Had the triangle OD and check engine light come on
Discussion in 'Generation 1 Prius Discussion' started by EbonBetta, Mar 16, 2018.
  1. EbonBetta
    EbonBetta Junior Member
    47
    16
    palmdale
    2002 Prius
    I
    I had the main issue and check engine light and all light yesterday.
    This morning I checked the diagnosis screen and battery reads 11.4. Should I change the battery or wait ??
  2. JC91006
    16,827
    8,600
    Charge up the battery first and test it. The batteries seem to last 5+ years. You probably have other issues not related to the 12v.
  3. Mendel Leisk
    41,906
    Check the voltage with a voltmeter, car off. If it's still around 11.4 volts, I think you've found your problem, and that would be good: simple, and remedy is easy.
  4. EbonBetta
    47
    16
    palmdale
    2002 Prius
    I
    Did not do anything today but drove about 5 -8 miles returning some dvd. After battery read as 12.7. willl see what i drops to by tomorrow.
  5. EbonBetta
    47
    16
    palmdale
    2002 Prius
    I
    checked battery this morning...current reading again...11.4
  6. Mendel Leisk
    41,906
    Way too low, replacement time.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Change it......after checking the voltage when the vehicle is running (ready to drive).
    11.4 is bordering on stone cold dead.
    And yes I know that a really LOT of people don't understand that.
  8. Cosmo Tigato
    Cosmo Tigato Active Member
    201
    363
    Oregon, USA
    Use a sealed deep cycle battery (Optima) Works great. I use it all my Pri'i (Prius's)
