenix)
    So one of the first things that has come to my mind - AZ has over 300 "sunny" days per year. If that solar panel is ONLY going to run vent fans, there's times of the year when it could be doing other things. Once we're able to download electrical diagrams, how many would be interested in looking into wiring up a float charger for the 12V battery, or directing that power elsewhere when the vent is "disabled"?
    This, of course, assumes Toyota didn't design this feature already.
    2 people like this.
  2. neutronned
    neutronned New Member
    65
    17
    Twin Cities MN
    Call me gutless, but this sounds like a warranty breaker to me. I'll be disappointed if they don't already use the solar cells to top off both batteries. Seems like a natural to me to trickle charge the 12V battery and not much extra work to charge the motive battery.
    Anyway, I'll help read schematics and make suggestions but I'll have to stop there. Even if I wasn't worried about voiding the warranty, my wife would kill me if she saw me cutting into and soldering up our new Prius.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,032
    Northern Michigan
    It only runs the fan. Toyota was very clear on this issue.
    Tom
  4. HTMLSpinnr
    5,338
    908
    251
    Nobody claimed it warranty safe. However, the "right" way to go about it would be to locate a harness and build in a Y adapter, or some sort of "board" to fit between. No wires broken, and worst case, you remove the unit should it become a problem.
    I took the same approach w/ the EV button on the '04 when determining how to integrate w/o the existing hardness. I did "tap" some wiring, but not in a manner that was destructive or irreparable. I knew it was a possible warranty voider, however made it easy enough to remove should it be required.
    Given our trend of the EV button hacking, and it now showing up in the 2010 (Thanks Toyota), the efforts for solar to do other functions could easily be OEM integrated in the future should they prove viable.
    Some of the solar challenges to "overcome" would be voltage regulation and current backflow (nothing like discharging a battery back through the panel overnight or on a cloudy day). The more challenging feat would be integrating w/ the override switch.
    I'm not an EE, just a guy w/ ambition and ideas, but not w/o some common sense ;-)
  5. darelldd
    6,057
    382
    Northern CA
    Yeah, you've got to pay to play. As long as you don't break anything, then no warranty can ever be voided. :)
    Rick - it is easy to prevent backflow with a diode. Charging the 12V would likely be quite simple. Charging the HV battery would be too complex (expensive and ineffective) to make any attempt worthwile. I think it should just power a propeller on the top of the car when it is doing nothing else. You know -like a propeller beanie. It does drive me nuts that around here that PV panel would only be put to use about five months out of the year - the rest of the time I WANT whatever heat is collected in the car to stay there! What a waste of product!
  6. HTMLSpinnr
    5,338
    908
    251
    Right sizing the diode, if not already present, would be the only simple challenge.
    I had no illusions of doing the HV battery, by the time you run through a step-up transformer (and it's losses), there's probably not much current left to be effective.
  7. qbee42
    18,058
    3,032
    Northern Michigan
    I could use it for a couple of days in August. The rest of the time snow would block the PV panel.
    Tom
  8. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    there is probably good reason on why it runs only the fan too :).
  9. qbee42
    18,058
    3,032
    Northern Michigan
    Probably the main reason is that the PV array doesn't generate much power. Toyota probably figures that the cost and complexity of routing that power to the 12V battery is not justified. Routing it to the HV battery is silly.
    Tom
  10. efusco
    efusco Moderator Emeritus
    19,885
    1,156
    Nixa, MO
    Such as?
    Other than cost and additional circuitry I can't think of any. Why not use it to power the 12v accessories and computers while you're driving? A tiny benefit I grant you, but it's something and it's better than letting the expensive solar array sit up there on the roof unused.
    Why not allow it to float charge the 12v...particularly when it's sitting unused for a week or more in an airport parking lot?
    It adds complexity to the system, indeed, but it also makes the cost of a PV panel like that a bit easier to swallow knowing it's doing something any time there's sunlight for it to gather.
