Had my 15K service today
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by crebble, Oct 8, 2012.
  1. crebble
    crebble Member
    176
    47
    Shohola PA
    Pretty anti-climatic. It was the same as the 5K. Fluid levels, tire rotation and a once over. They also tried to soak me $50 for a cabin air filter change. :).
  2. Mik1
    Mik1 Member
    333
    Houston, TX
    Save your money, get charcoal one from Walmart for $15. Filter replacement will not take more than 5 mins. It is located in your glove compartment.
  3. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Behind the glove box, isn't it?
    Pull in the box stops/ears and drop it down. It should be right behind.
    I thought it was a 30k mile change for that filter...
  4. Mik1
    Mik1 Member
    333
    Houston, TX
    Yes it is. I replaced mine almost right after I've got the car. The reason is because charcoal filter does much better work compared to the "standard" cloth one they have in there.
  5. crebble
    crebble Member
    176
    47
    Shohola PA
    Thanks. I just did one for a relative on an '11 Corolla. Figured it would be similar. I live on a gravel road, so it is possible that it should get changed out early.
  6. Mendel Leisk
    38,726
    FWIW, I think the manual says it's kosher to just inspect it, and blow it out with compressed air if it's not heavily clogged.
  7. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    I went for my 15K service the other day. One thing I will have to change is my Trip A/Trip B usage. I always used Trip A for tank and Trip B for trips. It seems like the service tech resets Trip A when he is resetting some values, so I lose my tank info, such as MPGs and MPH stats.
    When I fill up again, I will use Trip B for my tank stats and Trip A for trips. Just thought I'd let everyone know!
  8. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    Can you be more specific as to exactly what you bought at Walmart for this? Was it made for the car, or was it just some charcoal material you found that you cut to fit? A search of their site came up empty on a specific filter type part
  9. Mik1
    Mik1 Member
    333
    Houston, TX
    Walmart sells filters in their auto section. They usually have paper books or electronic libraries where you can find the model of the filter you need. Do not search for Prius C look for Camry (2010, 2011 models will be fine). Prius C has the same cabin filter as Camry. Once you will find a required model, open the box and check if the filter has black (charcoal) fibers in it. If it does, that's what you need.
    rjdriver likes this.
  10. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    +1 It's always a good idea to look in the box and see if the correct part is there. Some dirtbags take more expensive parts out of boxes and put them in boxes with lower priced labels to save money.
  11. Mik1
    Mik1 Member
    333
    Houston, TX
    Learned my lesson in the past. I went to buy spark plugs (a set of 6) to O'Reilly for my dad's car. I've got one small box which suppose to have 6 smaller boxes with new spark plugs in it. Didn't pay attention at the beginning (opened the box-->saw 6 smaller boxes-->paid money-->went home), but found out later that one smaller box inside of this bigger box was empty. Have to give a credit to O'Reilly, they gave me one new one without asking a single question, but I could read on manager's face that it was something that they had before. The rest is mystery....
  12. rjdriver
    406
    168
    Rhode Island
    Thanks
