had snow tires mounted inflation light?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gone2green, Dec 21, 2007.
  1. gone2green
    gone2green grumpier than the grumpiest old man you know ;)
    117
    17
    Mesa AZ
    2015 Prius v wagon
    I had snow tires mounted on the stock rims today, the question is should not have the underinflation light come on?
    they did not reset anything.
    how to check if the warning system is working?
    thanks in advance
  2. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    If you originally had your TPMS set for 40 psi and they filled your replacement tires to more than 30 psi, then there would be NO alarm. (Assuming the TPMS sensors stayed on the tires.)
    To check the system:
    1) Measure your present tire pressure,
    2) Reset your TPMS system,
    3) Lower your pressure by at least 25 % (original: 40, lower it to less than 30 psi -- 1/4 of 40).
    4) Check your system. You may need to drive a little before the light comes on.
    Be SURE to REFILL your tires after you're through.:D
    This works in my TCH, but YPMV (Your Prius May Vary), however, in this case, I doubt it.
  3. p10leadman
    p10leadman New Member
    Maine, USA
    I too, just bought a set or snow tires on rism all mounted, do not know if there is a TPMS sensor insdie or not.....will this harm anything? Other than Toyota, where can I buy the sensors?:confused:
