had the Snow Flake and termination dust
Discussion in 'Gen 2 Prius Main Forum' started by Frank Hudon, Sep 1, 2006.
  1. Frank Hudon
    Frank Hudon Senior Member
    4,147
    falling on me yesterday morning on the way home from Alberta. Height of the continental divide. Not sticking on the road but right to the shoulder in the trees. Summers over!
  2. Tideland Prius
    16,445
    already? dang...
    which pass?
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    It's still topping 105F (45.5C) here in Phoenix. We're lucky if our lows dip below 80F (26.5C).
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Wow, isn't it usually mid-Sept. before you see that?
  5. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 31 2006, 11:04 PM) [snapback]312609[/snapback]</div>
    Vermillion Pass between Banff Alberta and Radium Hot Springs. Rick I don't know how you people live in PHX my temp limit is about 85F. Evan we had a really intense cold front move thru and this is out of the ordinary for this time of year but in the rocks you never know. 5415'
  6. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    It's normal to get "temporary snow" in the mountains of Alberta/BC this time of year. I always live in fear if I take my RX-7 to the coast this time of year - that thing is impossible in snow, because of the "performance tires". They are ball bearings in snow. ;)
    We will now return to another month of wonderful weather, then winter will decend on us.
  7. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(David Beale @ Sep 1 2006, 07:27 AM) [snapback]312714[/snapback]</div>
    got 4"of snow in Lethbridge one August afternoon in the late 80's when a cold front went thru. It was in the hi 20's and just kept dropping till it snowed. Was there visiting and had to go and try and buy a coat, but in August they are really hard to find, bought a sweater instead. You should have seen all the slipping and sliding then. Not a snow tire in sight.
  8. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    <div class='quotetop'>QUOTE(Frank Hudon @ Sep 1 2006, 10:19 AM) [snapback]312706[/snapback]</div>
    It's a terribly overused cliche, but: "It's a dry heat."
    I, though, simply try to avoid going outside whenever possible. All the stores set their air-conditioning to "artic."
