Halfshaft (grease on boot)?
Discussion in 'Gen 3 Prius Technical Discussion' started by Jay J, Mar 16, 2013.
  1. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Anyone else's half shafts greasy???
    (I was under my car today) took off the the rear half spashshield to do one of the cusco bars and saw grease(not a huge amount) just damp to the touch around the boot-my car is right around 10,100 miles =/?
  2. peterjmc
    917
    189
    Clarksburg, MD
    Shouldn't be greasy. You should inspect for any holes or tears. If no holes, or tears... Maybe grease left from factory?
    frodoz737 likes this.
  3. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Did inspect for holes...Denada =/
  4. frodoz737
    frodoz737 Top Wrench
    4,531
    2,437
    33
    Grease on the outside of the CV Joint Boot "usually" means it's punctured, cracked or the band clamps have become lose or broken. If this is the case, a repair kit is available. If the problem is not addressed it will lead to premature failure of the joint from lack of lube. Thorough inspection will determine the cause.
    Rebound likes this.
  5. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    It is under warranty still :p
  6. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I doubt that the warranty will cover a hole in a CV joint boot after 10k miles.
  7. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Powertrain (FWD system) is 60/60000
  8. frodoz737
    4,531
    2,437
    33
    I hope so at 10,100 miles. Good catch.
  9. Former Member 68813
    3,524
    983
    US
    It doesn't cover road hazards.
  10. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Its under the car (covered) by the under tray.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    Are you sure it's grease, my right hand inner CV boot has had from new, a thin coat of sticky residue all over it (looks a bit like the protective waxy stuff they spray on metals to prevent corrosion) but it's definitely not grease and there are no leaks.
    If yours is leaking there will be some grease deposited around the area where it gets flung off the boot.
  12. Mendel Leisk
    40,575
    ^ +1.
    I was thinking ours was leaking or something. It looked shiny, but I think now it was just some coating left over from manufacturing process, or whatever. No change in over a year since. No sign of leaking/flung grease.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    I wouldn't worry about it, mine's not showing any adverse effects after being like that for 3 years
  14. BZzap!
    BZzap! Senior Member
    1,607
    878
    If you don't see any evidence of it throwing grease in surrounding area, I wouldn't worry about it.