  11. miscrms
    miscrms Plug Envious Member
    2,076
    519
    Phoenix, AZ
    It certainly is a natural fit. The car will tend to heat up when its sunny, and the sun angle is high (ie in summer). Part of the problem with utilizing it for something else the rest of the year is that the sun angle will be poor, which will not only limit hours of production, but also reduce peak production.
    For example:
    Average Wh/day for 80W panel at 0deg inclination in:
    Month: -- 1 - 2 - 3 - 4 - 5 - 6 - 7 - 8 - 9 - 10 - 11 - 12
    Phoenix: 214 288 359 458 504 500 471 436 380- 314- 233- 188
    Duluth:- 115 184 300 326 392 416 387 340 254- 173- 96 - 82
    Seattle:- 49 105 196 281 375 409 411 330 251- 131- 66 - 36
    I used the site below, with the following inputs: System size = 8kW (result divided by 100), DC/AC conversion 0.9 (higher than default 0.77 as we don't have to convert to AC), and array tilt angle = 0 deg.
    PVWATTS v. 1
    Ideally I would think running a block or battery heater in winter would be very desirable, but I don't see there being enough power available to do much. The OEM block heater is 400W, and takes 3 hours to heat the block using ~1200Wh of power. A trickle charge on the 12V battery is probably feasible though. You'd probably need something like the charge controller below, although this one would probably be overkill. The nice thing about ones like this is they function like a dc:dc converter, or buck/boost converter, taking whatever the solar panel voltage is and transforming it to the battery charge voltage while putting as much current into the battery as possible. This is much more efficient than an old school solar charger.
    Blue Sky Solar Boost 2512iX 25A,12V 3 Stage Charg - Blue Sky Solar Charge Controllers (MPPT) @ AltE
    Rob
  12. miscrms
    2,076
    519
    Phoenix, AZ
    Incidently, in Seattle in December, if you can find a south facing 47 degree hill to park on you can more than double your solar output. Maybe a jack of some sort is in order ;)
    Rob
  13. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Would have helped if they had hinged the solar panel, so it could be tilted to the best angle for max. power!
    But given its low power output, I think it is as much a marketing ploy for Kyocera as for Toyota, with the former picking up much of the tab.
  14. patsparks
    10,664
    562
    Adelaide South Australia
    Why trickle charge a fully charged battery?
    I think some people are starting to work out the solar panel is an expensive gimmick, nothing more.
    The cost of the solar panel over the life and location of the car combined with the limited amount of time it would be useful mean the solar panel would never recoup the additional cost. It shouts GREEN to the world but it is quite black.
    A PV array on the roof of a house has a life of productive power conversion of +25 years, even a Toyota Prius won't live 25 years on average due to collision damage, corrosion and wear.
    The PV on the roof of your home collects power when ever the sun is shining and if it makes more than the household is using at that moment pushes the left over into the grid for someone else to use, the Prius panel only works when the car is parked in the sun and it is going to get hot in the car, otherwise it's a decorative item.
    The PV on the roof of a house is carried from factory to final location once, the PV on the roof of a Prius will add weight to that Prius for its entire life, meaning that the panel will be responsible for transport costs of the journey from factory, via Toyota's factory to the dealer then another 300,000 miles of travel until the end of the vehicles life. Carrying that additional weight will cost in fuel consumption.
    I think if you want the solar panels to be green, don't.
    If you want the solar panel to look green, go ahead but keep the truth quiet.
    If you want the moon roof and it only comes with the solar panel, what can you do?
    These are just my thoughts, no science to back it up, just dead reckoning and gut reactions.
    I'm not trying to force my opinion on anyone and if a friend gets a solar panelled Prius I will praise it like a grandmother would a baby grandchild but if you are out to reduce your carbon footprint you would be better off putting the added cost of the solar roof Prius toward a home mounted PV array, it would be a better investment for the planet..
    2 people like this.
  15. HTMLSpinnr
    5,338
    908
    251
    Pat, if I lived anywhere but in AZ, I'd be inclined to agree with you. However at least 6 months out of the year, I will have solar venting turned on. It's those other 6 that I'd like "something" useful.
    Don't forget, there are also parasitic losses within the car, from SKS to security system to clock. Probably quite minor, but why not let an already installed feature carry that load vs. the battery? And for those cars that do get parked at an airport for a couple weeks straight, what a way to keep the 12V battery from going flat?
  16. efusco
    19,885
    1,156
    Nixa, MO
    Considering the current OEM setup of this PV I think you're assessment is totally on target Pat.
    It seems almost slapped on. If they'd have used the entire roof and made this closer to 200W it may have been more useful had it been more completely integrated into the car. 200W would be enough for to run a tiny heater to keep the edge off a really cold day. It would be enought to run all the electronics and take at least part of the load of the AC even on a hot day. Maybe, just maybe, it would be enough to passively charge the HV battery a little bit.
  17. HTMLSpinnr
    5,338
    908
    251
    I think the message we're seeing is despite some of the improvements we're seeing, there's definitely a few options that feel last minute - heated seats, perhaps solar w/ it's limited integration.
  18. patsparks
    10,664
    562
    It is very hot here in summer too but we are talking a 5 minutes per drive benefit from the solar panel, the remote AC to me makes sense.
    Good point but a costly way to do it. A solar battery charger which cost about $25 on the cargo blind during long periods parked in the open would do the job just as well I suspect.
    Anyone remember the accessory solar powered fans that went in the side windows?
    Maybe my mind is just rationalising for me why I won't be getting the solar panel roof? Never been a sun/moon roof fan myself.
    Evan, for cabin heating a double glazed roof would be more effective. Let the sun in but keep it in too. Of course if you can't cover the glass you have cabin heating in spades in hot sunny weather, when you don't want it.
  19. HTMLSpinnr
    5,338
    908
    251
    The Solar panel was supposed to assist the A/C per the onsite specialist. Thinking back and looking @ the graphs, the solar venting makes less work for that remote A/C. W/o the solar vent, there's an additional temperature differential that the A/C would be working to reduce, and that power would be made up by the ICE recharging the battery. Therefore, indirectly, the solar panel is assisting the HV battery (and MPG) by requiring less A/C work. Besides, the thought of getting into a car that isn't 140°F/60°C is appealing in any scenario and "worth" that expense over the life of the car.
    Yes, we tried one in our 2002 - the solar tinted glass (stock) rendered the solar panel ineffective. We found once we sat the panel out of the way of the glass, the fan ran full speed. However, once placed in the window crack, the fan all but ceased to spin. Was really disappointing, but it was on loan from the in-laws. I suspect the $25 charger you mention would suffer a similar problem w/ the glass reducing the efficiency of the panel.
  20. patsparks
    10,664
    562
    Another way the solar could have been used, this is after all a cutting edge vehicle.
    Charge the traction battery and run a small transmitter. When the key fob is within a predetermined distance, user defined within hardware limits the AC comes on to adjust the interior temperature toward the preset comfort level selected by the driver when last driven. An electric inverter controlled AC could be reverse cycle for this purpose.
    The only charge you could put into the traction battery is from the normal state of about 60% charged up to 80% full charge and once this state was reached the AC fan could be powered if the interior temperature was further for the preset temperature than the outside air.
    I still would see the solar panel as a look good feel good item of little practical use. Hard to please hey?
    Edit, I suspect you are right Rick, damn UV reducing glass.
    I agree with what the solar panel is meant to do and it will reduce the overall load on the engine for recharging the traction battery after remote cooling but when considering the added weight of the solar panels and that the added weight is on top of the car inducing more body roll so requiring more speed reduction for corners, I suspect the solar panel uses more energy over its life particularly in its current part time role than it contributes.
Loading...
